nyplayer 90 Posted January 14, 2018 Posted January 14, 2018 Is there a way to set padding when you record a show on the Android TV app .. I set to record football games from the guide but I could not find a way to set 1 hour padding I had to do it from the web interface on my pc.
mastrmind11 722 Posted January 14, 2018 Posted January 14, 2018 Is there a way to set padding when you record a show on the Android TV app .. I set to record football games from the guide but I could not find a way to set 1 hour padding I had to do it from the web interface on my pc. Web interface as of now, across all user recordings. Put in the FR section since it makes sense.
ebr 16337 Posted January 15, 2018 Posted January 15, 2018 You can do this from the Android TV app for series recordings right now but not one-offs.
nyplayer 90 Posted January 15, 2018 Author Posted January 15, 2018 You can do this from the Android TV app for series recordings right now but not one-offs. Thanks ... hope it can be added in the future .... I appreciate your teams support and response to issues.
