e123enitan 276 Posted January 13, 2018 Posted January 13, 2018 @Angelblue, I just noticed play issue with the latest addon, follow type of video files where a single file broken down into series was playing nicely in ver 2.3.61 has stopped in the latest version. Appreciate U taken care of this issue swifly e:\Movies 1\Lucy (2014) Lucy (2014)A.mkvLucy (2014)B.mkv Cheers!
sualfred 677 Posted January 13, 2018 Posted January 13, 2018 Do you use addon or native path playback? Is there any difference if you start the movie from a widget or from a library node? Please also provide a log.
e123enitan 276 Posted January 13, 2018 Author Posted January 13, 2018 (edited) Do you use addon or native path playback? Is there any difference if you start the movie from a widget or from a library node? Please also provide a log. Using addon play back, playback is STILL working fine on 2.3.61 which on window laptop, but libreelec I did upate to the latest and it stopped playing. full log link https://paste.ubuntu.com/26379816/ 13:45:35.597 T:545101721824 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.AttributeError'>Error Contents: 'PlaybackUtils' object has no attribute 'setArtwork'Traceback (most recent call last):File "/storage/.kodi/addons/plugin.video.emby.movies/default.py", line 50, in <module>entrypoint.doPlayback(itemid, dbid)File "/storage/.kodi/addons/plugin.video.emby/resources/lib/entrypoint.py", line 49, in doPlaybackpbutils.PlaybackUtils(item).play(itemId, dbId)File "/storage/.kodi/addons/plugin.video.emby/resources/lib/playbackutils.py", line 77, in playself.set_playlist(play_url, item_id, listitem, seektime, dbid)File "/storage/.kodi/addons/plugin.video.emby/resources/lib/playbackutils.py", line 127, in set_playlistself._set_additional_parts(item_id)File "/storage/.kodi/addons/plugin.video.emby/resources/lib/playbackutils.py", line 166, in _set_additional_partspb.setArtwork(listitem)AttributeError: 'PlaybackUtils' object has no attribute 'setArtwork'-->End of Python script error report<-- Edited January 13, 2018 by e123enitan
sualfred 677 Posted January 13, 2018 Posted January 13, 2018 Thanks. @@Angelblue05 Sorry, nothing I can assist you with
e123enitan 276 Posted January 13, 2018 Author Posted January 13, 2018 Thanks. @@Angelblue05 Sorry, nothing I can assist you with Now worries, we've similar issue in the past and was fixed by Angelblue05. Thanks anyway for your time.
Angelblue05 4132 Posted January 13, 2018 Posted January 13, 2018 Thanks for providing your log. I'll fix it and post a new build. 2
e123enitan 276 Posted January 13, 2018 Author Posted January 13, 2018 (edited) Thanks for providing your log. I'll fix it and post a new build. Any ETA, not trying to push, but like to know when so I can test Thanks Edited January 13, 2018 by e123enitan
Angelblue05 4132 Posted January 13, 2018 Posted January 13, 2018 (edited) It's on the way. Should be there within the next 10 min or so. Edit: It should be there now Edited January 13, 2018 by Angelblue05 2
e123enitan 276 Posted January 13, 2018 Author Posted January 13, 2018 It's on the way. Should be there within the next 10 min or so. Edit: It should be there now Do I need to rescaned library coz it wont play the update
Angelblue05 4132 Posted January 14, 2018 Posted January 14, 2018 (edited) Ah crap, nvm. I didn't fully correct the issue. Give me a sec. Edited January 14, 2018 by Angelblue05
e123enitan 276 Posted January 14, 2018 Author Posted January 14, 2018 Do I need to rescaned library coz it wont play the update Just reset DB I shall keep you informed after DB scan.
Angelblue05 4132 Posted January 14, 2018 Posted January 14, 2018 (edited) No!! Don't reset?! Reset has nothing to do with playback. I just forgot we added the media type to artwork and that's why it still wasn't working. Here, try this build. Confirm it works thank you. plugin.video.emby-3.0.4a.zip Edited January 14, 2018 by Angelblue05
e123enitan 276 Posted January 14, 2018 Author Posted January 14, 2018 No!! Don't reset?! Reset has nothing to do with playback. I just forgot we added the media type to artwork and that's why it still wasn't working. Here, try this build. Confirm it works thank you. ok we'll keep U posted
e123enitan 276 Posted January 14, 2018 Author Posted January 14, 2018 Thanks everything is working nicely. 1
Angelblue05 4132 Posted January 14, 2018 Posted January 14, 2018 Thank you for confirming I'll post a build soon, report back any other issues. I really appreciate it. 1
e123enitan 276 Posted January 14, 2018 Author Posted January 14, 2018 https://paste.ubuntu.com/26382035/ There several logs errors in the attached, play back is taken quite a time to respond, it spins for a while before it connect to server and start palying something is definitely wrong, before the last update it was snappy very quick I mean. let me know if you need more testing done
Angelblue05 4132 Posted January 14, 2018 Posted January 14, 2018 Give this build a try. Thank you. plugin.video.emby-3.0.4a.zip
e123enitan 276 Posted January 14, 2018 Author Posted January 14, 2018 (edited) Give this build a try. Thank you. New log same issue, while working to resolve isssue, is there a way to have 2.3.61 addon, i have another box that I can use to testing. Thanks https://paste.ubuntu.com/26382297/ Edited January 14, 2018 by e123enitan
Angelblue05 4132 Posted January 14, 2018 Posted January 14, 2018 stable is always available in the stable repo. Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted January 14, 2018 Posted January 14, 2018 What's the issue now? Please include that with your new log. I don't see errors.
e123enitan 276 Posted January 14, 2018 Author Posted January 14, 2018 https://paste.ubuntu.com/26382340/ The issue is instead of playing right away, it spins for a while before movie started playing, NOTICE: EMBY.kodimonitor -> Method: VideoLibrary.OnScanFinished Data: null 22:21:31.956 T:548246438112 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://192.168.1.104:8096/emby/Items/d983f0e897835d28697193be914656ec/Images/Primary/0?MaxWidth=10000&MaxHeight=10000&Format=original&Tag=43dc95898002279b3974a966177f38a5 22:21:31.959 T:547432165600 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.emby.tvshows/821d2feeeaef4daf4c27bd93e72d3ae6/?dbid=15260&mode=play&id=d983f0e897835d28697193be914656ec&filename=The.Affair.S02E12.Webrip.1080p.10bit.5.1.x265.HEVC-Qman%5BUTR%5D.mkv 22:21:31.959 T:547432165600 ERROR: Open - failed to open source <plugin://plugin.video.emby.tvshows/821d2feeeaef4daf4c27bd93e72d3ae6/?dbid=15260&mode=play&id=d983f0e897835d28697193be914656ec&filename=The.Affair.S02E12.Webrip.1080p.10bit.5.1.x265.HEVC-Qman%5BUTR%5D.mkv> 22:21:31.959 T:547432165600 ERROR: InputStream: Error opening, plugin://plugin.video.emby.tvshows/821d2feeeaef4daf4c27bd93e72d3ae6/?dbid=15260&mode=play&id=d983f0e897835d28697193be914656ec&filename=The.Affair.S02E12.Webrip.1080p.10bit.5.1.x265.HEVC-Qman%5BUTR%5D.mkv 22:21:31.972 T:548246438112 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://192.168.1.104:8096/emby/Items/e0ba3ceb9bf42036bc030cd933347846/Images/Primary/0?MaxWidth=10000&MaxHeight=10000&Format=original&Tag=3978187d4d0e8430fa04eadc6394177e 22:21:31.975 T:547557994720 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.emby.tvshows/821d2feeeaef4daf4c27bd93e72d3ae6/?dbid=15256&mode=play&id=e0ba3ceb9bf42036bc030cd933347846&filename=The.Affair.S02E11.Webrip.1080p.10bit.5.1.x265.HEVC-Qman%5BUTR%5D.mkv 22:21:31.975 T:547557994720 ERROR: Open - failed to open source <plugin://plugin.video.emby.tvshows/821d2feeeaef4daf4c27bd93e72d3ae6/?dbid=15256&mode=play&id=e0ba3ceb9bf42036bc030cd933347846&filename=The.Affair.S02E11.Webrip.1080p.10bit.5.1.x265.HEVC-Qman%5BUTR%5D.mkv> 22:21:31.975 T:547557994720 ERROR: InputStream: Error opening, plugin://plugin.video.emby.tvshows/821d2feeeaef4daf4c27bd93e72d3ae6/?dbid=15256&mode=play&id=e0ba3ceb9bf42036bc030cd933347846&filename=The.Affair.S02E11.Webrip.1080p.10bit.5.1.x265.HEVC-Qman%5BUTR%5D.mkv 22:22:01.585 T:545396297952 NOTICE: EMBY.default_movies -> Parameter string: ?dbid=35&mode=play&id=984cd85e76f1b40788237fc51fd58d67&filename=3+Headed+Shark+Attack+%282015%29.mp4 22:22:02.410 T:545396297952 NOTICE: EMBY.playbackutils -> Play called: 3-Headed Shark Attack 22:22:02.987 T:545396297952 NOTICE: EMBY.playutils -> Mediasources: [{u'SupportsDirectStream': True, u'Container': u'mov', u'RequiresClosing': False, u'IgnoreDts': False, u'IgnoreIndex': False, u'DefaultAudioStreamIndex': 1, u'SupportsDirectPlay': True, u'MediaStreams': [{u'IsInterlaced': False, u'Index': 0, u'AverageFrameRate': 23.976024599999999, u'Width': 1920, u'Codec': u'h264', u'IsForced': False, u'AspectRatio': u'16:9', u'Type': u'Video', u'IsTextSubtitleStream': False, u'Profile': u'High', u'DisplayTitle': u'1080P H264', u'Language': u'und', u'NalLengthSize': u'4', u'CodecTimeBase': u'1001/48000', u'RealFrameRate': 23.976024599999999, u'CodecTag': u'avc1', u'Level': 41, u'RefFrames': 1, u'TimeBase': u'1/24000', u'BitRate': 1906671, u'IsDefault': True, u'IsAnamorphic': False, u'SupportsExternalStream': False, u'Height': 1080, u'IsAVC': True, u'PixelFormat': u'yuv420p', u'BitDepth': 8, u'IsExternal': False}, {u'Profile': u'LC', u'IsInterlaced': False, u'DisplayTitle': u'Eng AAC stereo Default', u'CodecTag': u'mp4a', u'Language': u'eng', u'Index': 1, u'Type': u'Audio', u'IsForced': False, u'Level': 0, u'Channels': 2, u'Codec': u'aac', u'ChannelLayout': u'stereo', u'SupportsExternalStream': False, u'CodecTimeBase': u'1/48000', u'IsAnamorphic': False, u'TimeBase': u'1/48000', u'SampleRate': 48000, u'BitRate': 93898, u'IsTextSubtitleStream': False, u'IsDefault': True, u'IsExternal': False}, {u'IsAnamorphic': True, u'IsInterlaced': False, u'DisplayTitle': u'Eng', u'IsExternalUrl': False, u'Language': u'eng', u'Index': 2, u'DeliveryUrl': u'/Videos/984cd85e76f1b40788237fc51fd58d67/984cd85e76f1b40788237fc51fd58d67/Subtitles/2/0/Stream.srt?api_key=bc17f1d28d67441eac8a2914fddf9233', u'SupportsExternalStream': True, u'DeliveryMethod': u'External', u'Codec': u'srt', u'IsForced': False, u'Path': u'\\\\192.168.1.102\\Public2\\2Movies\\3 Headed Shark Attack (2015)\\3 Headed Shark Attack (2015).eng.srt', u'Type': u'Subtitle', u'IsTextSubtitleStream': True, u'IsDefault': False, u'IsExternal': True}], u'Type': u'Default', u'ReadAtNativeFramerate': False, u'RequiresLooping': False, u'Path': u'\\\\192.168.1.102\\Public2\\2Movies\\3 Headed Shark Attack (2015)\\3 Headed Shark Attack (2015).mp4', u'RequiresOpening': False, u'Bitrate': 2004624, u'IsRemote': False, u'Name': u'3 Headed Shark Attack (2015).mp4', u'RequiredHttpHeaders': {}, u'SupportsTranscoding': False, u'Formats': [], u'Protocol': u'File', u'IsInfiniteStream': False, u'GenPtsInput': False, u'VideoType': u'VideoFile', u'ETag': u'1c5da97adcb63fc3d92d7c32a19d6f61', u'RunTimeTicks': 53377921024, u'SupportsProbing': True, u'Id': u'984cd85e76f1b40788237fc51fd58d67', u'DefaultSubtitleStreamIndex': 2}] 22:22:03.553 T:545396297952 NOTICE: EMBY.playutils -> playback info: {u'SupportsDirectStream': True, u'Container': u'mov', u'RequiresClosing': False, u'IgnoreDts': False, u'IgnoreIndex': False, u'DefaultAudioStreamIndex': 1, u'SupportsDirectPlay': True, u'MediaStreams': [{u'IsInterlaced': False, u'Index': 0, u'AverageFrameRate': 23.976024599999999, u'Width': 1920, u'Codec': u'h264', u'IsForced': False, u'AspectRatio': u'16:9', u'Type': u'Video', u'IsTextSubtitleStream': False, u'Profile': u'High', u'DisplayTitle': u'1080P H264', u'Language': u'und', u'NalLengthSize': u'4', u'CodecTimeBase': u'1001/48000', u'RealFrameRate': 23.976024599999999, u'CodecTag': u'avc1', u'Level': 41, u'RefFrames': 1, u'TimeBase': u'1/24000', u'BitRate': 1906671, u'IsDefault': True, u'IsAnamorphic': False, u'SupportsExternalStream': False, u'Height': 1080, u'IsAVC': True, u'PixelFormat': u'yuv420p', u'BitDepth': 8, u'IsExternal': False}, {u'Profile': u'LC', u'IsInterlaced': False, u'DisplayTitle': u'Eng AAC stereo Default', u'CodecTag': u'mp4a', u'Language': u'eng', u'Index': 1, u'Type': u'Audio', u'IsForced': False, u'Level': 0, u'Channels': 2, u'Codec': u'aac', u'ChannelLayout': u'stereo', u'SupportsExternalStream': False, u'CodecTimeBase': u'1/48000', u'IsAnamorphic': False, u'TimeBase': u'1/48000', u'SampleRate': 48000, u'BitRate': 93898, u'IsTextSubtitleStream': False, u'IsDefault': True, u'IsExternal': False}, {u'IsAnamorphic': True, u'IsInterlaced': False, u'DisplayTitle': u'Eng', u'IsExternalUrl': False, u'Language': u'eng', u'Index': 2, u'DeliveryUrl': u'/Videos/984cd85e76f1b40788237fc51fd58d67/984cd85e76f1b40788237fc51fd58d67/Subtitles/2/0/Stream.srt?api_key=bc17f1d28d67441eac8a2914fddf9233', u'SupportsExternalStream': True, u'DeliveryMethod': u'External', u'Codec': u'srt', u'IsForced': False, u'Path': u'\\\\192.168.1.102\\Public2\\2Movies\\3 Headed Shark Attack (2015)\\3 Headed Shark Attack (2015).eng.srt', u'Type': u'Subtitle', u'IsTextSubtitleStream': True, u'IsDefault': False, u'IsExternal': True}], u'Type': u'Default', u'ReadAtNativeFramerate': False, u'RequiresLooping': False, u'Path': u'http://192.168.1.104:8096/emby/Videos/984cd85e76f1b40788237fc51fd58d67/stream?static=true&api_key=bc17f1d28d67441eac8a2914fddf9233', u'RequiresOpening': False, u'Bitrate': 2004624, u'IsRemote': False, u'Name': u'3 Headed Shark Attack (2015).mp4', u'RequiredHttpHeaders': {}, u'SupportsTranscoding': False, u'Formats': [], u'Protocol': u'File', u'IsInfiniteStream': False, u'GenPtsInput': False, u'VideoType': u'VideoFile', u'ETag': u'1c5da97adcb63fc3d92d7c32a19d6f61', u'RunTimeTicks': 53377921024, u'SupportsProbing': True, u'Id': u'984cd85e76f1b40788237fc51fd58d67', u'DefaultSubtitleStreamIndex': 2} 22:22:03.568 T:545396297952 NOTICE: EMBY.playutils -> play method: DirectStream play url: http://192.168.1.104:8096/emby/Videos/984cd85e76f1b40788237fc51fd58d67/stream?static=true&api_key=bc17f1d28d67441eac8a2914fddf9233 22:22:03.943 T:548263227392 NOTICE: VideoPlayer: Opening: http://192.168.1.104:8096/emby/Videos/984cd85e76f1b40788237fc51fd58d67/stream?static=true&api_key=bc17f1d28d67441eac8a2914fddf9233 22:22:03.944 T:548263227392 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 22:22:03.948 T:545462653152 NOTICE:
Angelblue05 4132 Posted January 14, 2018 Posted January 14, 2018 (edited) Disable append external subtitles in the add-on settings > playback. Maybe that's what's making it take longer. Edited January 14, 2018 by Angelblue05
e123enitan 276 Posted January 15, 2018 Author Posted January 15, 2018 Disable append external subtitles in the add-on settings > playback. Maybe that's what's making it take longer. Makes no diff, I shall rebuild my box and do fresh install will keep you posted
Angelblue05 4132 Posted January 15, 2018 Posted January 15, 2018 (edited) Ok and from where are you starting playback?You are a little trigger happy when it comes to rebuilding heh... I rebuilt the entire playback process for add-on playback mode. If anything it should start faster because I removed workarounds. Anyway, keep me posted, I highly doubt it will be fixed that way but I guess you never know.Sent from my iPhone using Tapatalk Edited January 16, 2018 by Angelblue05
e123enitan 276 Posted January 16, 2018 Author Posted January 16, 2018 with Version: 3.0.4a ALL MY Current known issues are solved, ie staking file and slow play, and no more errors in my log, If I spotted any issue I shall keep you posted. Thanks 1
