jimmer 1 Posted March 13, 2014 Posted March 13, 2014 I've installed MBT on 2 htpc's- one a while ago the other yesterday the new install would crash whenever I tried to play movie (MBT gui quit unexpectedly ....) I supected the lav filters didn't install properly and downloaded the latest from video help version .61 now movie plays audio but video does 2 second endless replay the new system is 32 bit old 64 bit both on MBT .25066 old lav .59.1 should I try to find the old lav filters and install on new build? is there a config setting I need to change from the default lav install for MBT? there doesn't appear to be a way to adjust from w/in MBT
saitoh183 137 Posted March 13, 2014 Posted March 13, 2014 MBT usually downloads Lav 60.1 you should try Lav 61.0 that came out a few days ago... thats what i use and it works great
jimmer 1 Posted March 13, 2014 Author Posted March 13, 2014 thanks for the suggestion tried that but it din't work played awhile and discovered that if i switch auto hardware acceleration off it remedied the problem working well now
