Guest asrequested Posted July 21, 2018 Posted July 21, 2018 Aaaaarrrrrggghhhhh! Nothing is consistent. It works in part, then it doesn't work at all. This doesn't work, correctly! There's something wrong with how the server is reading these folders/files.
Guest asrequested Posted July 21, 2018 Posted July 21, 2018 And why does it only sometimes play trailers? A lot of the time, all I get is the custom intro, then straight to the movie. No trailers and no codec intro! This whole cinema mode doesn't seem to work, very well.
Luke 42287 Posted July 21, 2018 Posted July 21, 2018 We'd have to look at a specific example. Thanks.
Guest asrequested Posted July 22, 2018 Posted July 22, 2018 I think I figured out the trailer issue. If I set to play only one trailer in the server, when I play a movie, it doesn't play any. I set it to play 2 trailers, and I get 2 trailers. 1 apparently doesn't work.
Mopar_Mudder 14 Posted July 22, 2018 Author Posted July 22, 2018 I have mine set to play 2 and some times it doesn't play any. Codec seems to work fine but I don't do Atmos
Guest asrequested Posted July 22, 2018 Posted July 22, 2018 I have mine set to play 2 and some times it doesn't play any. Codec seems to work fine but I don't do Atmos Yeah, it's very inconsistent. I can't find a specific way to reproduce it. It just randomly does or doesn't do it.
Mopar_Mudder 14 Posted July 22, 2018 Author Posted July 22, 2018 I thought maybe do to internet speed at the time?
Luke 42287 Posted July 24, 2018 Posted July 24, 2018 It may depend on whether or not there is also a cinema trailer available for that item. Can you confirm?
Guest asrequested Posted July 24, 2018 Posted July 24, 2018 How would we confirm that? Doesn't the trailer plugin just pick which to play? Or are you saying that a particular movie may or may not get trailers? If I test with same movie, repeatedly, sometimes I get trailers and sometimes I don't
ShoutingMan 101 Posted July 29, 2018 Posted July 29, 2018 I’ve got the Trailer set to just 1 and all options disabled (having problems with local trailers). I get my theater intro and a codec intro. If a movie is tagged Atmos, I get both TrueHD and Atmos. I’ve not noticed any problems with this.
Guest asrequested Posted July 29, 2018 Posted July 29, 2018 I've given on the atmos folder. No way that I've tried, works.
Guest asrequested Posted January 19, 2019 Posted January 19, 2019 Ok, I'm reviving this, because it still doesn't work. Here's something I'd like you to test. This is a link to an EAC3 + Atmos codec intro. Using only that intro, play an Atmos soundtrack that is not EAC3 and tell me how you get it to work. I've tagged it as Atmos, and it doesn't play.
Luke 42287 Posted January 19, 2019 Posted January 19, 2019 Well what is the media info in the web app?
Guest asrequested Posted January 19, 2019 Posted January 19, 2019 Well what is the media info in the web app?
Guest asrequested Posted January 19, 2019 Posted January 19, 2019 This was what I was trying to explain, earlier. Atmos isn't a codec, and ffprobe isn't seeing it. If that's what's being relied on, Atmos won't be able to be used, directly.
Luke 42287 Posted January 19, 2019 Posted January 19, 2019 Try just naming it atmos.mkv, then run a library scan.
Sammy 791 Posted March 10, 2022 Posted March 10, 2022 On 1/19/2019 at 11:00 AM, Luke said: Try just naming it atmos.mkv, then run a library scan. Searching for EAC3 codec intros I ran across this old thread. Is there any follow up on this, @Luke
Luke 42287 Posted March 14, 2022 Posted March 14, 2022 On 3/10/2022 at 9:56 AM, Sammy said: Searching for EAC3 codec intros I ran across this old thread. Is there any follow up on this, @Luke Hi, what exactly are you asking about?
Sammy 791 Posted March 14, 2022 Posted March 14, 2022 Having Cinema Mode identify E-AC3 audio and play a codec intro for Dolby Atmos.
Luke 42287 Posted March 14, 2022 Posted March 14, 2022 21 minutes ago, Sammy said: Having Cinema Mode identify E-AC3 audio and play a codec intro for Dolby Atmos. For eac3 you can learn about that here: https://support.emby.media/support/solutions/articles/44001848833-cinema-intros For atmos, it's the same thing but it also depends on detection in the core server first.
