gene0915 42 Posted January 15, 2018 Posted January 15, 2018 When I was running Windows, I followed a pretty detailed guide to get zap2xml (for free TV guide data) working. Now that I've switched to Linux (Mint), I'm having trouble finding a good guide. Yes, I've seen a guide or two out there but it was hard to follow for me. And since I might be switching to Antergos (Arch based) on my server down the road, I was wondering if anyone knew of a really detailed guide that a Linux newbie could follow that covers how to get zap2xml working under Debian based distros as well as Arch? Thanks
tdiguy 99 Posted January 16, 2018 Posted January 16, 2018 (edited) When I was running Windows, I followed a pretty detailed guide to get zap2xml (for free TV guide data) working. Now that I've switched to Linux (Mint), I'm having trouble finding a good guide. Yes, I've seen a guide or two out there but it was hard to follow for me. And since I might be switching to Antergos (Arch based) on my server down the road, I was wondering if anyone knew of a really detailed guide that a Linux newbie could follow that covers how to get zap2xml working under Debian based distros as well as Arch? Thanks If you find one let me know. I have not found much information past using the --help in the file. here is what i use though maybe it will help you. sudo ./zap2xml.pl -u *** -p *** -N 2 -i test -a -d 14 the test after -i is the directory you want to store the icons for the channels. I also have the -N 2 so that the first 2 days of downloaded data is not cached i figure this helps to ensure today and tomorrows guide data is as up to date as possible. I dont know how often emby refreshes its schedule for recordings but i imagine its at least daily so i figure this helps ensure the episode and season information populates. Also if you have not downloaded the script in a month or so its worth going back and downloading it, there have been some major changes. Edited January 16, 2018 by tdiguy
