BloodyIron 24 Posted January 16, 2018 Posted January 16, 2018 So I just upgraded from mono to .net core, and I noticed the box art plugin, figured I'd give it a try, maybe get some laughs. Turns out, I'm not digging the box art style, I like the classic/original style more. So I removed the plugin, but the box art is still there. What's the best way to redo all the artwork for all the media I have? I'd really rather not reset all my meta data, as I'm not sure if that'll also nuke my play history. Any ideas?
Luke 42204 Posted January 16, 2018 Posted January 16, 2018 Sounds like this is coming from CoverArt and not AutoBoxSets. 1
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 Ooops, cover art is what I meant to say. Yeah, how do I undo that jazz?
Luke 42204 Posted January 16, 2018 Posted January 16, 2018 Either uninstall the Cover Art plugin, or go into Cover Art setting and disable the treatment for BoxSets. 1
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 I did uninstall the Cover Art plugin though, didn't seem to change anything Either uninstall the Cover Art plugin, or go into Cover Art setting and disable the treatment for BoxSets.
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 Probably, but... what do you want me to post a screenshot of? the lack of the plugin, or... uhhh. the artwork still looking like blu-rays or wtvr? Can you show a screenshot? thanks.
Luke 42204 Posted January 16, 2018 Posted January 16, 2018 Whatever it is that you're not satisfied with, thanks. 1
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 Movies be doing this: http://i.imgur.com/hvEccpU.png But I liked the artwork without the blu-ray and other boxy style stuff (classssiiiccccc). I don't mind having it rescan for artwork, I'm just not sure which method is the best way to go with my current predicament. Also, really cool I'm getting your help this late. thx d00d
Luke 42204 Posted January 16, 2018 Posted January 16, 2018 That's the CoverArt plugin, can you attach an emby server log? I'm guessing you didn't actually uninstall it. 1
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 I'll PM you a link to the log, gimme a few mins That's the CoverArt plugin, can you attach an emby server log? I'm guessing you didn't actually uninstall it.
Luke 42204 Posted January 16, 2018 Posted January 16, 2018 before you do that, head over to the plugins section, make sure the plugin is uninstalled, and then restart the server. thanks. 1
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 Plugins section: http://i.imgur.com/BWZAnPM.png Now I'm going to restart the server, then snag logs for you (I'll include a few of them as I don't recall when I removed the plugin, a day or so ago?)
Solution BloodyIron 24 Posted January 16, 2018 Author Solution Posted January 16, 2018 Okay.... maybe the restart is all it took... now I'm not seeing the "blu-ray" style box arts on the movies. Argh, I could swear I restarted after that... I'm going to verify this some more. 1
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 Yeah looks like the cover art stuff is gone. Sorry dude! My bad
BloodyIron 24 Posted January 16, 2018 Author Posted January 16, 2018 Thanks for putting up with my crap! Thanks for the feedback.
