CatSama 1 Posted January 15, 2018 Posted January 15, 2018 (edited) I used the mono version, tested this issue on 3.2.60.0 and 3.2.60.15. For example, I have a picture looks like this But when I put it on my Emby library, it displayed just like this, the picture displayed darker than original. (It's a screenshot,so it's not my monitor's problem) I downloaded this picture by use the button, and it displayed right in my computer. the .NTE core version doesn't have this issue ,but as I said, .NET core version doesn't support animated GIFs, so I will not use it for now. This is the picture file 2.zip, you can use it to test this issus. _____________________________________________________________________________________________________________________ And I have posted a topic to report a problem that Emby doesn't use the first picture of a folder as it's thumbnail. https://emby.media/community/index.php?/topic/54380-%E3%80%90need-help%E3%80%91how-emby-auto-generate-a-thumbnail-for-folder-in-a-picture-library/&do=findComment&comment=526204 Now I found some folder use the first picture as it's thumbnail on 3.2.60.15, but there is still some folder use the wrong picture as it's thumbnail, so this problem is not completely fixed. Please check it ,thanks. Edited January 15, 2018 by CatSama
Luke 42245 Posted January 15, 2018 Posted January 15, 2018 The mono version is using older components. I'm not really sure, sorry.
CatSama 1 Posted January 15, 2018 Author Posted January 15, 2018 (edited) The mono version is using older components. I'm not really sure, sorry. So is this issue repairable? will you fix this? @@Luke Edited January 15, 2018 by CatSama
Luke 42245 Posted January 15, 2018 Posted January 15, 2018 We are not doing any new development on the mono packages.
