grid-hibiscus-pancake 6 Posted March 10, 2018 Author Posted March 10, 2018 Thank you for such a fast fix, I will check in latest dev/beta build. I tried looking into the latest commit, but I am not quite well versed in C#... What settings do you accept? Could you tell me if any of below should work? Can you add example to the dialog itself? IP Addresses ex. 192.168.1.1, 192.168.1.2 (comma separated)? Netmasks(comma separated) ex. 192.168.1.1/24 ? or 192.168.1.1/32? Netmask 192.168.1.1/255.255.255.0 ? Thank you for clarifying this.
hooray4me 52 Posted March 10, 2018 Posted March 10, 2018 I've got this example resolved for the next release, thanks. When do you think the next release will be ready?
Luke 42210 Posted March 10, 2018 Posted March 10, 2018 Sorry we don't offer ETAs but it should be consistent with our patterns.
grid-hibiscus-pancake 6 Posted March 10, 2018 Author Posted March 10, 2018 Luke, did your see my post #26? Could please comment on that? Thank you so much. Sent from my Pixel XL using Tapatalk
Luke 42210 Posted March 10, 2018 Posted March 10, 2018 Those should work yes and I can add an example. 1
grid-hibiscus-pancake 6 Posted April 29, 2018 Author Posted April 29, 2018 Hi @@Luke I think I found a strange little bug in the latest stable version of emby Version 3.3.1.0 If Lan Networks is set to something ex. 192.168.1.1/255.255.255.0 Then both following URLS will fail to load with 500 http://serverip:8096/web/serversecurity.html http://serverurl:8096/web/userprofiles.html Server log 2018-04-29 11:27:13.428 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.1.0 Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.9.0.6 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /config Application directory: /system System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at Emby.Server.Implementations.Networking.IpAddresses.GetSubnetAndMaskFromCidr(String cidr) at Emby.Server.Implementations.Networking.NetworkManager.IsInConfiguredLocalSubnets(IPAddress address, String[] subnets) at Emby.Server.Implementations.Networking.NetworkManager.IsInLocalNetworkInternal(String endpoint, Boolean resolveHost) at Emby.Server.Implementations.Library.UserManager.GetUserDto(User user, String remoteEndPoint) at System.Linq.Enumerable.SelectIPartitionIterator`2.PreallocatingToArray(Int32 count) at System.Linq.Enumerable.SelectIPartitionIterator`2.ToArray() at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at MediaBrowser.Api.UserService.Get(GetUsers request, Boolean filterByDevice) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() System.FormatException at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at Emby.Server.Implementations.Networking.IpAddresses.GetSubnetAndMaskFromCidr(String cidr) at Emby.Server.Implementations.Networking.NetworkManager.IsInConfiguredLocalSubnets(IPAddress address, String[] subnets) at Emby.Server.Implementations.Networking.NetworkManager.IsInLocalNetworkInternal(String endpoint, Boolean resolveHost) at Emby.Server.Implementations.Library.UserManager.GetUserDto(User user, String remoteEndPoint) at System.Linq.Enumerable.SelectIPartitionIterator`2.PreallocatingToArray(Int32 count) at System.Linq.Enumerable.SelectIPartitionIterator`2.ToArray() at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at MediaBrowser.Api.UserService.Get(GetUsers request, Boolean filterByDevice) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() 2018-04-29 11:27:13.430 Info HttpServer: HTTP Response 500 to 192.168.1.12. Time: 49ms. http://broadcast.xxxx.net:8096/emby/users
Luke 42210 Posted April 29, 2018 Posted April 29, 2018 Please try again with the next release of Emby Server, thanks.
grid-hibiscus-pancake 6 Posted April 29, 2018 Author Posted April 29, 2018 Ok I will and report back.
