rkr87 3 Posted March 13, 2014 Posted March 13, 2014 Hi, I just installed the auto-boxsets plugin and it generated boxsets for my entire collection perfectly and also brought all meta data - however it didn't bring any art over - so I just have a collection full of the default coverart folder image. Did I do something wrong or is this not included with auto-boxsets? Thanks.
Logos302 86 Posted March 13, 2014 Posted March 13, 2014 Has the scan media run more than once? I believe (Could be wrong) but it creates the directories and the metadata, and then when the scan media runs again it will pick this up causing a it to download the backdrops and folder images.
rkr87 3 Posted March 13, 2014 Author Posted March 13, 2014 I thought that too so I manually started the scan media library task and while it has downloaded backdrops for a couple of the boxsets none of them (currently 50 box sets) has a folder image downloaded :s I've checked a few of them on tmdb too and they definetely have art available, which I was pretty sure of since I have downloaded art for them manually in the past.
ebr 16344 Posted March 13, 2014 Posted March 13, 2014 The plug-in doesn't actually fetch anything. It just creates the items and then the normal system takes over. If you browse images for those collections in the editor, does it show any? If you refresh the collection item, does it download a poster? Are there errors in the logs?
rkr87 3 Posted March 13, 2014 Author Posted March 13, 2014 I just went into the editor via the webclient and clicked browse images, and the poster images are displayed. If I click refresh it doesn't download them though. How do I check the error log?
ebr 16344 Posted March 13, 2014 Posted March 13, 2014 How do I check the error log? Pinned at the top of this forum: How to report a problem
CBers 7558 Posted March 13, 2014 Posted March 13, 2014 (edited) None of my BoxSets have metadata either. I found this out earlier today, so deleted all of by BoxSets, forced the plugin to refresh, which it did, but umpteen library scans later, still no metadata. If I manually refresh an individual BoxSet, metadata is fetched OK. . Edited March 13, 2014 by CBers
ebr 16344 Posted March 13, 2014 Posted March 13, 2014 This probably got something to do with the way providers were changed in the last release. It probably is seeing something that is making it think it shouldn't go fetch data. I am going to just pull the Auto Box Sets plug-in for now because we will be re-working how it operates in the future.
rkr87 3 Posted March 13, 2014 Author Posted March 13, 2014 ok, I removed all folders from my collection and created a new movie library with 2 movies that I knew are in a box set together. 2014-03-13 19:32:09.2201 Debug - App: Searching for: PmpSearcher 2014-03-13 19:32:09.2211 Error - App: Error reported by Mono.Nat: An existing connection was forcibly closed by the remote host System.Net.Sockets.SocketException at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at Mono.Nat.NatUtility.Receive(ISearcher searcher, List`1 clients) at Mono.Nat.NatUtility.SearchAndListen() 2014-03-13 19:32:16.1205 Info - App: Cache file cleanup Completed after 0 minute(s) and 14 seconds 2014-03-13 19:32:17.1616 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/System/Info 2014-03-13 19:32:17.2131 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Plugins 2014-03-13 19:32:17.2131 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/configurationpages?pageType=PluginConfiguration 2014-03-13 19:32:17.4946 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 280.5233 ms Url: http://localhost:8096/mediabrowser/dashboard/configurationpages?pageType=PluginConfiguration 2014-03-13 19:32:17.4946 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 281.0234 ms Url: http://localhost:8096/mediabrowser/Plugins 2014-03-13 19:32:17.5426 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 395.0318 ms Url: http://localhost:8096/mediabrowser/System/Info 2014-03-13 19:32:17.9816 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/ConfigurationPage?name=Automatic BoxSets 2014-03-13 19:32:17.9916 Debug - HttpServer: HTTP Response 304 to [::1]:59915. Response time: 11.0006 ms Url: http://localhost:8096/mediabrowser/dashboard/ConfigurationPage?name=Automatic BoxSets 2014-03-13 19:32:18.0396 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/System/Info 2014-03-13 19:32:18.0656 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Plugins/899c12c7-5b40-4c4e-9afd-afd74a685eb1/Configuration 2014-03-13 19:32:18.0666 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 31.0018 ms Url: http://localhost:8096/mediabrowser/System/Info 2014-03-13 19:32:18.0666 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 10.0005 ms Url: http://localhost:8096/mediabrowser/Plugins/899c12c7-5b40-4c4e-9afd-afd74a685eb1/Configuration 2014-03-13 19:32:18.5716 Info - App: Client connected from 127.0.0.1:59919 2014-03-13 19:32:19.0837 Debug - SessionWebSocketListener: Received Identity message: Dashboard|1ed105bc7765665627b084b425ea52b641c1f30d|3.0.5171.19958|Chrome 33.0.1750.146 2014-03-13 19:32:19.1767 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/AutoBoxSets/Refresh 2014-03-13 19:32:19.1917 Info - Automatic BoxSets: Executing Automatic BoxSet creation. Found 1 potential box sets. 2014-03-13 19:32:19.1917 Debug - Automatic BoxSets: Found box set 43563 with 2 members. 2014-03-13 19:32:19.1917 Debug - LibraryMonitor: Watcher sees change of type Created to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.1917 Debug - Automatic BoxSets: Created new box set: \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.2057 Debug - Automatic BoxSets: Adding member Next Friday 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Watcher sees change of type Created to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.2057 Debug - Automatic BoxSets: Adding member Friday 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Watcher sees change of type Created to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:32:19.2057 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:32:19.2207 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.2207 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.2207 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:32:19.2207 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:32:19.2207 Info - App: Executing Scan media library 2014-03-13 19:32:19.2207 Info - Automatic BoxSets: Automatic BoxSet creation completed. 2014-03-13 19:32:19.2207 Info - App: Sending web socket message ScheduledTaskStarted 2014-03-13 19:32:19.2207 Debug - HttpServer: HTTP Response 204 to [::1]:59916. Response time: 57.0032 ms Url: http://localhost:8096/mediabrowser/AutoBoxSets/Refresh 2014-03-13 19:32:19.2207 Info - App: Validating media library 2014-03-13 19:32:19.3077 Info - Automatic BoxSets: Executing Automatic BoxSet creation. Found 1 potential box sets. 2014-03-13 19:32:19.3077 Debug - Automatic BoxSets: Found box set 43563 with 2 members. 2014-03-13 19:32:19.3077 Debug - Automatic BoxSets: Box set already exists. Will confirm members. 2014-03-13 19:32:19.3077 Debug - Automatic BoxSets: Member Next Friday already exists 2014-03-13 19:32:19.3077 Debug - Automatic BoxSets: Member Friday already exists 2014-03-13 19:32:19.3077 Info - Automatic BoxSets: Automatic BoxSet creation completed. 2014-03-13 19:32:19.5767 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:32:19.5797 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:32:19.5797 Info - BaseItem: Shortcut links have changed for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:32:19.6007 Debug - ProviderManager: Saving \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] to Media Browser Xml. 2014-03-13 19:32:19.6387 Debug - App: Saving \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] to database. 2014-03-13 19:32:19.8877 Debug - App: 192.168.0.1:80: Device denied the connection attempt: System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.0.1:80 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at Mono.Nat.Upnp.UpnpNatDevice.ServicesReceived(IAsyncResult result) 2014-03-13 19:32:20.4238 Info - App: Scan media library Completed after 0 minute(s) and 1 seconds 2014-03-13 19:32:20.4238 Info - LibraryMonitor: Watching directory C:\Users\Ryan\AppData\Roaming\MediaBrowser-Server\root 2014-03-13 19:32:20.4238 Info - LibraryMonitor: Watching directory \\RYAN-PC\Videos\Movies Test 2014-03-13 19:32:20.4628 Info - LibraryMonitor: Watching directory \\RYAN-PC\Videos\Auto Box Sets 2014-03-13 19:32:20.4628 Info - App: Sending web socket message ScheduledTaskEnded 2014-03-13 19:32:20.4628 Info - LibraryMonitor: Watching directory \\RYAN-PC\Music 2014-03-13 19:32:24.2150 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/scheduledtasks.html 2014-03-13 19:32:24.2150 Debug - HttpServer: HTTP Response 304 to [::1]:59916. Response time: 3.0002 ms Url: http://localhost:8096/mediabrowser/dashboard/scheduledtasks.html 2014-03-13 19:32:24.2950 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2014-03-13 19:32:24.3480 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 53.003 ms Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2014-03-13 19:32:24.3560 Info - App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 127.0.0.1:59919 2014-03-13 19:32:25.4870 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb 2014-03-13 19:32:25.4870 Info - App: Executing Scan media library 2014-03-13 19:32:25.4870 Info - App: Sending web socket message ScheduledTaskStarted 2014-03-13 19:32:25.4870 Debug - HttpServer: HTTP Response 204 to [::1]:59916. Response time: 3.0002 ms Url: http://localhost:8096/mediabrowser/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb 2014-03-13 19:32:25.4920 Info - App: Validating media library 2014-03-13 19:32:25.4920 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2014-03-13 19:32:25.4920 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 2.0001 ms Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2014-03-13 19:32:25.7561 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:32:25.7581 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:32:26.0231 Info - App: Scan media library Completed after 0 minute(s) and 0 seconds 2014-03-13 19:32:26.0231 Info - LibraryMonitor: Watching directory C:\Users\Ryan\AppData\Roaming\MediaBrowser-Server\root 2014-03-13 19:32:26.0651 Info - LibraryMonitor: Watching directory \\RYAN-PC\Music 2014-03-13 19:32:26.0451 Info - App: Sending web socket message ScheduledTaskEnded 2014-03-13 19:32:26.0651 Info - LibraryMonitor: Watching directory \\RYAN-PC\Videos\Auto Box Sets 2014-03-13 19:32:26.0651 Info - LibraryMonitor: Watching directory \\RYAN-PC\Videos\Movies Test 2014-03-13 19:32:34.3706 Info - Automatic BoxSets: Executing Automatic BoxSet creation. Found 1 potential box sets. 2014-03-13 19:32:34.3706 Debug - Automatic BoxSets: Found box set 43563 with 2 members. 2014-03-13 19:32:34.3706 Debug - Automatic BoxSets: Box set already exists. Will confirm members. 2014-03-13 19:32:34.3706 Debug - Automatic BoxSets: Member Next Friday already exists 2014-03-13 19:32:34.3706 Debug - Automatic BoxSets: Member Friday already exists 2014-03-13 19:32:34.3706 Info - Automatic BoxSets: Automatic BoxSet creation completed. 2014-03-13 19:32:39.6839 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&ImageTypes=Primary&Ids=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:32:39.8229 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 139.0079 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?Recursive=true&Limit=3&Filters=IsNotFolder&SortBy=DateCreated&SortOrder=Descending&ImageTypes=Primary&Ids=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:32:41.2219 Debug - App: Searching for: PmpSearcher 2014-03-13 19:32:41.2219 Error - App: Error reported by Mono.Nat: An existing connection was forcibly closed by the remote host System.Net.Sockets.SocketException at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at Mono.Nat.NatUtility.Receive(ISearcher searcher, List`1 clients) at Mono.Nat.NatUtility.SearchAndListen() 2014-03-13 19:32:41.4720 Debug - App: Searching for: PmpSearcher 2014-03-13 19:32:41.4720 Error - App: Error reported by Mono.Nat: An existing connection was forcibly closed by the remote host System.Net.Sockets.SocketException at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at Mono.Nat.NatUtility.Receive(ISearcher searcher, List`1 clients) at Mono.Nat.NatUtility.SearchAndListen() 2014-03-13 19:32:42.4720 Debug - App: Searching for: PmpSearcher 2014-03-13 19:32:42.4820 Error - App: Error reported by Mono.Nat: An existing connection was forcibly closed by the remote host System.Net.Sockets.SocketException at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at Mono.Nat.NatUtility.Receive(ISearcher searcher, List`1 clients) at Mono.Nat.NatUtility.SearchAndListen() 2014-03-13 19:32:46.4722 Debug - App: Searching for: PmpSearcher 2014-03-13 19:32:46.4822 Error - App: Error reported by Mono.Nat: An existing connection was forcibly closed by the remote host System.Net.Sockets.SocketException at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at Mono.Nat.NatUtility.Receive(ISearcher searcher, List`1 clients) at Mono.Nat.NatUtility.SearchAndListen() 2014-03-13 19:32:58.6119 Info - App: HttpClientManager GET: http://bot.whatismyipaddress.com/ 2014-03-13 19:33:02.4812 Debug - App: Searching for: PmpSearcher 2014-03-13 19:33:57.5173 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/moviesrecommended.html 2014-03-13 19:33:57.5583 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 41.0023 ms Url: http://localhost:8096/mediabrowser/dashboard/moviesrecommended.html 2014-03-13 19:33:57.6483 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/System/Info 2014-03-13 19:33:57.7048 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie&Filters=IsResumable&Limit=3&Recursive=true&Fields=DateCreated%2CUserData 2014-03-13 19:33:57.7048 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie&Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CDateCreated%2CUserData&Filters=IsUnplayed 2014-03-13 19:33:57.7048 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Trailer&Limit=6&Recursive=true&Fields=PrimaryImageAspectRatio%2CDateCreated%2CUserData&Filters=IsUnplayed 2014-03-13 19:33:57.7343 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 29.5037 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie&Filters=IsResumable&Limit=3&Recursive=true&Fields=DateCreated%2CUserData 2014-03-13 19:33:57.7368 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 32.004 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie&Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CDateCreated%2CUserData&Filters=IsUnplayed 2014-03-13 19:33:57.7368 Debug - HttpServer: HTTP Response 200 to [::1]:59935. Response time: 28.5036 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Trailer&Limit=6&Recursive=true&Fields=PrimaryImageAspectRatio%2CDateCreated%2CUserData&Filters=IsUnplayed 2014-03-13 19:33:57.7368 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 98.512 ms Url: http://localhost:8096/mediabrowser/System/Info 2014-03-13 19:33:58.8684 Info - App: Client connected from 127.0.0.1:59937 2014-03-13 19:33:59.3694 Debug - SessionWebSocketListener: Received Identity message: Dashboard|1ed105bc7765665627b084b425ea52b641c1f30d|3.0.5171.19958|Chrome 33.0.1750.146 2014-03-13 19:33:59.8144 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?sortBy=SortName 2014-03-13 19:33:59.8144 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/Counts?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:33:59.8334 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 19.0011 ms Url: http://localhost:8096/mediabrowser/Items/Counts?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:33:59.8784 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=random&IncludeItemTypes=Movie%2CTrailer&Limit=6&ImageTypes=Primary&Recursive=true 2014-03-13 19:33:59.8784 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=random&IncludeItemTypes=MusicAlbum&Limit=6&ImageTypes=Primary&Recursive=true 2014-03-13 19:34:00.8455 Debug - HttpServer: HTTP Response 200 to [::1]:59935. Response time: 1030.0604 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?sortBy=SortName 2014-03-13 19:34:00.8455 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 967.0554 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=random&IncludeItemTypes=MusicAlbum&Limit=6&ImageTypes=Primary&Recursive=true 2014-03-13 19:34:00.8455 Debug - HttpServer: HTTP Response 200 to [::1]:59916. Response time: 973.0557 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=random&IncludeItemTypes=Movie%2CTrailer&Limit=6&ImageTypes=Primary&Recursive=true 2014-03-13 19:34:00.9065 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/eb44ad0792485810f143e8b6abb78907/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=07d12cc77b02d278a1bcd3b82452a0ce 2014-03-13 19:34:00.9065 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/18b7f1ac24b960ea57195fff3d4b3b8d/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=0d18d2f4cd8c6c747b2f7c2a884ecf82 2014-03-13 19:34:00.9065 Debug - HttpServer: HTTP Response 304 to [::1]:59916. Response time: 9.0006 ms Url: http://localhost:8096/mediabrowser/Items/eb44ad0792485810f143e8b6abb78907/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=07d12cc77b02d278a1bcd3b82452a0ce 2014-03-13 19:34:00.9065 Debug - HttpServer: HTTP Response 304 to [::1]:59915. Response time: 8.0004 ms Url: http://localhost:8096/mediabrowser/Items/18b7f1ac24b960ea57195fff3d4b3b8d/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=0d18d2f4cd8c6c747b2f7c2a884ecf82 2014-03-13 19:34:00.9195 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/a49fbc759d743a78d3f231ffa3dc6259/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=c4da67aac2491ba00f6c10635b05aa7a 2014-03-13 19:34:00.9195 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/4e9c83bdfa967848d9db26f78c8dcf6f/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=5d5b56588b5d28218968b2396f4d3d3e 2014-03-13 19:34:00.9195 Debug - HttpServer: HTTP Response 304 to [::1]:59917. Response time: 2.0001 ms Url: http://localhost:8096/mediabrowser/Items/4e9c83bdfa967848d9db26f78c8dcf6f/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=5d5b56588b5d28218968b2396f4d3d3e 2014-03-13 19:34:00.9385 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/445ebb3581ae3af49441fa7925192941/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=5b020f1928f817a4e537c10f0e6f61fe 2014-03-13 19:34:00.9385 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/da86c68fc2ac552b58b011419ddfaa1b/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=6ddb2c445f9283ce2d4e190d11385cba 2014-03-13 19:34:00.9385 Debug - HttpServer: HTTP Response 304 to [::1]:59939. Response time: 3.0002 ms Url: http://localhost:8096/mediabrowser/Items/da86c68fc2ac552b58b011419ddfaa1b/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=6ddb2c445f9283ce2d4e190d11385cba 2014-03-13 19:34:00.9385 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/bdcc95da51f417ef5f7a337ec9231b2a/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=19a1dfc47b9116b5e245d16a060fa6e3 2014-03-13 19:34:00.9385 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/449343d17390189e759e2d2b6f83f6e0/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=7c9c6aef8774bc96fad73f8d9a945291 2014-03-13 19:34:01.0105 Debug - HttpServer: HTTP Response 200 to [::1]:59935. Response time: 92.0068 ms Url: http://localhost:8096/mediabrowser/Items/a49fbc759d743a78d3f231ffa3dc6259/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=c4da67aac2491ba00f6c10635b05aa7a 2014-03-13 19:34:01.0115 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 67.0053 ms Url: http://localhost:8096/mediabrowser/Items/449343d17390189e759e2d2b6f83f6e0/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=7c9c6aef8774bc96fad73f8d9a945291 2014-03-13 19:34:01.0115 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 76.0058 ms Url: http://localhost:8096/mediabrowser/Items/445ebb3581ae3af49441fa7925192941/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=5b020f1928f817a4e537c10f0e6f61fe 2014-03-13 19:34:01.0275 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 81.0061 ms Url: http://localhost:8096/mediabrowser/Items/bdcc95da51f417ef5f7a337ec9231b2a/Images/Primary/0?width=160&EnableImageEnhancers=false&tag=19a1dfc47b9116b5e245d16a060fa6e3 2014-03-13 19:34:02.1816 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/itemlist.html?parentId=b17e17a284ce1d78a25aee67508ed8b1 2014-03-13 19:34:02.1816 Warn - StringMapTypeDeserializer: Property 'parentid' does not exist on type 'MediaBrowser.WebDashboard.Api.GetDashboardResource' 2014-03-13 19:34:02.1816 Debug - HttpServer: HTTP Response 304 to [::1]:59917. Response time: 2.0001 ms Url: http://localhost:8096/mediabrowser/dashboard/itemlist.html?parentId=b17e17a284ce1d78a25aee67508ed8b1 2014-03-13 19:34:02.3356 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=SortName&SortOrder=Ascending&Fields=DateCreated&StartIndex=0&Limit=500&ParentId=b17e17a284ce1d78a25aee67508ed8b1&Filters=&NameStartsWithOrGreater= 2014-03-13 19:34:02.3356 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/b17e17a284ce1d78a25aee67508ed8b1 2014-03-13 19:34:02.3376 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 6.0004 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?SortBy=SortName&SortOrder=Ascending&Fields=DateCreated&StartIndex=0&Limit=500&ParentId=b17e17a284ce1d78a25aee67508ed8b1&Filters=&NameStartsWithOrGreater= 2014-03-13 19:34:02.3696 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 34.002 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/b17e17a284ce1d78a25aee67508ed8b1 2014-03-13 19:34:04.9617 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/itemdetails.html?id=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:04.9617 Warn - StringMapTypeDeserializer: Property 'id' does not exist on type 'MediaBrowser.WebDashboard.Api.GetDashboardResource' 2014-03-13 19:34:04.9617 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 7.0004 ms Url: http://localhost:8096/mediabrowser/dashboard/itemdetails.html?id=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:05.0958 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:05.0998 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 4.0003 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:05.1488 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?ParentId=f2e1ea0e080d2fc0bfce4124662a9eb3&Fields=ItemCounts%2CDateCreated%2CAudioInfo%2CPrimaryImageAspectRatio 2014-03-13 19:34:05.1488 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ThemeSongs?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:05.1488 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 5.5004 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?ParentId=f2e1ea0e080d2fc0bfce4124662a9eb3&Fields=ItemCounts%2CDateCreated%2CAudioInfo%2CPrimaryImageAspectRatio 2014-03-13 19:34:05.1488 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ThemeVideos?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:05.1628 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 6.5008 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ThemeVideos?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:05.1628 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 11.0012 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ThemeSongs?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:05.1888 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/449343d17390189e759e2d2b6f83f6e0/Images/Primary?height=400&width=267&tag=7c9c6aef8774bc96fad73f8d9a945291 2014-03-13 19:34:05.1998 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/bdcc95da51f417ef5f7a337ec9231b2a/Images/Primary?height=400&width=267&tag=19a1dfc47b9116b5e245d16a060fa6e3 2014-03-13 19:34:05.2918 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 104.006 ms Url: http://localhost:8096/mediabrowser/Items/449343d17390189e759e2d2b6f83f6e0/Images/Primary?height=400&width=267&tag=7c9c6aef8774bc96fad73f8d9a945291 2014-03-13 19:34:05.3038 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 103.0059 ms Url: http://localhost:8096/mediabrowser/Items/bdcc95da51f417ef5f7a337ec9231b2a/Images/Primary?height=400&width=267&tag=19a1dfc47b9116b5e245d16a060fa6e3 2014-03-13 19:34:06.5598 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/edititemmetadata.html?id=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:06.5598 Warn - StringMapTypeDeserializer: Property 'id' does not exist on type 'MediaBrowser.WebDashboard.Api.GetDashboardResource' 2014-03-13 19:34:06.5688 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 9.0005 ms Url: http://localhost:8096/mediabrowser/dashboard/edititemmetadata.html?id=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:06.7558 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Ancestors?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:06.7558 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 7.0004 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Ancestors?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:06.7758 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/cultures 2014-03-13 19:34:06.7758 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/countries 2014-03-13 19:34:06.7919 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:06.7919 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 4.0002 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:06.8184 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 42.004 ms Url: http://localhost:8096/mediabrowser/Localization/cultures 2014-03-13 19:34:06.8369 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 61.0064 ms Url: http://localhost:8096/mediabrowser/Localization/countries 2014-03-13 19:34:06.8709 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ExternalIdInfos 2014-03-13 19:34:06.8779 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 7.0004 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ExternalIdInfos 2014-03-13 19:34:06.9059 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-03-13 19:34:06.9109 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 5.0003 ms Url: http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-03-13 19:34:07.0039 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Library/MediaFolders 2014-03-13 19:34:07.0039 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 4.0003 ms Url: http://localhost:8096/mediabrowser/Library/MediaFolders 2014-03-13 19:34:07.0039 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/LiveTv/Info? 2014-03-13 19:34:07.0479 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 36.0021 ms Url: http://localhost:8096/mediabrowser/LiveTv/Info? 2014-03-13 19:34:07.1149 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?ParentId=b17e17a284ce1d78a25aee67508ed8b1&Fields=Settings&SortBy=SortName 2014-03-13 19:34:07.1149 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 1.0001 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?ParentId=b17e17a284ce1d78a25aee67508ed8b1&Fields=Settings&SortBy=SortName 2014-03-13 19:34:08.8210 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Refresh?forced=true&recursive=true 2014-03-13 19:34:08.8360 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:34:08.8360 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:34:08.8630 Debug - App: Running MovieDbBoxSetProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:08.9175 Debug - App: Running BoxSetXmlProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:08.9610 Debug - App: Running CADummyImageProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:08.9610 Debug - App: CoverArt providing base image for Friday Collection 2014-03-13 19:34:08.9850 Debug - App: Running MovieDbBoxSetImageProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:09.0040 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/configuration?api_key=f6bd687ffa63cd282b6ff2c6877f2669 2014-03-13 19:34:09.2490 Debug - App: Running FanartMovieImageProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:09.2490 Debug - ProviderManager: Saving \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] to Media Browser Xml. 2014-03-13 19:34:09.2660 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.2660 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.2660 Debug - App: Saving \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] to database. 2014-03-13 19:34:09.2660 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Friday (1995) - Shortcut.mblink 2014-03-13 19:34:09.2660 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.2660 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.2800 Debug - BaseItem: Found shortcut at \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Next Friday (2000) - Shortcut.mblink 2014-03-13 19:34:09.2800 Debug - App: Running MovieDbBoxSetProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:09.2800 Debug - App: Running BoxSetXmlProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:09.2980 Debug - App: Running CADummyImageProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:09.2980 Debug - App: Running MovieDbBoxSetImageProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:09.2980 Debug - App: Running FanartMovieImageProvider for \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:09.2980 Debug - ProviderManager: Saving \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] to Media Browser Xml. 2014-03-13 19:34:09.3120 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.3120 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.3120 Debug - App: Saving \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] to database. 2014-03-13 19:34:09.3120 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.3120 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\collection.xml 2014-03-13 19:34:09.3120 Debug - HttpServer: HTTP Response 204 to [::1]:59917. Response time: 496.0319 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Refresh?forced=true&recursive=true 2014-03-13 19:34:09.3410 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:09.3460 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 5.0003 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:09.3800 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ExternalIdInfos 2014-03-13 19:34:09.3800 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 2.0001 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/ExternalIdInfos 2014-03-13 19:34:09.3800 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-03-13 19:34:09.3800 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 1 ms Url: http://localhost:8096/mediabrowser/Localization/ParentalRatings 2014-03-13 19:34:11.7381 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/dashboard/edititemimages.html?id=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:11.7381 Warn - StringMapTypeDeserializer: Property 'id' does not exist on type 'MediaBrowser.WebDashboard.Api.GetDashboardResource' 2014-03-13 19:34:11.7551 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 17.001 ms Url: http://localhost:8096/mediabrowser/dashboard/edititemimages.html?id=f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:11.8131 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Ancestors?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:11.8131 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 3.0002 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Ancestors?userId=365d013f78a04595a1a987728290730d 2014-03-13 19:34:11.8451 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:11.8451 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 3.0001 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:12.0192 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages/Providers? 2014-03-13 19:34:12.0262 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Library/MediaFolders 2014-03-13 19:34:12.0262 Debug - HttpServer: HTTP Response 200 to [::1]:59915. Response time: 3.0002 ms Url: http://localhost:8096/mediabrowser/Library/MediaFolders 2014-03-13 19:34:12.0262 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/LiveTv/Info? 2014-03-13 19:34:12.0262 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 11.0006 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages/Providers? 2014-03-13 19:34:12.0262 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 1.0001 ms Url: http://localhost:8096/mediabrowser/LiveTv/Info? 2014-03-13 19:34:12.0452 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images 2014-03-13 19:34:12.0452 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?ParentId=b17e17a284ce1d78a25aee67508ed8b1&Fields=Settings&SortBy=SortName 2014-03-13 19:34:12.0452 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 3.0001 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items?ParentId=b17e17a284ce1d78a25aee67508ed8b1&Fields=Settings&SortBy=SortName 2014-03-13 19:34:12.0612 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 16.0009 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images 2014-03-13 19:34:12.0862 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images/Primary?maxheight=216&tag=569661d2f8db53201b7c6197f9566f8c 2014-03-13 19:34:12.0912 Debug - CoverArt: CoverArt will treat C:\Users\Ryan\AppData\Roaming\MediaBrowser-Server\plugins\CoverArt\DummyImageCache\f2e1ea0e-080d-2fc0-bfce-4124662a9eb3-folder.jpg 2014-03-13 19:34:12.1102 Warn - CoverArt: CoverArt is expired. Please register it via the Plugin Catalog. 2014-03-13 19:34:12.1352 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 49.0028 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images/Primary?maxheight=216&tag=569661d2f8db53201b7c6197f9566f8c 2014-03-13 19:34:13.3002 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages?type=Primary&startIndex=0&limit=10&IncludeAllLanguages=false 2014-03-13 19:34:13.3192 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 20.0011 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages?type=Primary&startIndex=0&limit=10&IncludeAllLanguages=false 2014-03-13 19:34:13.3872 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Images/Remote?imageUrl=http:%2F%2Fimage.tmdb.org%2Ft%2Fp%2Foriginal%2FuhNS10HAQ2Sj1IXbLabXGnGLnT6.jpg 2014-03-13 19:34:13.3872 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Images/Remote?imageUrl=http:%2F%2Fimage.tmdb.org%2Ft%2Fp%2Foriginal%2Fzg8KBtzWO6GoEMPOMIRFVmXeSsP.jpg 2014-03-13 19:34:13.3872 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/uhNS10HAQ2Sj1IXbLabXGnGLnT6.jpg 2014-03-13 19:34:13.3982 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/zg8KBtzWO6GoEMPOMIRFVmXeSsP.jpg 2014-03-13 19:34:13.7683 Debug - HttpServer: HTTP Response 200 to [::1]:59917. Response time: 372.0213 ms Url: http://localhost:8096/mediabrowser/Images/Remote?imageUrl=http:%2F%2Fimage.tmdb.org%2Ft%2Fp%2Foriginal%2Fzg8KBtzWO6GoEMPOMIRFVmXeSsP.jpg 2014-03-13 19:34:13.9513 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 565.0323 ms Url: http://localhost:8096/mediabrowser/Images/Remote?imageUrl=http:%2F%2Fimage.tmdb.org%2Ft%2Fp%2Foriginal%2FuhNS10HAQ2Sj1IXbLabXGnGLnT6.jpg 2014-03-13 19:34:17.3075 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages/Download?Type=Primary&ImageUrl=http:%2F%2Fimage.tmdb.org%2Ft%2Fp%2Foriginal%2Fzg8KBtzWO6GoEMPOMIRFVmXeSsP.jpg&ProviderName=TheMovieDb 2014-03-13 19:34:17.3155 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/zg8KBtzWO6GoEMPOMIRFVmXeSsP.jpg 2014-03-13 19:34:17.4985 Debug - ProviderManager: Saving image to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Watcher sees change of type Created to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.5015 Debug - App: Saving \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] to database. 2014-03-13 19:34:17.5015 Debug - HttpServer: HTTP Response 204 to [::1]:59938. Response time: 204.0117 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages/Download?Type=Primary&ImageUrl=http:%2F%2Fimage.tmdb.org%2Ft%2Fp%2Foriginal%2Fzg8KBtzWO6GoEMPOMIRFVmXeSsP.jpg&ProviderName=TheMovieDb 2014-03-13 19:34:17.5215 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:17.5465 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 25.0014 ms Url: http://localhost:8096/mediabrowser/Users/365d013f78a04595a1a987728290730d/Items/f2e1ea0e080d2fc0bfce4124662a9eb3 2014-03-13 19:34:17.5905 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages/Providers? 2014-03-13 19:34:17.5905 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 1.5002 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/RemoteImages/Providers? 2014-03-13 19:34:17.6150 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images 2014-03-13 19:34:17.6150 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 6.5009 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images 2014-03-13 19:34:17.6520 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images/Primary?maxheight=216&tag=0327fa89ec882e9b922cb35d0382c009 2014-03-13 19:34:17.6895 Debug - CoverArt: CoverArt will treat \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\poster.jpg 2014-03-13 19:34:17.6895 Warn - CoverArt: CoverArt is expired. Please register it via the Plugin Catalog. 2014-03-13 19:34:17.8585 Debug - HttpServer: HTTP Response 200 to [::1]:59938. Response time: 206.5188 ms Url: http://localhost:8096/mediabrowser/Items/f2e1ea0e080d2fc0bfce4124662a9eb3/Images/Primary?maxheight=216&tag=0327fa89ec882e9b922cb35d0382c009 2014-03-13 19:34:18.4355 Debug - LibraryMonitor: Watcher sees change of type Created to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Thumbs.db 2014-03-13 19:34:18.4355 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:18.4375 Debug - LibraryMonitor: Ignoring change to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563] 2014-03-13 19:34:18.4375 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Thumbs.db 2014-03-13 19:34:18.4375 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Thumbs.db 2014-03-13 19:34:18.4375 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Thumbs.db 2014-03-13 19:34:18.4375 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Thumbs.db 2014-03-13 19:34:18.4595 Debug - LibraryMonitor: Watcher sees change of type Changed to \\RYAN-PC\Videos\Auto Box Sets\MB Auto Set [Boxset][tmdbid=43563]\Thumbs.db
ebr 16344 Posted March 13, 2014 Posted March 13, 2014 It looks like the fetchers don't go get images for the auto sets anymore. But, as I said, this will all be changing so we'll get it working then. As an aside, you should either uninstall or register CoverArt as it is just taking up memory and processing cycles right now.
mbc0 68 Posted March 14, 2014 Posted March 14, 2014 Hi, I am a new user to mediabrowser and have installed this plugin but cannot see what it is supposed to do? When I go to collections in the mediabrowser should I see something? it is a blank screen tons of folders have been downloaded to the specified directory with MBLINK files in them but I can't see what is supposed to happen?
ebr 16344 Posted March 14, 2014 Posted March 14, 2014 As I said, the implementation of this is going to change but did you add the folder with all of those auto sets in it to your Media Library?
mbc0 68 Posted March 14, 2014 Posted March 14, 2014 As I said, the implementation of this is going to change but did you add the folder with all of those auto sets in it to your Media Library? Hi, I am sorry but I haven't added the folder I pictured into the library, what do I add them as? what folder type? Thanks
ebr 16344 Posted March 14, 2014 Posted March 14, 2014 You can add it to any existing media folder or create a new one of type "Collections".
mbc0 68 Posted March 14, 2014 Posted March 14, 2014 You can add it to any existing media folder or create a new one of type "Collections". Ah, I see and tell it that the folder type is movies yes?
ebr 16344 Posted March 14, 2014 Posted March 14, 2014 No, "Collections"... But Movies would probably work too.
mbc0 68 Posted March 15, 2014 Posted March 15, 2014 No, "Collections"... But Movies would probably work too. Changed it to collections & it is now working! :-D Many Thanks For Your Time ;-)
