Daithi 3 Posted March 13, 2014 Posted March 13, 2014 Started hitting a problem a few nights ago (can't say for sure but I think it was just after update to Server version 3.0.5171.19958) where TV series folders appear to be empty when I go to play an episode. The series level metadata is viewable, the folder indicates the correct number of unwatched episodes but when I navigate into the season folder in MBC (3.0.129.0 2-12.2) it is empty and through web view in IE 11 I get "Value cannot be null. parameter name: Item" error and also empty. Which series this effects seems to change from night to night, fixing previously "broken" episodes one night while "breaking" new ones the next. I've confirmed the files play outside of MB. Setup is Server running on Media Center with all content sitting on a NAS. Logs - here
ebr 16357 Posted March 13, 2014 Posted March 13, 2014 There's a ton of errors trying to get the last modified date on your file system.
Luke 42301 Posted March 13, 2014 Posted March 13, 2014 2014-03-13 11:25:07.5937 Error - App: Error resolving path \\MEDIABOX\Multimedia\TV\2) Archived\Drama\Da Vincis Demons The specified network name is no longer available. System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
ebr 16357 Posted March 13, 2014 Posted March 13, 2014 If you have server and client all on the same machine, more than likely, the server is coming up before your network is fully initialized so we cannot get to your NAS. 1
