VladTepz 47 Posted January 16, 2018 Posted January 16, 2018 (edited) Using Kodi's PlayMedia to directly play playlists is no longer working in the beta 3.0.x versions. This is useful for playlist scripts or directly playing playlists from the menu or skin shortcuts.PlayMedia to directly play playlists is still working fine in the stable 2.3.x versions. PlayMedia(special://profile/playlists/video/MyPlayList.xsp) Here is the error snippet. I can post the full log if needed. 10:45:50.342 T:22072 NOTICE: VideoPlayer::OpenFile: special://profile/playlists/video/MyPlayList.xsp 10:45:50.343 T:22468 NOTICE: Creating InputStream 10:45:50.345 T:22468 NOTICE: Creating Demuxer 10:45:50.347 T:22468 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, special://profile/playlists/video/MyPlayList.xsp 10:45:50.347 T:22468 ERROR: CVideoPlayer::OpenDemuxStream - Error creating demuxer 10:45:50.347 T:22468 NOTICE: CVideoPlayer::OnExit() 10:45:50.392 T:20080 ERROR: EXCEPTION: XBMC is not playing any file 10:45:50.494 T:20080 NOTICE: EMBY.kodimonitor -> Method: Player.OnPlay Data: {"item":{"title":"","type":"movie"},"player":{"playerid":0,"speed":1}} 10:45:50.494 T:20080 NOTICE: EMBY.kodimonitor -> Item is invalid for playstate update 10:45:50.595 T:20080 NOTICE: EMBY.kodimonitor -> Method: Unknown.OnChanged Data: null 10:45:50.687 T:20080 NOTICE: EMBY.kodimonitor -> Item is invalid for playstate update 10:45:50.687 T:20080 ERROR: EXCEPTION: XBMC is not playing any file 10:45:51.232 T:20080 ERROR: Previous line repeats 5 times. 10:45:51.232 T:20080 NOTICE: EMBY.player -> Cancelling playback report... If any more info is needed I'd be more than happy to provide anything needed. Edited January 19, 2018 by VladTepz
sualfred 677 Posted January 16, 2018 Posted January 16, 2018 @@Angelblue05 I can confirm that it's broken. This also happens if you manually add items to a queue and start the playback right out of the playlist window.
Angelblue05 4132 Posted January 16, 2018 Posted January 16, 2018 Thanks for reporting this, I'll have a look. Sent from my iPhone using Tapatalk
Solution Angelblue05 4132 Posted January 19, 2018 Solution Posted January 19, 2018 Give 3.0.5a a try. Let me know if your issue is resolved. 1
VladTepz 47 Posted January 19, 2018 Author Posted January 19, 2018 @@Angelblue05 Everything seems to be working as expected with v3.0.5a. Thank you! 2
