strugglez 8 Posted January 29, 2018 Author Posted January 29, 2018 I tried downloading it this morning but it gave me a connection error. I will try again when I get home from work.
strugglez 8 Posted January 30, 2018 Author Posted January 30, 2018 Hey guys, Managed to update it. Doesn't seemed to of fixed it. Anything else I can provide? Logs from the TV?
strugglez 8 Posted January 30, 2018 Author Posted January 30, 2018 (edited) I actually think the changes have made it worse. Here's the server ffmpeg log: 2018-01-30 17:35:43.766Application version: 3.2.70.0http://192.168.1.5:8096/emby/Videos/4a024e45217e9bd46cf664a6cff10fcf/Stream.ts?VideoStreamIndex=0&AudioStreamIndex=1&VideoCodec=h264&Profile=high&Level=41&MaxVideoBitDepth=8&MaxWidth=1920&VideoBitrate=511922&AudioCodec=aac&AudioBitrate=360000&MaxAudioChannels=6&MediaSourceId=4a024e45217e9bd46cf664a6cff10fcf&api_key=48e3fc51489c46d58e23a0a3a4b1b6f1&DeviceId=SHCJEJIYFUKVY&StartTimeTicks=0{"Protocol":"File","Id":"4a024e45217e9bd46cf664a6cff10fcf","Path":"F:\\TV Series\\Dragon Ball\\Season 1\\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","Type":"Default","Container":"mkv,webm","Name":"Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","IsRemote":false,"ETag":"bdacb6ae3d5bd508f1d0b28ba9d496d3","RunTimeTicks":14524779520,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"hevc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","DisplayTitle":"720P HEVC","IsInterlaced":false,"BitRate":511922,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1612,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main 10","Type":"Video","AspectRatio":"403:270","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"aac","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng AAC 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":320000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"HE-AAC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":511922,"RequiredHttpHeaders":{}}User policy for Administrator: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: TrueC:\Users\Administrator\AppData\Roaming\Emby-Server\system\ffmpeg.exe -f matroska,webm -i file:"F:\TV Series\Dragon Ball\Season 1\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 511922 -bufsize 1023844 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -y "C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata\transcoding-temp\a5ed8a00a385b98cfaac44c11c984faf.ts"ffmpeg version git-2017-12-31-2906363 Copyright © 2000-2017 the FFmpeg developersbuilt with gcc 7.2.0 (GCC)configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-amf --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfxlibavutil 56. 7.100 / 56. 7.100libavcodec 58. 9.100 / 58. 9.100libavformat 58. 3.100 / 58. 3.100libavdevice 58. 0.100 / 58. 0.100libavfilter 7. 8.100 / 7. 8.100libswscale 5. 0.101 / 5. 0.101libswresample 3. 0.101 / 3. 0.101libpostproc 55. 0.100 / 55. 0.100Input #0, matroska,webm, from 'file:F:\TV Series\Dragon Ball\Season 1\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv':Metadata:encoder : libebml v1.3.3 + libmatroska v1.4.4creation_time : 2016-04-29T23:07:22.000000ZDuration: 00:24:12.48, start: 0.000000, bitrate: 511 kb/sChapter #0:0: start 0.000000, end 110.143000Metadata:title : Chapter 01Chapter #0:1: start 110.143000, end 150.316000Metadata:title : Chapter 02Chapter #0:2: start 150.316000, end 723.756000Metadata:title : Chapter 03Chapter #0:3: start 723.756000, end 1354.353000Metadata:title : Chapter 04Chapter #0:4: start 1354.353000, end 1452.478000Metadata:title : Chapter 05Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1612x1080, SAR 1:1 DAR 403:270, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)Metadata:BPS : 446083BPS-eng : 446083DURATION : 00:24:12.451000000DURATION-eng : 00:24:12.451000000NUMBER_OF_FRAMES: 34824NUMBER_OF_FRAMES-eng: 34824NUMBER_OF_BYTES : 80989302NUMBER_OF_BYTES-eng: 80989302_STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-04-29 23:07:22_STATISTICS_WRITING_DATE_UTC-eng: 2016-04-29 23:07:22_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream #0:1(eng): Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)Metadata:BPS : 63999BPS-eng : 63999DURATION : 00:24:12.459000000DURATION-eng : 00:24:12.459000000NUMBER_OF_FRAMES: 34042NUMBER_OF_FRAMES-eng: 34042NUMBER_OF_BYTES : 11619670NUMBER_OF_BYTES-eng: 11619670_STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-04-29 23:07:22_STATISTICS_WRITING_DATE_UTC-eng: 2016-04-29 23:07:22_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream mapping:Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264))Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for help[libx264 @ 000001bf70e95c80] using SAR=1/1[libx264 @ 000001bf70e95c80] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX[libx264 @ 000001bf70e95c80] profile Main, level 4.1Output #0, mpegts, to 'C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata\transcoding-temp\a5ed8a00a385b98cfaac44c11c984faf.ts':Metadata:encoder : Lavf58.3.100Stream #0:0: Video: h264 (libx264), yuv420p, 1612x1080 [sAR 1:1 DAR 403:270], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default)Metadata:encoder : Lavc58.9.100 libx264Side data:cpb: bitrate max/min/avg: 511000/0/0 buffer size: 1023000 vbv_delay: -1Stream #0:1: Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)frame= 37 fps=0.0 q=17.0 size= 4kB time=00:00:02.02 bitrate= 14.9kbits/s speed=4.04xframe= 94 fps= 94 q=36.0 size= 215kB time=00:00:04.45 bitrate= 395.7kbits/s speed=4.45xframe= 167 fps=111 q=37.0 size= 256kB time=00:00:07.44 bitrate= 281.8kbits/s speed=4.94xframe= 242 fps=121 q=30.0 size= 512kB time=00:00:10.81 bitrate= 387.9kbits/s speed=5.38xframe= 320 fps=128 q=34.0 size= 768kB time=00:00:13.88 bitrate= 453.1kbits/s speed=5.54xframe= 395 fps=131 q=39.0 size= 1024kB time=00:00:16.87 bitrate= 497.2kbits/s speed= 5.6xframe= 467 fps=133 q=40.0 size= 1280kB time=00:00:20.07 bitrate= 522.4kbits/s speed=5.71xframe= 535 fps=133 q=44.0 size= 1536kB time=00:00:22.88 bitrate= 549.8kbits/s speed= 5.7xframe= 598 fps=132 q=36.0 size= 1792kB time=00:00:25.49 bitrate= 575.9kbits/s speed=5.64xframe= 657 fps=131 q=37.0 size= 2048kB time=00:00:27.87 bitrate= 601.8kbits/s speed=5.55xframe= 724 fps=131 q=31.0 size= 2048kB time=00:00:30.86 bitrate= 543.6kbits/s speed=5.59xframe= 789 fps=131 q=44.0 size= 2304kB time=00:00:33.34 bitrate= 566.1kbits/s speed=5.53xframe= 851 fps=130 q=48.0 size= 2560kB time=00:00:35.90 bitrate= 584.1kbits/s speed= 5.5xframe= 917 fps=130 q=54.0 size= 2816kB time=00:00:38.63 bitrate= 597.2kbits/s speed=5.49xframe= 979 fps=130 q=54.0 size= 3072kB time=00:00:41.40 bitrate= 607.8kbits/s speed=5.49xframe= 1046 fps=130 q=38.0 size= 3328kB time=00:00:44.22 bitrate= 616.5kbits/s speed= 5.5xframe= 1111 fps=130 q=45.0 size= 3584kB time=00:00:46.90 bitrate= 625.9kbits/s speed=5.49xframe= 1174 fps=130 q=52.0 size= 3584kB time=00:00:49.63 bitrate= 591.5kbits/s speed=5.49xframe= 1241 fps=130 q=29.0 size= 3840kB time=00:00:52.19 bitrate= 602.6kbits/s speed=5.47xframe= 1307 fps=130 q=32.0 size= 4096kB time=00:00:54.93 bitrate= 610.9kbits/s speed=5.46xframe= 1373 fps=130 q=54.0 size= 4352kB time=00:00:57.66 bitrate= 618.3kbits/s speed=5.46xframe= 1434 fps=130 q=58.0 size= 4608kB time=00:01:00.43 bitrate= 624.6kbits/s speed=5.46xframe= 1502 fps=130 q=45.0 size= 4608kB time=00:01:03.03 bitrate= 598.8kbits/s speed=5.45xframe= 1569 fps=130 q=41.0 size= 4864kB time=00:01:05.98 bitrate= 603.9kbits/s speed=5.46xframe= 1646 fps=131 q=35.0 size= 5120kB time=00:01:09.22 bitrate= 605.9kbits/s speed= 5.5xframe= 1719 fps=131 q=45.0 size= 5376kB time=00:01:12.29 bitrate= 609.2kbits/s speed=5.53xframe= 1781 fps=131 q=52.0 size= 5632kB time=00:01:14.81 bitrate= 616.7kbits/s speed=5.51xframe= 1845 fps=131 q=44.0 size= 5888kB time=00:01:17.54 bitrate= 622.0kbits/s speed=5.51xframe= 1914 fps=131 q=38.0 size= 6144kB time=00:01:20.27 bitrate= 627.0kbits/s speed= 5.5xframe= 1986 fps=132 q=27.0 size= 6400kB time=00:01:23.30 bitrate= 629.4kbits/s speed=5.52xframe= 2061 fps=132 q=43.0 size= 6656kB time=00:01:26.37 bitrate= 631.3kbits/s speed=5.54xframe= 2123 fps=132 q=49.0 size= 6912kB time=00:01:29.10 bitrate= 635.5kbits/s speed=5.54xframe= 2184 fps=132 q=51.0 size= 6912kB time=00:01:31.66 bitrate= 617.7kbits/s speed=5.52xframe= 2245 fps=131 q=63.0 size= 7168kB time=00:01:34.14 bitrate= 623.7kbits/s speed=5.51xframe= 2312 fps=131 q=29.0 size= 7424kB time=00:01:37.21 bitrate= 625.6kbits/s speed=5.52xframe= 2377 fps=131 q=36.0 size= 7680kB time=00:01:39.81 bitrate= 630.3kbits/s speed=5.51xframe= 2444 fps=131 q=35.0 size= 7936kB time=00:01:42.54 bitrate= 634.0kbits/s speed=5.51xframe= 2507 fps=131 q=46.0 size= 7936kB time=00:01:44.97 bitrate= 619.3kbits/s speed=5.49xframe= 2587 fps=132 q=27.0 size= 8192kB time=00:01:48.56 bitrate= 618.2kbits/s speed=5.53xframe= 2661 fps=132 q=42.0 size= 8448kB time=00:01:51.50 bitrate= 620.6kbits/s speed=5.54xframe= 2727 fps=132 q=32.0 size= 8704kB time=00:01:54.19 bitrate= 624.4kbits/s speed=5.54xframe= 2791 fps=132 q=28.0 size= 8960kB time=00:01:56.84 bitrate= 628.2kbits/s speed=5.53xframe= 2858 fps=132 q=32.0 size= 9216kB time=00:01:59.86 bitrate= 629.8kbits/s speed=5.54xframe= 2930 fps=132 q=36.0 size= 9472kB time=00:02:02.89 bitrate= 631.4kbits/s speed=5.55xframe= 3002 fps=133 q=29.0 size= 9728kB time=00:02:05.84 bitrate= 633.3kbits/s speed=5.56xframe= 3073 fps=133 q=43.0 size= 9984kB time=00:02:08.57 bitrate= 636.1kbits/s speed=5.56xframe= 3148 fps=133 q=38.0 size= 10240kB time=00:02:11.98 bitrate= 635.6kbits/s speed=5.58xframe= 3226 fps=134 q=32.0 size= 10496kB time=00:02:15.14 bitrate= 636.2kbits/s speed= 5.6xframe= 3306 fps=134 q=34.0 size= 10752kB time=00:02:18.42 bitrate= 636.3kbits/s speed=5.61xframe= 3384 fps=134 q=34.0 size= 11008kB time=00:02:21.62 bitrate= 636.7kbits/s speed=5.63xframe= 3464 fps=135 q=26.0 size= 11264kB time=00:02:24.95 bitrate= 636.6kbits/s speed=5.65xframe= 3537 fps=135 q=22.0 size= 11520kB time=00:02:28.02 bitrate= 637.5kbits/s speed=5.66xframe= 3590 fps=135 q=14.0 size= 11520kB time=00:02:30.24 bitrate= 628.1kbits/s speed=5.63xframe= 3641 fps=134 q=34.0 size= 11776kB time=00:02:32.63 bitrate= 632.0kbits/s speed=5.62xframe= 3701 fps=134 q=33.0 size= 12032kB time=00:02:35.02 bitrate= 635.8kbits/s speed= 5.6xframe= 3766 fps=134 q=37.0 size= 12288kB time=00:02:37.71 bitrate= 638.3kbits/s speed= 5.6xframe= 3840 fps=134 q=31.0 size= 12544kB time=00:02:40.61 bitrate= 639.8kbits/s speed= 5.6xframe= 3915 fps=134 q=28.0 size= 12800kB time=00:02:43.73 bitrate= 640.4kbits/s speed=5.61xframe= 3981 fps=134 q=40.0 size= 13056kB time=00:02:46.71 bitrate= 641.5kbits/s speed=5.61xframe= 4044 fps=134 q=32.0 size= 13056kB time=00:02:49.14 bitrate= 632.3kbits/s speed= 5.6xframe= 4111 fps=134 q=35.0 size= 13312kB time=00:02:51.96 bitrate= 634.2kbits/s speed= 5.6xframe= 4170 fps=134 q=34.0 size= 13568kB time=00:02:54.48 bitrate= 637.0kbits/s speed=5.59xframe= 4233 fps=134 q=44.0 size= 13824kB time=00:02:57.08 bitrate= 639.5kbits/s speed=5.59xframe= 4299 fps=133 q=40.0 size= 14080kB time=00:02:59.73 bitrate= 641.8kbits/s speed=5.58xframe= 4362 fps=133 q=43.0 size= 14080kB time=00:03:02.54 bitrate= 631.9kbits/s speed=5.58xframe= 4417 fps=133 q=53.0 size= 14336kB time=00:03:04.59 bitrate= 636.2kbits/s speed=5.56xframe= 4483 fps=133 q=38.0 size= 14592kB time=00:03:07.36 bitrate= 638.0kbits/s speed=5.56xframe= 4546 fps=133 q=38.0 size= 14848kB time=00:03:10.31 bitrate= 639.1kbits/s speed=5.56xframe= 4608 fps=133 q=48.0 size= 15104kB time=00:03:12.91 bitrate= 641.4kbits/s speed=5.55xframe= 4678 fps=133 q=28.0 size= 15104kB time=00:03:15.64 bitrate= 632.4kbits/s speed=5.55xframe= 4739 fps=133 q=34.0 size= 15360kB time=00:03:18.24 bitrate= 634.7kbits/s speed=5.55xframe= 4802 fps=132 q=36.0 size= 15616kB time=00:03:20.89 bitrate= 636.8kbits/s speed=5.54xframe= 4871 fps=133 q=37.0 size= 15872kB time=00:03:23.62 bitrate= 638.5kbits/s speed=5.54xframe= 4939 fps=133 q=44.0 size= 16128kB time=00:03:26.56 bitrate= 639.6kbits/s speed=5.55xframe= 5012 fps=133 q=29.0 size= 16384kB time=00:03:29.63 bitrate= 640.2kbits/s speed=5.55xframe= 5088 fps=133 q=29.0 size= 16640kB time=00:03:32.92 bitrate= 640.2kbits/s speed=5.57xframe= 5162 fps=133 q=31.0 size= 16896kB time=00:03:35.91 bitrate= 641.1kbits/s speed=5.57xframe= 5217 fps=133 q=46.0 size= 16896kB time=00:03:38.00 bitrate= 634.9kbits/s speed=5.55xframe= 5273 fps=133 q=59.0 size= 17152kB time=00:03:40.43 bitrate= 637.4kbits/s speed=5.54xframe= 5341 fps=133 q=37.0 size= 17408kB time=00:03:43.37 bitrate= 638.4kbits/s speed=5.55xframe= 5401 fps=132 q=42.0 size= 17664kB time=00:03:45.72 bitrate= 641.1kbits/s speed=5.54xframe= 5466 fps=132 q=39.0 size= 17920kB time=00:03:48.54 bitrate= 642.3kbits/s speed=5.54xframe= 5508 fps=132 q=51.0 size= 17920kB time=00:03:50.12 bitrate= 637.9kbits/s speed=5.49xframe= 5582 fps=132 q=30.0 size= 18176kB time=00:03:53.49 bitrate= 637.7kbits/s speed=5.51xframe= 5648 fps=132 q=49.0 size= 18432kB time=00:03:56.09 bitrate= 639.6kbits/s speed= 5.5xframe= 5723 fps=132 q=32.0 size= 18688kB time=00:03:59.16 bitrate= 640.1kbits/s speed=5.51xframe= 5796 fps=132 q=36.0 size= 18944kB time=00:04:02.15 bitrate= 640.9kbits/s speed=5.52xframe= 5870 fps=132 q=28.0 size= 19200kB time=00:04:05.22 bitrate= 641.4kbits/s speed=5.52xframe= 5947 fps=132 q=34.0 size= 19456kB time=00:04:08.46 bitrate= 641.5kbits/s speed=5.53xframe= 6020 fps=133 q=42.0 size= 19712kB time=00:04:11.45 bitrate= 642.2kbits/s speed=5.54xframe= 6082 fps=132 q=32.0 size= 19968kB time=00:04:14.18 bitrate= 643.5kbits/s speed=5.54xframe= 6151 fps=132 q=33.0 size= 20224kB time=00:04:17.17 bitrate= 644.2kbits/s speed=5.54xframe= 6218 fps=132 q=38.0 size= 20224kB time=00:04:20.02 bitrate= 637.1kbits/s speed=5.54xframe= 6287 fps=133 q=37.0 size= 20480kB time=00:04:22.75 bitrate= 638.5kbits/s speed=5.54xframe= 6358 fps=133 q=35.0 size= 20736kB time=00:04:25.70 bitrate= 639.3kbits/s speed=5.54xframe= 6412 fps=132 q=40.0 size= 20992kB time=00:04:28.00 bitrate= 641.6kbits/s speed=5.53xframe= 6480 fps=132 q=36.0 size= 21248kB time=00:04:30.73 bitrate= 642.9kbits/s speed=5.53xframe= 6555 fps=133 q=33.0 size= 21504kB time=00:04:34.02 bitrate= 642.9kbits/s speed=5.54xframe= 6624 fps=133 q=28.0 size= 21760kB time=00:04:36.75 bitrate= 644.1kbits/s speed=5.54xframe= 6701 fps=133 q=35.0 size= 22016kB time=00:04:40.03 bitrate= 644.0kbits/s speed=5.55xframe= 6776 fps=133 q=31.0 size= 22272kB time=00:04:43.11 bitrate= 644.5kbits/s speed=5.55xframe= 6847 fps=133 q=36.0 size= 22528kB time=00:04:46.09 bitrate= 645.1kbits/s speed=5.56xframe= 6922 fps=133 q=33.0 size= 22784kB time=00:04:49.08 bitrate= 645.6kbits/s speed=5.56xframe= 6993 fps=133 q=31.0 size= 22784kB time=00:04:52.28 bitrate= 638.6kbits/s speed=5.57xframe= 7071 fps=133 q=24.0 size= 23040kB time=00:04:55.35 bitrate= 639.0kbits/s speed=5.57xframe= 7149 fps=134 q=23.0 size= 23296kB time=00:04:58.59 bitrate= 639.1kbits/s speed=5.58xframe= 7226 fps=134 q=26.0 size= 23552kB time=00:05:01.97 bitrate= 638.9kbits/s speed=5.59xframe= 7302 fps=134 q=28.0 size= 23808kB time=00:05:04.95 bitrate= 639.5kbits/s speed= 5.6xframe= 7378 fps=134 q=32.0 size= 24064kB time=00:05:08.32 bitrate= 639.4kbits/s speed=5.61xframe= 7452 fps=134 q=37.0 size= 24320kB time=00:05:11.27 bitrate= 640.1kbits/s speed=5.61xframe= 7527 fps=134 q=30.0 size= 24576kB time=00:05:14.34 bitrate= 640.5kbits/s speed=5.61xframe= 7601 fps=135 q=36.0 size= 24832kB time=00:05:17.45 bitrate= 640.8kbits/s speed=5.62xframe= 7670 fps=135 q=36.0 size= 25088kB time=00:05:20.35 bitrate= 641.5kbits/s speed=5.62xframe= 7739 fps=135 q=42.0 size= 25344kB time=00:05:23.34 bitrate= 642.1kbits/s speed=5.62xframe= 7793 fps=134 q=57.0 size= 25600kB time=00:05:25.56 bitrate= 644.2kbits/s speed=5.61xframe= 7851 fps=134 q=53.0 size= 25600kB time=00:05:27.86 bitrate= 639.6kbits/s speed= 5.6xframe= 7910 fps=134 q=40.0 size= 25856kB time=00:05:30.59 bitrate= 640.7kbits/s speed= 5.6xframe= 7977 fps=134 q=26.0 size= 26112kB time=00:05:33.41 bitrate= 641.6kbits/s speed= 5.6xframe= 8046 fps=134 q=37.0 size= 26368kB time=00:05:36.06 bitrate= 642.8kbits/s speed= 5.6xframe= 8117 fps=134 q=38.0 size= 26624kB time=00:05:39.26 bitrate= 642.9kbits/s speed= 5.6xframe= 8192 fps=134 q=34.0 size= 26880kB time=00:05:42.20 bitrate= 643.5kbits/s speed=5.61xframe= 8262 fps=134 q=34.0 size= 27136kB time=00:05:45.19 bitrate= 644.0kbits/s speed=5.61xframe= 8329 fps=134 q=37.0 size= 27392kB time=00:05:47.75 bitrate= 645.3kbits/s speed=5.61xframe= 8393 fps=134 q=34.0 size= 27392kB time=00:05:50.52 bitrate= 640.2kbits/s speed= 5.6xframe= 8452 fps=134 q=62.0 size= 27648kB time=00:05:52.95 bitrate= 641.7kbits/s speed= 5.6xframe= 8515 fps=134 q=43.0 size= 27904kB time=00:05:55.56 bitrate= 642.9kbits/s speed=5.59xframe= 8576 fps=134 q=34.0 size= 28160kB time=00:05:58.07 bitrate= 644.2kbits/s speed=5.59xframe= 8631 fps=134 q=67.0 size= 28416kB time=00:06:00.33 bitrate= 646.0kbits/s speed=5.58xframe= 8684 fps=133 q=56.0 size= 28416kB time=00:06:02.64 bitrate= 641.9kbits/s speed=5.57xframe= 8744 fps=133 q=49.0 size= 28672kB time=00:06:05.28 bitrate= 643.0kbits/s speed=5.57xframe= 8807 fps=133 q=60.0 size= 28928kB time=00:06:07.67 bitrate= 644.5kbits/s speed=5.56xframe= 8862 fps=133 q=48.0 size= 28928kB time=00:06:10.15 bitrate= 640.2kbits/s speed=5.56xframe= 8918 fps=133 q=59.0 size= 29184kB time=00:06:12.54 bitrate= 641.7kbits/s speed=5.55xframe= 8991 fps=133 q=26.0 size= 29440kB time=00:06:15.48 bitrate= 642.3kbits/s speed=5.55xframe= 9059 fps=133 q=36.0 size= 29696kB time=00:06:18.34 bitrate= 643.0kbits/s speed=5.55xframe= 9124 fps=133 q=43.0 size= 29952kB time=00:06:21.07 bitrate= 643.9kbits/s speed=5.55xframe= 9195 fps=133 q=32.0 size= 30208kB time=00:06:24.01 bitrate= 644.4kbits/s speed=5.55xframe= 9264 fps=133 q=35.0 size= 30464kB time=00:06:27.09 bitrate= 644.7kbits/s speed=5.56xframe= 9333 fps=133 q=28.0 size= 30720kB time=00:06:29.69 bitrate= 645.8kbits/s speed=5.56xframe= 9406 fps=133 q=33.0 size= 30976kB time=00:06:32.76 bitrate= 646.1kbits/s speed=5.56xframe= 9478 fps=133 q=28.0 size= 30976kB time=00:06:35.75 bitrate= 641.2kbits/s speed=5.56xframe= 9547 fps=133 q=40.0 size= 31232kB time=00:06:38.78 bitrate= 641.6kbits/s speed=5.57xframe= 9621 fps=133 q=25.0 size= 31488kB time=00:06:41.93 bitrate= 641.8kbits/s speed=5.57xframe= 9692 fps=133 q=30.0 size= 31744kB time=00:06:44.71 bitrate= 642.5kbits/s speed=5.57xframe= 9763 fps=133 q=32.0 size= 32000kB time=00:06:47.65 bitrate= 643.1kbits/s speed=5.57xframe= 9827 fps=133 q=39.0 size= 32256kB time=00:06:50.30 bitrate= 644.0kbits/s speed=5.57xframe= 9887 fps=133 q=46.0 size= 32512kB time=00:06:53.03 bitrate= 644.8kbits/s speed=5.57xframe= 9947 fps=133 q=44.0 size= 32768kB time=00:06:55.42 bitrate= 646.2kbits/s speed=5.56xframe=10005 fps=133 q=48.0 size= 32768kB time=00:06:57.81 bitrate= 642.5kbits/s speed=5.56xframe=10057 fps=133 q=59.0 size= 33024kB time=00:06:59.90 bitrate= 644.3kbits/s speed=5.55xframe=10118 fps=133 q=42.0 size= 33280kB time=00:07:02.67 bitrate= 645.0kbits/s speed=5.55xframe=10182 fps=133 q=35.0 size= 33536kB time=00:07:05.31 bitrate= 645.9kbits/s speed=5.55xframe=10246 fps=133 q=42.0 size= 33536kB time=00:07:07.92 bitrate= 642.0kbits/s speed=5.54xframe=10315 fps=133 q=30.0 size= 33792kB time=00:07:10.82 bitrate= 642.5kbits/s speed=5.54xframe=10378 fps=133 q=40.0 size= 34048kB time=00:07:13.25 bitrate= 643.8kbits/s speed=5.54xframe=10443 fps=133 q=44.0 size= 34304kB time=00:07:15.98 bitrate= 644.6kbits/s speed=5.54xframe=10511 fps=133 q=28.0 size= 34560kB time=00:07:18.88 bitrate= 645.1kbits/s speed=5.54xframe=10567 fps=133 q=56.0 size= 34816kB time=00:07:21.31 bitrate= 646.3kbits/s speed=5.54xframe=10619 fps=132 q=47.0 size= 34816kB time=00:07:23.41 bitrate= 643.2kbits/s speed=5.53xframe=10675 fps=132 q=57.0 size= 35072kB time=00:07:25.75 bitrate= 644.5kbits/s speed=5.52xframe=10729 fps=132 q=51.0 size= 35328kB time=00:07:28.14 bitrate= 645.8kbits/s speed=5.52xframe=10803 fps=132 q=45.0 size= 35584kB time=00:07:31.13 bitrate= 646.2kbits/s speed=5.52xframe=10880 fps=132 q=35.0 size= 35840kB time=00:07:34.41 bitrate= 646.1kbits/s speed=5.53xframe=10942 fps=132 q=37.0 size= 35840kB time=00:07:36.89 bitrate= 642.6kbits/s speed=5.52xframe=11014 fps=132 q=33.0 size= 36096kB time=00:07:39.96 bitrate= 642.9kbits/s speed=5.53xframe=11087 fps=132 q=30.0 size= 36352kB time=00:07:43.03 bitrate= 643.1kbits/s speed=5.53xframe=11149 fps=132 q=42.0 size= 36608kB time=00:07:45.51 bitrate= 644.2kbits/s speed=5.53xframe=11215 fps=132 q=37.0 size= 36864kB time=00:07:48.32 bitrate= 644.8kbits/s speed=5.53xframe=11273 fps=132 q=41.0 size= 37120kB time=00:07:50.84 bitrate= 645.8kbits/s speed=5.52xframe=11331 fps=132 q=38.0 size= 37120kB time=00:07:53.19 bitrate= 642.6kbits/s speed=5.52xframe=11391 fps=132 q=42.0 size= 37376kB time=00:07:55.62 bitrate= 643.8kbits/s speed=5.51xframe=11460 fps=132 q=31.0 size= 37632kB time=00:07:58.35 bitrate= 644.5kbits/s speed=5.51xframe=11526 fps=132 q=39.0 size= 37888kB time=00:08:01.38 bitrate= 644.8kbits/s speed=5.52xframe=11593 fps=132 q=36.0 size= 38144kB time=00:08:03.90 bitrate= 645.7kbits/s speed=5.51xframe=11658 fps=132 q=26.0 size= 38400kB time=00:08:06.84 bitrate= 646.1kbits/s speed=5.51x I will try get a photo of the TV logs, but it doesn't provide too much in comparison. Edited January 30, 2018 by strugglez
Luke 42239 Posted January 30, 2018 Posted January 30, 2018 Yea it's still requesting a very low bitrate, so that's the reason why it doesn't look good. So that needs to be looked at but I'm guessing @@SamES may have been concerned about potential side effects and didn't want to touch that. We'll see what he thinks. Thanks.
strugglez 8 Posted January 30, 2018 Author Posted January 30, 2018 Maybe I could pause it on emby then on plex to give a comparison, and then even send you guys the file to see if you guys can replicate it and see what I mean.
SamES 1084 Posted January 30, 2018 Posted January 30, 2018 (edited) I actually think the changes have made it worse. Here's the server ffmpeg log: I will try get a photo of the TV logs, but it doesn't provide too much in comparison. Yes, I can imagine it is worse now with higher width resolution but limited to same bitrate. Actually, the bitrate of the original file is quite low, and the app requests the same bit rate. I'm not entirely sure why. {"Protocol":"File","Id":"4a024e45217e9bd46cf664a6cff10fcf","Path":"F:\\TV Series\\Dragon Ball\\Season 1\\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","Type":"Default","Container":"mkv,webm","Name":"Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","IsRemote":false,"ETag":"bdacb6ae3d5bd508f1d0b28ba9d496d3","RunTimeTicks":14524779520,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"hevc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","DisplayTitle":"720P HEVC","IsInterlaced":false,"BitRate":511922,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1612,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main 10","Type":"Video","AspectRatio":"403:270","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"aac","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng AAC 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":320000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"HE-AAC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":511922,"RequiredHttpHeaders":{}} @@Luke, in the theatre app, am I correct to presume that MaxBitrate request is based only on the user setting and the detected network speed. In that case, the bitrate of the original file would not be considered. Correct? Edited January 30, 2018 by SamES
SamES 1084 Posted January 30, 2018 Posted January 30, 2018 @@strugglez, I've given Luke another version with the file bitrate limitation removed. Now it is limited only be the user setting for this app. When he uploads it, can you please test it and send another ffmpeg log. Thanks 1
strugglez 8 Posted January 30, 2018 Author Posted January 30, 2018 @@strugglez, I've given Luke another version with the file bitrate limitation removed. Now it is limited only be the user setting for this app. When he uploads it, can you please test it and send another ffmpeg log. Thanks Sure thing! Also, here's some pics to show you the difference between Emby and Plex. Emby: Plex:
strugglez 8 Posted February 1, 2018 Author Posted February 1, 2018 Any update to when it will be uploaded to test? Regards Strugz
strugglez 8 Posted February 1, 2018 Author Posted February 1, 2018 Well, you all will pleased to hear that it transcodes crystal clear now! Hell yea! Nice work SamES, and thanks all for your input to fixing this. Still require the ffmpeg logs at all? 1
strugglez 8 Posted February 1, 2018 Author Posted February 1, 2018 I know this may this suggestion may be out of place or not accepted well, but if there are problems with the older TV's rendering platform and it will require a lot of work to have the Theater App working as it should, maybe this could be the official release for it. Just an idea. Anyway. Thanks Luke! Enjoy ya day.
SamES 1084 Posted February 1, 2018 Posted February 1, 2018 Well, you all will pleased to hear that it transcodes crystal clear now! Hell yea! Nice work SamES, and thanks all for your input to fixing this. Still require the ffmpeg logs at all? Great to hear, thanks for the feedback. Would you mind still attaching a log, I just want to see what the actual output was. Thanks.
strugglez 8 Posted February 2, 2018 Author Posted February 2, 2018 Sure. Will provide one when I'm home from work. Thanks SamES!
strugglez 8 Posted February 2, 2018 Author Posted February 2, 2018 Recent Log: 2018-02-02 06:53:11.830Application version: 3.2.70.0http://192.168.1.5:8096/emby/Videos/4a024e45217e9bd46cf664a6cff10fcf/Stream.ts?VideoStreamIndex=0&AudioStreamIndex=1&VideoCodec=h264&Profile=high&Level=41&MaxVideoBitDepth=8&MaxWidth=1920&VideoBitrate=62914560&AudioCodec=aac&AudioBitrate=360000&MaxAudioChannels=6&MediaSourceId=4a024e45217e9bd46cf664a6cff10fcf&api_key=48e3fc51489c46d58e23a0a3a4b1b6f1&DeviceId=SHCJEJIYFUKVY&StartTimeTicks=0{"Protocol":"File","Id":"4a024e45217e9bd46cf664a6cff10fcf","Path":"F:\\TV Series\\Dragon Ball\\Season 1\\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","Type":"Default","Container":"mkv,webm","Name":"Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","IsRemote":false,"ETag":"bdacb6ae3d5bd508f1d0b28ba9d496d3","RunTimeTicks":14524779520,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"hevc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","DisplayTitle":"720P HEVC","IsInterlaced":false,"BitRate":511922,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1612,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main 10","Type":"Video","AspectRatio":"403:270","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"aac","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng AAC 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":320000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"HE-AAC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":511922,"RequiredHttpHeaders":{}}User policy for Administrator: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: TrueC:\Users\Administrator\AppData\Roaming\Emby-Server\system\ffmpeg.exe -f matroska,webm -i file:"F:\TV Series\Dragon Ball\Season 1\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset veryslow -crf 1 -maxrate 2559610 -bufsize 5119220 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -y "C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata\transcoding-temp\f8464b3c9d0eae5f567c6674c8341ebc.ts"ffmpeg version git-2017-12-31-2906363 Copyright © 2000-2017 the FFmpeg developersbuilt with gcc 7.2.0 (GCC)configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-amf --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfxlibavutil 56. 7.100 / 56. 7.100libavcodec 58. 9.100 / 58. 9.100libavformat 58. 3.100 / 58. 3.100libavdevice 58. 0.100 / 58. 0.100libavfilter 7. 8.100 / 7. 8.100libswscale 5. 0.101 / 5. 0.101libswresample 3. 0.101 / 3. 0.101libpostproc 55. 0.100 / 55. 0.100Input #0, matroska,webm, from 'file:F:\TV Series\Dragon Ball\Season 1\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv':Metadata:encoder : libebml v1.3.3 + libmatroska v1.4.4creation_time : 2016-04-29T23:07:22.000000ZDuration: 00:24:12.48, start: 0.000000, bitrate: 511 kb/sChapter #0:0: start 0.000000, end 110.143000Metadata:title : Chapter 01Chapter #0:1: start 110.143000, end 150.316000Metadata:title : Chapter 02Chapter #0:2: start 150.316000, end 723.756000Metadata:title : Chapter 03Chapter #0:3: start 723.756000, end 1354.353000Metadata:title : Chapter 04Chapter #0:4: start 1354.353000, end 1452.478000Metadata:title : Chapter 05Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1612x1080, SAR 1:1 DAR 403:270, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)Metadata:BPS : 446083BPS-eng : 446083DURATION : 00:24:12.451000000DURATION-eng : 00:24:12.451000000NUMBER_OF_FRAMES: 34824NUMBER_OF_FRAMES-eng: 34824NUMBER_OF_BYTES : 80989302NUMBER_OF_BYTES-eng: 80989302_STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-04-29 23:07:22_STATISTICS_WRITING_DATE_UTC-eng: 2016-04-29 23:07:22_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream #0:1(eng): Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)Metadata:BPS : 63999BPS-eng : 63999DURATION : 00:24:12.459000000DURATION-eng : 00:24:12.459000000NUMBER_OF_FRAMES: 34042NUMBER_OF_FRAMES-eng: 34042NUMBER_OF_BYTES : 11619670NUMBER_OF_BYTES-eng: 11619670_STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-04-29 23:07:22_STATISTICS_WRITING_DATE_UTC-eng: 2016-04-29 23:07:22_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream mapping:Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264))Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for help[libx264 @ 0000019f11535c80] subme=0 + direct=temporal is not supported[libx264 @ 0000019f11535c80] using SAR=1/1[libx264 @ 0000019f11535c80] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX[libx264 @ 0000019f11535c80] profile Main, level 4.1Output #0, mpegts, to 'C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata\transcoding-temp\f8464b3c9d0eae5f567c6674c8341ebc.ts':Metadata:encoder : Lavf58.3.100Stream #0:0: Video: h264 (libx264), yuv420p, 1612x1080 [sAR 1:1 DAR 403:270], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default)Metadata:encoder : Lavc58.9.100 libx264Side data:cpb: bitrate max/min/avg: 2559000/0/0 buffer size: 5119000 vbv_delay: -1Stream #0:1: Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)frame= 41 fps=0.0 q=0.0 size= 0kB time=00:00:02.36 bitrate= 0.0kbits/s speed=4.65xframe= 63 fps= 59 q=12.0 size= 3kB time=00:00:03.09 bitrate= 9.2kbits/s speed= 2.9xframe= 85 fps= 52 q=17.0 size= 256kB time=00:00:04.11 bitrate= 509.8kbits/s speed=2.52xframe= 120 fps= 55 q=23.0 size= 768kB time=00:00:05.47 bitrate=1148.3kbits/s speed=2.49xframe= 158 fps= 58 q=25.0 size= 1280kB time=00:00:07.18 bitrate=1459.2kbits/s speed=2.64xframe= 183 fps= 57 q=26.0 size= 1536kB time=00:00:08.12 bitrate=1548.7kbits/s speed=2.52xframe= 214 fps= 57 q=25.0 size= 2048kB time=00:00:09.44 bitrate=1775.9kbits/s speed=2.54xframe= 249 fps= 59 q=21.0 size= 2560kB time=00:00:10.81 bitrate=1939.5kbits/s speed=2.56xframe= 286 fps= 60 q=24.0 size= 3072kB time=00:00:12.43 bitrate=2024.1kbits/s speed=2.63xframe= 320 fps= 61 q=22.0 size= 3584kB time=00:00:13.84 bitrate=2121.1kbits/s speed=2.65xframe= 355 fps= 62 q=23.0 size= 4096kB time=00:00:15.25 bitrate=2200.1kbits/s speed=2.66xframe= 391 fps= 63 q=28.0 size= 4608kB time=00:00:16.82 bitrate=2243.1kbits/s speed=2.69xframe= 421 fps= 62 q=26.0 size= 5120kB time=00:00:18.19 bitrate=2305.3kbits/s speed=2.67xframe= 448 fps= 61 q=26.0 size= 5376kB time=00:00:19.09 bitrate=2306.9kbits/s speed=2.59xframe= 476 fps= 61 q=28.0 size= 5888kB time=00:00:20.41 bitrate=2362.9kbits/s speed= 2.6xframe= 513 fps= 61 q=27.0 size= 6656kB time=00:00:21.94 bitrate=2484.2kbits/s speed=2.61xframe= 538 fps= 60 q=28.0 size= 6912kB time=00:00:22.88 bitrate=2474.0kbits/s speed=2.56xframe= 562 fps= 60 q=27.0 size= 7168kB time=00:00:23.91 bitrate=2455.8kbits/s speed=2.53xframe= 590 fps= 59 q=27.0 size= 7424kB time=00:00:25.14 bitrate=2418.3kbits/s speed=2.52xframe= 619 fps= 59 q=31.0 size= 7936kB time=00:00:26.51 bitrate=2452.0kbits/s speed=2.52xframe= 642 fps= 58 q=31.0 size= 8192kB time=00:00:27.24 bitrate=2463.6kbits/s speed=2.47xframe= 666 fps= 58 q=34.0 size= 8960kB time=00:00:28.22 bitrate=2600.9kbits/s speed=2.45xframe= 700 fps= 58 q=23.0 size= 9216kB time=00:00:29.92 bitrate=2522.7kbits/s speed=2.49xframe= 728 fps= 58 q=20.0 size= 9472kB time=00:00:30.86 bitrate=2513.9kbits/s speed=2.45xframe= 764 fps= 58 q=27.0 size= 9984kB time=00:00:32.27 bitrate=2534.2kbits/s speed=2.45xframe= 792 fps= 58 q=25.0 size= 10496kB time=00:00:33.63 bitrate=2556.1kbits/s speed=2.46xframe= 816 fps= 57 q=27.0 size= 10752kB time=00:00:34.66 bitrate=2541.0kbits/s speed=2.44xframe= 838 fps= 57 q=30.0 size= 11264kB time=00:00:35.34 bitrate=2610.6kbits/s speed= 2.4xframe= 864 fps= 57 q=30.0 size= 11520kB time=00:00:36.54 bitrate=2582.7kbits/s speed= 2.4xframe= 885 fps= 56 q=31.0 size= 12032kB time=00:00:37.56 bitrate=2623.9kbits/s speed=2.39xframe= 914 fps= 56 q=30.0 size= 12288kB time=00:00:38.63 bitrate=2605.8kbits/s speed=2.37xframe= 939 fps= 56 q=31.0 size= 12800kB time=00:00:39.65 bitrate=2644.2kbits/s speed=2.36xframe= 963 fps= 56 q=36.0 size= 13056kB time=00:00:40.72 bitrate=2626.5kbits/s speed=2.35xframe= 989 fps= 55 q=35.0 size= 13312kB time=00:00:41.78 bitrate=2609.6kbits/s speed=2.34xframe= 1010 fps= 55 q=32.0 size= 13568kB time=00:00:42.77 bitrate=2598.8kbits/s speed=2.33xframe= 1034 fps= 55 q=34.0 size= 14080kB time=00:00:43.79 bitrate=2633.8kbits/s speed=2.32xframe= 1062 fps= 55 q=27.0 size= 14592kB time=00:00:44.90 bitrate=2662.1kbits/s speed=2.32xframe= 1090 fps= 55 q=30.0 size= 14848kB time=00:00:45.92 bitrate=2648.4kbits/s speed= 2.3xframe= 1116 fps= 55 q=30.0 size= 15104kB time=00:00:47.25 bitrate=2618.7kbits/s speed=2.31xframe= 1135 fps= 54 q=31.0 size= 15616kB time=00:00:47.93 bitrate=2668.9kbits/s speed=2.29xframe= 1151 fps= 53 q=33.0 size= 15872kB time=00:00:48.61 bitrate=2674.6kbits/s speed=2.26xframe= 1165 fps= 53 q=34.0 size= 16128kB time=00:00:49.29 bitrate=2680.0kbits/s speed=2.24xframe= 1179 fps= 52 q=33.0 size= 16128kB time=00:00:49.63 bitrate=2661.6kbits/s speed= 2.2xframe= 1194 fps= 52 q=34.0 size= 16384kB time=00:00:50.19 bitrate=2673.9kbits/s speed=2.18xframe= 1209 fps= 51 q=30.0 size= 16640kB time=00:00:50.83 bitrate=2681.6kbits/s speed=2.16xframe= 1232 fps= 51 q=30.0 size= 17152kB time=00:00:51.85 bitrate=2709.5kbits/s speed=2.15xframe= 1266 fps= 51 q=21.0 size= 17408kB time=00:00:53.26 bitrate=2677.2kbits/s speed=2.17xframe= 1306 fps= 52 q=21.0 size= 17920kB time=00:00:54.93 bitrate=2672.5kbits/s speed=2.19xframe= 1338 fps= 52 q=24.0 size= 18432kB time=00:00:56.29 bitrate=2682.2kbits/s speed= 2.2xframe= 1362 fps= 52 q=28.0 size= 18944kB time=00:00:57.31 bitrate=2707.5kbits/s speed=2.19xframe= 1386 fps= 52 q=31.0 size= 19200kB time=00:00:58.38 bitrate=2693.9kbits/s speed=2.19xframe= 1408 fps= 52 q=33.0 size= 19456kB time=00:00:59.11 bitrate=2696.3kbits/s speed=2.17xframe= 1433 fps= 52 q=33.0 size= 19968kB time=00:01:00.43 bitrate=2706.7kbits/s speed=2.18xframe= 1459 fps= 52 q=35.0 size= 20224kB time=00:01:01.45 bitrate=2695.7kbits/s speed=2.18xframe= 1478 fps= 51 q=33.0 size= 20736kB time=00:01:02.18 bitrate=2731.7kbits/s speed=2.17xframe= 1502 fps= 51 q=29.0 size= 20992kB time=00:01:03.03 bitrate=2728.0kbits/s speed=2.16xframe= 1522 fps= 51 q=29.0 size= 21248kB time=00:01:03.93 bitrate=2722.6kbits/s speed=2.15xframe= 1547 fps= 51 q=30.0 size= 21504kB time=00:01:04.95 bitrate=2712.0kbits/s speed=2.15xframe= 1580 fps= 51 q=26.0 size= 22016kB time=00:01:06.36 bitrate=2717.6kbits/s speed=2.16xframe= 1609 fps= 51 q=20.0 size= 22528kB time=00:01:07.68 bitrate=2726.5kbits/s speed=2.16xframe= 1642 fps= 52 q=23.0 size= 23040kB time=00:01:08.92 bitrate=2738.4kbits/s speed=2.17xframe= 1674 fps= 52 q=25.0 size= 23296kB time=00:01:10.24 bitrate=2716.7kbits/s speed=2.17xframe= 1707 fps= 52 q=27.0 size= 23808kB time=00:01:11.61 bitrate=2723.5kbits/s speed=2.18xframe= 1731 fps= 52 q=29.0 size= 24064kB time=00:01:12.63 bitrate=2713.9kbits/s speed=2.18xframe= 1751 fps= 52 q=30.0 size= 24320kB time=00:01:13.53 bitrate=2709.4kbits/s speed=2.17xframe= 1773 fps= 52 q=32.0 size= 24832kB time=00:01:14.55 bitrate=2728.4kbits/s speed=2.17xframe= 1793 fps= 51 q=32.0 size= 25088kB time=00:01:15.19 bitrate=2733.1kbits/s speed=2.16xframe= 1817 fps= 51 q=33.0 size= 25600kB time=00:01:16.17 bitrate=2753.0kbits/s speed=2.15xframe= 1839 fps= 51 q=34.0 size= 25856kB time=00:01:17.20 bitrate=2743.6kbits/s speed=2.15xframe= 1859 fps= 51 q=28.0 size= 26112kB time=00:01:17.92 bitrate=2745.0kbits/s speed=2.14xframe= 1875 fps= 51 q=28.0 size= 26368kB time=00:01:18.61 bitrate=2747.8kbits/s speed=2.13xframe= 1895 fps= 51 q=27.0 size= 26624kB time=00:01:19.54 bitrate=2741.8kbits/s speed=2.13xframe= 1916 fps= 50 q=25.0 size= 26880kB time=00:01:20.57 bitrate=2732.9kbits/s speed=2.12xframe= 1943 fps= 50 q=26.0 size= 27392kB time=00:01:21.59 bitrate=2750.0kbits/s speed=2.12xframe= 1966 fps= 50 q=24.0 size= 27648kB time=00:01:22.62 bitrate=2741.3kbits/s speed=2.12xframe= 2001 fps= 51 q=21.0 size= 28160kB time=00:01:24.02 bitrate=2745.3kbits/s speed=2.13xframe= 2037 fps= 51 q=23.0 size= 28416kB time=00:01:25.60 bitrate=2719.2kbits/s speed=2.14xframe= 2072 fps= 51 q=28.0 size= 29184kB time=00:01:27.05 bitrate=2746.2kbits/s speed=2.15xframe= 2098 fps= 51 q=30.0 size= 29696kB time=00:01:28.08 bitrate=2761.9kbits/s speed=2.14xframe= 2126 fps= 51 q=30.0 size= 29952kB time=00:01:29.14 bitrate=2752.3kbits/s speed=2.14xframe= 2152 fps= 51 q=34.0 size= 30464kB time=00:01:30.34 bitrate=2762.4kbits/s speed=2.15xframe= 2182 fps= 51 q=34.0 size= 30720kB time=00:01:31.41 bitrate=2753.0kbits/s speed=2.15xframe= 2205 fps= 51 q=33.0 size= 31232kB time=00:01:32.39 bitrate=2769.2kbits/s speed=2.14xframe= 2224 fps= 51 q=38.0 size= 31488kB time=00:01:33.16 bitrate=2768.9kbits/s speed=2.14xframe= 2245 fps= 51 q=39.0 size= 31744kB time=00:01:34.14 bitrate=2762.3kbits/s speed=2.13xframe= 2267 fps= 51 q=34.0 size= 32000kB time=00:01:35.16 bitrate=2754.6kbits/s speed=2.13xframe= 2295 fps= 51 q=28.0 size= 32512kB time=00:01:36.18 bitrate=2768.9kbits/s speed=2.13xframe= 2322 fps= 51 q=22.0 size= 32768kB time=00:01:37.55 bitrate=2751.7kbits/s speed=2.14xframe= 2350 fps= 51 q=23.0 size= 33280kB time=00:01:38.49 bitrate=2768.0kbits/s speed=2.13xframe= 2380 fps= 51 q=22.0 size= 33536kB time=00:01:39.81 bitrate=2752.4kbits/s speed=2.14xframe= 2410 fps= 51 q=23.0 size= 34048kB time=00:01:41.18 bitrate=2756.7kbits/s speed=2.14xframe= 2440 fps= 51 q=25.0 size= 34560kB time=00:01:42.54 bitrate=2760.9kbits/s speed=2.14xframe= 2465 fps= 51 q=29.0 size= 35072kB time=00:01:43.27 bitrate=2782.1kbits/s speed=2.14xframe= 2492 fps= 51 q=28.0 size= 35328kB time=00:01:44.59 bitrate=2767.0kbits/s speed=2.14xframe= 2516 fps= 51 q=30.0 size= 35584kB time=00:01:45.49 bitrate=2763.3kbits/s speed=2.14xframe= 2556 fps= 51 q=31.0 size= 36352kB time=00:01:47.19 bitrate=2778.0kbits/s speed=2.15xframe= 2599 fps= 52 q=20.0 size= 36864kB time=00:01:48.90 bitrate=2773.0kbits/s speed=2.16xframe= 2640 fps= 52 q=20.0 size= 37376kB time=00:01:50.78 bitrate=2763.9kbits/s speed=2.18xframe= 2676 fps= 52 q=24.0 size= 37632kB time=00:01:52.14 bitrate=2748.9kbits/s speed=2.18xframe= 2701 fps= 52 q=26.0 size= 38144kB time=00:01:53.17 bitrate=2761.1kbits/s speed=2.18xframe= 2725 fps= 52 q=26.0 size= 38656kB time=00:01:54.19 bitrate=2773.1kbits/s speed=2.18xframe= 2750 fps= 52 q=25.0 size= 38912kB time=00:01:55.13 bitrate=2768.7kbits/s speed=2.17xframe= 2782 fps= 52 q=26.0 size= 39424kB time=00:01:56.45 bitrate=2773.3kbits/s speed=2.18xframe= 2805 fps= 52 q=25.0 size= 39680kB time=00:01:57.52 bitrate=2765.9kbits/s speed=2.18xframe= 2832 fps= 52 q=25.0 size= 40192kB time=00:01:58.84 bitrate=2770.4kbits/s speed=2.18xframe= 2858 fps= 52 q=24.0 size= 40448kB time=00:01:59.86 bitrate=2764.3kbits/s speed=2.18xframe= 2885 fps= 52 q=23.0 size= 40960kB time=00:02:00.85 bitrate=2776.5kbits/s speed=2.17xframe= 2919 fps= 52 q=24.0 size= 41472kB time=00:02:02.21 bitrate=2779.8kbits/s speed=2.18xframe= 2944 fps= 52 q=25.0 size= 41728kB time=00:02:03.23 bitrate=2773.8kbits/s speed=2.18xframe= 2976 fps= 52 q=25.0 size= 42240kB time=00:02:04.60 bitrate=2777.0kbits/s speed=2.18xframe= 3002 fps= 52 q=23.0 size= 42496kB time=00:02:05.84 bitrate=2766.4kbits/s speed=2.18xframe= 3034 fps= 52 q=25.0 size= 43008kB time=00:02:07.20 bitrate=2769.7kbits/s speed=2.19xframe= 3060 fps= 52 q=27.0 size= 43520kB time=00:02:08.23 bitrate=2780.3kbits/s speed=2.19xframe= 3063 fps= 52 q=-1.0 Lsize= 44413kB time=00:02:08.23 bitrate=2837.3kbits/s speed=2.17xvideo:39774kB audio:1004kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 8.915883%[libx264 @ 0000019f11535c80] frame I:38 Avg QP:17.17 size: 66763[libx264 @ 0000019f11535c80] frame P:1359 Avg QP:21.99 size: 22335[libx264 @ 0000019f11535c80] frame B:1666 Avg QP:22.30 size: 4704[libx264 @ 0000019f11535c80] consecutive B-frames: 22.1% 16.9% 16.6% 23.1% 11.3% 4.1% 3.4% 1.3% 1.2%[libx264 @ 0000019f11535c80] mb I I16..4: 57.6% 0.0% 42.4%[libx264 @ 0000019f11535c80] mb P I16..4: 41.0% 0.0% 0.0% P16..4: 32.9% 0.0% 0.0% 0.0% 0.0% skip:26.0%[libx264 @ 0000019f11535c80] mb B I16..4: 2.2% 0.0% 0.0% B16..8: 14.0% 0.0% 0.0% direct: 8.5% skip:75.3% L0:43.8% L1:49.0% BI: 7.2%[libx264 @ 0000019f11535c80] coded y,uvDC,uvAC intra: 12.0% 43.7% 10.7% inter: 7.1% 19.6% 1.0%[libx264 @ 0000019f11535c80] i16 v,h,dc,p: 54% 27% 11% 8%[libx264 @ 0000019f11535c80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 22% 16% 8% 6% 5% 5% 5% 5%[libx264 @ 0000019f11535c80] i8c dc,h,v,p: 45% 26% 22% 7%[libx264 @ 0000019f11535c80] Weighted P-Frames: Y:6.3% UV:3.2%[libx264 @ 0000019f11535c80] ref P L0: 66.8% 0.0% 18.9% 8.9% 5.4% 0.0%[libx264 @ 0000019f11535c80] ref B L0: 77.4% 17.8% 4.8%[libx264 @ 0000019f11535c80] ref B L1: 96.5% 3.5%[libx264 @ 0000019f11535c80] kb/s:2550.45
strugglez 8 Posted February 2, 2018 Author Posted February 2, 2018 (edited) Oh, I've just noticed that with testing I hadn't reverted it back to normal settings on the server end. But I imagine that will not change much. I will test and report back again soon! Edit: Yeap, still crystal clear! with CRF 20 and speed set to auto. 2018-02-02 22:21:07.931Application version: 3.2.70.0http://192.168.1.5:8096/emby/Videos/4a024e45217e9bd46cf664a6cff10fcf/Stream.ts?VideoStreamIndex=0&AudioStreamIndex=1&VideoCodec=h264&Profile=high&Level=41&MaxVideoBitDepth=8&MaxWidth=1920&VideoBitrate=62914560&AudioCodec=aac&AudioBitrate=360000&MaxAudioChannels=6&MediaSourceId=4a024e45217e9bd46cf664a6cff10fcf&api_key=48e3fc51489c46d58e23a0a3a4b1b6f1&DeviceId=SHCJEJIYFUKVY&StartTimeTicks=0{"Protocol":"File","Id":"4a024e45217e9bd46cf664a6cff10fcf","Path":"F:\\TV Series\\Dragon Ball\\Season 1\\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","Type":"Default","Container":"mkv,webm","Name":"Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv","IsRemote":false,"ETag":"bdacb6ae3d5bd508f1d0b28ba9d496d3","RunTimeTicks":14524779520,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"hevc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","DisplayTitle":"720P HEVC","IsInterlaced":false,"BitRate":511922,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1612,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main 10","Type":"Video","AspectRatio":"403:270","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"aac","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng AAC 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":320000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"HE-AAC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":511922,"RequiredHttpHeaders":{}}User policy for Administrator: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: TrueC:\Users\Administrator\AppData\Roaming\Emby-Server\system\ffmpeg.exe -f matroska,webm -i file:"F:\TV Series\Dragon Ball\Season 1\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 20 -maxrate 2559610 -bufsize 5119220 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -y "C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata\transcoding-temp\ca319587df58d0830f1e74116305f9d6.ts"ffmpeg version git-2017-12-31-2906363 Copyright © 2000-2017 the FFmpeg developersbuilt with gcc 7.2.0 (GCC)configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-amf --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfxlibavutil 56. 7.100 / 56. 7.100libavcodec 58. 9.100 / 58. 9.100libavformat 58. 3.100 / 58. 3.100libavdevice 58. 0.100 / 58. 0.100libavfilter 7. 8.100 / 7. 8.100libswscale 5. 0.101 / 5. 0.101libswresample 3. 0.101 / 3. 0.101libpostproc 55. 0.100 / 55. 0.100Input #0, matroska,webm, from 'file:F:\TV Series\Dragon Ball\Season 1\Dragon Ball - 1x01 - Secret of the Dragon Balls.mkv':Metadata:encoder : libebml v1.3.3 + libmatroska v1.4.4creation_time : 2016-04-29T23:07:22.000000ZDuration: 00:24:12.48, start: 0.000000, bitrate: 511 kb/sChapter #0:0: start 0.000000, end 110.143000Metadata:title : Chapter 01Chapter #0:1: start 110.143000, end 150.316000Metadata:title : Chapter 02Chapter #0:2: start 150.316000, end 723.756000Metadata:title : Chapter 03Chapter #0:3: start 723.756000, end 1354.353000Metadata:title : Chapter 04Chapter #0:4: start 1354.353000, end 1452.478000Metadata:title : Chapter 05Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1612x1080, SAR 1:1 DAR 403:270, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)Metadata:BPS : 446083BPS-eng : 446083DURATION : 00:24:12.451000000DURATION-eng : 00:24:12.451000000NUMBER_OF_FRAMES: 34824NUMBER_OF_FRAMES-eng: 34824NUMBER_OF_BYTES : 80989302NUMBER_OF_BYTES-eng: 80989302_STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-04-29 23:07:22_STATISTICS_WRITING_DATE_UTC-eng: 2016-04-29 23:07:22_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream #0:1(eng): Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)Metadata:BPS : 63999BPS-eng : 63999DURATION : 00:24:12.459000000DURATION-eng : 00:24:12.459000000NUMBER_OF_FRAMES: 34042NUMBER_OF_FRAMES-eng: 34042NUMBER_OF_BYTES : 11619670NUMBER_OF_BYTES-eng: 11619670_STATISTICS_WRITING_APP: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.5.2 ('Crosses') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-04-29 23:07:22_STATISTICS_WRITING_DATE_UTC-eng: 2016-04-29 23:07:22_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream mapping:Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264))Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for help[libx264 @ 000001b3797c5c80] using SAR=1/1[libx264 @ 000001b3797c5c80] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX[libx264 @ 000001b3797c5c80] profile Main, level 4.1Output #0, mpegts, to 'C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata\transcoding-temp\ca319587df58d0830f1e74116305f9d6.ts':Metadata:encoder : Lavf58.3.100Stream #0:0: Video: h264 (libx264), yuv420p, 1612x1080 [sAR 1:1 DAR 403:270], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default)Metadata:encoder : Lavc58.9.100 libx264Side data:cpb: bitrate max/min/avg: 2559000/0/0 buffer size: 5119000 vbv_delay: -1Stream #0:1: Audio: aac (HE-AAC), 48000 Hz, 5.1, fltp (default)frame= 67 fps=0.0 q=14.0 size= 256kB time=00:00:03.43 bitrate= 611.2kbits/s speed=6.82xframe= 130 fps=129 q=25.0 size= 1280kB time=00:00:06.16 bitrate=1701.7kbits/s speed=6.13xframe= 190 fps=125 q=24.0 size= 2304kB time=00:00:08.42 bitrate=2240.8kbits/s speed=5.56xframe= 256 fps=127 q=22.0 size= 3072kB time=00:00:11.15 bitrate=2256.2kbits/s speed=5.52xframe= 323 fps=128 q=21.0 size= 4096kB time=00:00:14.18 bitrate=2365.8kbits/s speed=5.62xframe= 387 fps=128 q=22.0 size= 5120kB time=00:00:16.48 bitrate=2544.0kbits/s speed=5.45xframe= 447 fps=127 q=23.0 size= 5888kB time=00:00:19.04 bitrate=2532.4kbits/s speed= 5.4xframe= 506 fps=126 q=28.0 size= 6656kB time=00:00:21.60 bitrate=2523.5kbits/s speed=5.36xframe= 561 fps=124 q=28.0 size= 7680kB time=00:00:23.91 bitrate=2631.2kbits/s speed=5.28xframe= 612 fps=122 q=33.0 size= 8448kB time=00:00:26.17 bitrate=2644.2kbits/s speed= 5.2xframe= 665 fps=120 q=19.0 size= 8960kB time=00:00:28.22 bitrate=2600.9kbits/s speed= 5.1xframe= 719 fps=119 q=19.0 size= 9984kB time=00:00:30.52 bitrate=2679.4kbits/s speed=5.05xframe= 776 fps=118 q=26.0 size= 10752kB time=00:00:32.95 bitrate=2672.6kbits/s speed=5.03xframe= 828 fps=117 q=31.0 size= 11520kB time=00:00:35.00 bitrate=2696.0kbits/s speed=4.96xframe= 884 fps=117 q=26.0 size= 12288kB time=00:00:37.56 bitrate=2679.7kbits/s speed=4.97xframe= 939 fps=116 q=36.0 size= 13056kB time=00:00:39.65 bitrate=2697.1kbits/s speed=4.92xframe= 995 fps=116 q=35.0 size= 13824kB time=00:00:42.08 bitrate=2690.8kbits/s speed=4.91xframe= 1054 fps=116 q=22.0 size= 14848kB time=00:00:44.56 bitrate=2729.6kbits/s speed=4.91xframe= 1108 fps=116 q=30.0 size= 15616kB time=00:00:46.56 bitrate=2747.1kbits/s speed=4.86xframe= 1162 fps=115 q=31.0 size= 16384kB time=00:00:48.95 bitrate=2741.5kbits/s speed=4.85xframe= 1217 fps=115 q=27.0 size= 17152kB time=00:00:51.17 bitrate=2745.7kbits/s speed=4.83xframe= 1287 fps=116 q=18.0 size= 18176kB time=00:00:54.24 bitrate=2744.8kbits/s speed=4.89xframe= 1345 fps=116 q=32.0 size= 18944kB time=00:00:56.63 bitrate=2740.1kbits/s speed=4.88xframe= 1400 fps=116 q=33.0 size= 19968kB time=00:00:58.72 bitrate=2785.4kbits/s speed=4.85xframe= 1451 fps=115 q=34.0 size= 20736kB time=00:01:01.11 bitrate=2779.4kbits/s speed=4.84xframe= 1509 fps=115 q=31.0 size= 21504kB time=00:01:03.37 bitrate=2779.5kbits/s speed=4.83xframe= 1569 fps=115 q=22.0 size= 22272kB time=00:01:05.98 bitrate=2765.2kbits/s speed=4.84xframe= 1632 fps=115 q=21.0 size= 23296kB time=00:01:08.54 bitrate=2784.4kbits/s speed=4.85xframe= 1694 fps=116 q=25.0 size= 24064kB time=00:01:11.27 bitrate=2766.0kbits/s speed=4.87xframe= 1748 fps=115 q=30.0 size= 24832kB time=00:01:13.36 bitrate=2772.8kbits/s speed=4.84xframe= 1796 fps=115 q=30.0 size= 25600kB time=00:01:15.49 bitrate=2777.9kbits/s speed=4.82xframe= 1854 fps=115 q=33.0 size= 26368kB time=00:01:17.88 bitrate=2773.4kbits/s speed=4.82xframe= 1918 fps=115 q=18.0 size= 27392kB time=00:01:20.57 bitrate=2785.0kbits/s speed=4.83xframe= 1979 fps=115 q=19.0 size= 28160kB time=00:01:23.00 bitrate=2779.2kbits/s speed=4.83xframe= 2042 fps=116 q=28.0 size= 29184kB time=00:01:25.65 bitrate=2791.3kbits/s speed=4.85xframe= 2101 fps=115 q=29.0 size= 29952kB time=00:01:28.08 bitrate=2785.7kbits/s speed=4.84xframe= 2155 fps=115 q=34.0 size= 30720kB time=00:01:30.34 bitrate=2785.6kbits/s speed=4.83xframe= 2205 fps=115 q=38.0 size= 31488kB time=00:01:32.34 bitrate=2793.2kbits/s speed=4.81xframe= 2259 fps=115 q=33.0 size= 32256kB time=00:01:34.82 bitrate=2786.7kbits/s speed=4.81xframe= 2313 fps=114 q=21.0 size= 33024kB time=00:01:37.21 bitrate=2782.9kbits/s speed=4.81xframe= 2362 fps=114 q=22.0 size= 33792kB time=00:01:39.13 bitrate=2792.5kbits/s speed=4.79xframe= 2414 fps=114 q=22.0 size= 34560kB time=00:01:41.18 bitrate=2798.1kbits/s speed=4.77xframe= 2468 fps=114 q=24.0 size= 35328kB time=00:01:43.57 bitrate=2794.3kbits/s speed=4.77xframe= 2523 fps=114 q=23.0 size= 36096kB time=00:01:45.83 bitrate=2794.1kbits/s speed=4.76xframe= 2594 fps=114 q=20.0 size= 37120kB time=00:01:48.90 bitrate=2792.3kbits/s speed=4.79xframe= 2658 fps=114 q=29.0 size= 38144kB time=00:01:51.46 bitrate=2803.4kbits/s speed= 4.8xframe= 2707 fps=114 q=22.0 size= 38912kB time=00:01:53.51 bitrate=2808.2kbits/s speed=4.78xframe= 2760 fps=114 q=21.0 size= 39680kB time=00:01:55.77 bitrate=2807.7kbits/s speed=4.78xframe= 2815 fps=114 q=21.0 size= 40448kB time=00:01:57.82 bitrate=2812.3kbits/s speed=4.76xframe= 2870 fps=114 q=21.0 size= 41216kB time=00:02:00.12 bitrate=2810.8kbits/s speed=4.76xframe= 2928 fps=114 q=30.0 size= 41984kB time=00:02:02.60 bitrate=2805.3kbits/s speed=4.76xframe= 2985 fps=114 q=23.0 size= 42752kB time=00:02:04.94 bitrate=2803.0kbits/s speed=4.76xframe= 3045 fps=114 q=28.0 size= 43776kB time=00:02:07.54 bitrate=2811.6kbits/s speed=4.76xframe= 3109 fps=114 q=24.0 size= 44544kB time=00:02:10.27 bitrate=2800.9kbits/s speed=4.77xframe= 3170 fps=114 q=17.0 size= 45568kB time=00:02:12.71 bitrate=2812.8kbits/s speed=4.78xframe= 3235 fps=114 q=24.0 size= 46336kB time=00:02:15.48 bitrate=2801.7kbits/s speed=4.79xframe= 3292 fps=114 q=22.0 size= 47360kB time=00:02:18.08 bitrate=2809.6kbits/s speed=4.79xframe= 3358 fps=115 q=18.0 size= 48384kB time=00:02:20.60 bitrate=2819.0kbits/s speed= 4.8xframe= 3420 fps=115 q=21.0 size= 49152kB time=00:02:23.25 bitrate=2810.8kbits/s speed=4.81xframe= 3495 fps=115 q=19.0 size= 50176kB time=00:02:26.32 bitrate=2809.2kbits/s speed=4.83xframe= 3567 fps=116 q=10.0 size= 50688kB time=00:02:29.26 bitrate=2781.9kbits/s speed=4.84xframe= 3632 fps=116 q=21.0 size= 51200kB time=00:02:31.95 bitrate=2760.2kbits/s speed=4.85xframe= 3683 fps=116 q=22.0 size= 52224kB time=00:02:34.34 bitrate=2771.9kbits/s speed=4.85xframe= 3734 fps=116 q=20.0 size= 52736kB time=00:02:36.34 bitrate=2763.1kbits/s speed=4.84xframe= 3794 fps=116 q=21.0 size= 53760kB time=00:02:38.78 bitrate=2773.6kbits/s speed=4.84xframe= 3859 fps=116 q=23.0 size= 54784kB time=00:02:41.59 bitrate=2777.2kbits/s speed=4.85xframe= 3926 fps=116 q=24.0 size= 55552kB time=00:02:44.32 bitrate=2769.4kbits/s speed=4.86xframe= 3979 fps=116 q=27.0 size= 56320kB time=00:02:46.41 bitrate=2772.4kbits/s speed=4.84xframe= 4036 fps=116 q=25.0 size= 57088kB time=00:02:48.80 bitrate=2770.4kbits/s speed=4.84xframe= 4096 fps=116 q=28.0 size= 58112kB time=00:02:51.28 bitrate=2779.4kbits/s speed=4.85xframe= 4151 fps=116 q=26.0 size= 58880kB time=00:02:53.79 bitrate=2775.3kbits/s speed=4.85xframe= 4205 fps=116 q=30.0 size= 59648kB time=00:02:56.06 bitrate=2775.4kbits/s speed=4.84xframe= 4258 fps=116 q=31.0 size= 60416kB time=00:02:58.10 bitrate=2778.8kbits/s speed=4.83xframe= 4319 fps=116 q=24.0 size= 61184kB time=00:03:00.75 bitrate=2772.9kbits/s speed=4.84xframe= 4370 fps=115 q=29.0 size= 61952kB time=00:03:02.88 bitrate=2775.0kbits/s speed=4.83xframe= 4419 fps=115 q=35.0 size= 62720kB time=00:03:04.93 bitrate=2778.3kbits/s speed=4.82xframe= 4481 fps=115 q=29.0 size= 63744kB time=00:03:07.36 bitrate=2787.0kbits/s speed=4.82xframe= 4532 fps=115 q=20.0 size= 64512kB time=00:03:09.62 bitrate=2786.9kbits/s speed=4.81xframe= 4589 fps=115 q=32.0 size= 65280kB time=00:03:11.89 bitrate=2786.9kbits/s speed=4.81xframe= 4649 fps=115 q=22.0 size= 66048kB time=00:03:14.62 bitrate=2780.1kbits/s speed=4.82xframe= 4702 fps=115 q=23.0 size= 66816kB time=00:03:16.54 bitrate=2784.9kbits/s speed=4.81xframe= 4757 fps=115 q=25.0 size= 67584kB time=00:03:18.97 bitrate=2782.5kbits/s speed=4.81xframe= 4810 fps=115 q=25.0 size= 68352kB time=00:03:21.23 bitrate=2782.5kbits/s speed= 4.8xframe= 4871 fps=115 q=26.0 size= 69376kB time=00:03:23.62 bitrate=2791.1kbits/s speed= 4.8xframe= 4927 fps=115 q=28.0 size= 70144kB time=00:03:25.88 bitrate=2791.0kbits/s speed= 4.8xframe= 4990 fps=115 q=25.0 size= 71168kB time=00:03:28.61 bitrate=2794.7kbits/s speed= 4.8xframe= 5051 fps=115 q=24.0 size= 71936kB time=00:03:31.21 bitrate=2790.0kbits/s speed=4.81xframe= 5110 fps=115 q=21.0 size= 72960kB time=00:03:33.60 bitrate=2798.1kbits/s speed=4.81xframe= 5168 fps=115 q=28.0 size= 73728kB time=00:03:36.25 bitrate=2792.9kbits/s speed=4.81xframe= 5214 fps=115 q=32.0 size= 74496kB time=00:03:37.95 bitrate=2799.9kbits/s speed=4.79xframe= 5263 fps=114 q=35.0 size= 75264kB time=00:03:40.09 bitrate=2801.4kbits/s speed=4.79xframe= 5326 fps=115 q=23.0 size= 76032kB time=00:03:42.69 bitrate=2796.9kbits/s speed=4.79xframe= 5381 fps=114 q=27.0 size= 76800kB time=00:03:44.99 bitrate=2796.2kbits/s speed=4.79xframe= 5439 fps=114 q=24.0 size= 77824kB time=00:03:47.26 bitrate=2805.3kbits/s speed=4.78xframe= 5497 fps=114 q=30.0 size= 78336kB time=00:03:49.90 bitrate=2791.3kbits/s speed=4.79xframe= 5559 fps=115 q=21.0 size= 79360kB time=00:03:52.46 bitrate=2796.6kbits/s speed=4.79xframe= 5621 fps=115 q=30.0 size= 80384kB time=00:03:54.85 bitrate=2803.9kbits/s speed=4.79xframe= 5687 fps=115 q=23.0 size= 81152kB time=00:03:57.79 bitrate=2795.6kbits/s speed= 4.8xframe= 5753 fps=115 q=22.0 size= 82176kB time=00:04:00.44 bitrate=2799.7kbits/s speed=4.81xframe= 5818 fps=115 q=17.0 size= 83200kB time=00:04:03.13 bitrate=2803.3kbits/s speed=4.81xframe= 5885 fps=115 q=26.0 size= 84224kB time=00:04:05.90 bitrate=2805.8kbits/s speed=4.82xframe= 5953 fps=116 q=24.0 size= 84992kB time=00:04:08.80 bitrate=2798.4kbits/s speed=4.83xframe= 6020 fps=116 q=29.0 size= 86016kB time=00:04:11.45 bitrate=2802.3kbits/s speed=4.83xframe= 6075 fps=116 q=24.0 size= 86784kB time=00:04:13.84 bitrate=2800.7kbits/s speed=4.83xframe= 6138 fps=116 q=27.0 size= 87808kB time=00:04:16.48 bitrate=2804.5kbits/s speed=4.83xframe= 6196 fps=116 q=22.0 size= 88576kB time=00:04:19.00 bitrate=2801.5kbits/s speed=4.84xframe= 6259 fps=116 q=20.0 size= 89600kB time=00:04:21.39 bitrate=2808.0kbits/s speed=4.83xframe= 6323 fps=116 q=21.0 size= 90624kB time=00:04:24.33 bitrate=2808.5kbits/s speed=4.84xframe= 6379 fps=116 q=25.0 size= 91392kB time=00:04:26.72 bitrate=2806.9kbits/s speed=4.84xframe= 6429 fps=116 q=31.0 size= 92160kB time=00:04:28.69 bitrate=2809.8kbits/s speed=4.83xframe= 6495 fps=116 q=25.0 size= 92928kB time=00:04:31.42 bitrate=2804.7kbits/s speed=4.84xframe= 6560 fps=116 q=21.0 size= 93952kB time=00:04:34.36 bitrate=2805.2kbits/s speed=4.85xframe= 6624 fps=116 q=19.0 size= 94976kB time=00:04:36.75 bitrate=2811.3kbits/s speed=4.85xframe= 6693 fps=116 q=20.0 size= 96000kB time=00:04:39.69 bitrate=2811.7kbits/s speed=4.85xframe= 6760 fps=116 q=17.0 size= 96768kB time=00:04:42.42 bitrate=2806.8kbits/s speed=4.86xframe= 6823 fps=116 q=17.0 size= 97792kB time=00:04:45.07 bitrate=2810.2kbits/s speed=4.86xframe= 6889 fps=116 q=15.0 size= 98816kB time=00:04:47.76 bitrate=2813.1kbits/s speed=4.87xframe= 6950 fps=117 q=24.0 size= 99584kB time=00:04:50.57 bitrate=2807.5kbits/s speed=4.87xframe= 7015 fps=117 q=22.0 size= 100608kB time=00:04:52.96 bitrate=2813.2kbits/s speed=4.87xframe= 7085 fps=117 q=18.0 size= 101376kB time=00:04:56.25 bitrate=2803.3kbits/s speed=4.88xframe= 7155 fps=117 q=17.0 size= 102656kB time=00:04:58.94 bitrate=2813.1kbits/s speed=4.89xframe= 7214 fps=117 q=17.0 size= 103168kB time=00:05:01.28 bitrate=2805.1kbits/s speed=4.89xframe= 7281 fps=117 q=18.0 size= 104448kB time=00:05:04.06 bitrate=2814.0kbits/s speed=4.89xframe= 7349 fps=117 q=17.0 size= 105472kB time=00:05:07.30 bitrate=2811.6kbits/s speed= 4.9xframe= 7415 fps=117 q=25.0 size= 106496kB time=00:05:09.69 bitrate=2817.0kbits/s speed= 4.9xframe= 7484 fps=118 q=20.0 size= 107264kB time=00:05:12.63 bitrate=2810.6kbits/s speed=4.91xframe= 7550 fps=118 q=20.0 size= 108288kB time=00:05:15.32 bitrate=2813.3kbits/s speed=4.91xframe= 7614 fps=118 q=23.0 size= 109312kB time=00:05:18.14 bitrate=2814.7kbits/s speed=4.92xframe= 7676 fps=118 q=26.0 size= 110080kB time=00:05:20.70 bitrate=2811.9kbits/s speed=4.92xframe= 7738 fps=118 q=30.0 size= 111104kB time=00:05:23.34 bitrate=2814.8kbits/s speed=4.92xframe= 7789 fps=118 q=35.0 size= 111872kB time=00:05:25.22 bitrate=2817.9kbits/s speed=4.91xframe= 7843 fps=118 q=24.0 size= 112640kB time=00:05:27.52 bitrate=2817.3kbits/s speed=4.91xframe= 7897 fps=117 q=25.0 size= 113408kB time=00:05:29.91 bitrate=2816.0kbits/s speed=4.91xframe= 7959 fps=118 q=19.0 size= 114176kB time=00:05:32.39 bitrate=2813.9kbits/s speed=4.91xframe= 8020 fps=118 q=19.0 size= 115200kB time=00:05:35.03 bitrate=2816.8kbits/s speed=4.91xframe= 8085 fps=118 q=20.0 size= 116224kB time=00:05:37.89 bitrate=2817.8kbits/s speed=4.91xframe= 8151 fps=118 q=25.0 size= 116992kB time=00:05:40.62 bitrate=2813.6kbits/s speed=4.92xframe= 8214 fps=118 q=27.0 size= 118016kB time=00:05:43.22 bitrate=2816.7kbits/s speed=4.92xframe= 8277 fps=118 q=19.0 size= 119040kB time=00:05:45.87 bitrate=2819.5kbits/s speed=4.92xframe= 8338 fps=118 q=23.0 size= 119808kB time=00:05:48.43 bitrate=2816.8kbits/s speed=4.92xframe= 8396 fps=118 q=25.0 size= 120576kB time=00:05:50.52 bitrate=2817.9kbits/s speed=4.92xframe= 8452 fps=118 q=36.0 size= 121600kB time=00:05:52.95 bitrate=2822.3kbits/s speed=4.92xframe= 8512 fps=118 q=26.0 size= 122368kB time=00:05:55.51 bitrate=2819.7kbits/s speed=4.92xframe= 8566 fps=118 q=28.0 size= 123136kB time=00:05:57.60 bitrate=2820.8kbits/s speed=4.91xframe= 8620 fps=118 q=38.0 size= 123904kB time=00:05:59.99 bitrate=2819.5kbits/s speed=4.91xframe= 8674 fps=118 q=33.0 size= 124672kB time=00:06:02.25 bitrate=2819.3kbits/s speed=4.91xframe= 8727 fps=117 q=31.0 size= 125440kB time=00:06:04.60 bitrate=2818.4kbits/s speed=4.91xframe= 8785 fps=117 q=34.0 size= 126464kB time=00:06:06.99 bitrate=2822.9kbits/s speed=4.91xframe= 8844 fps=117 q=30.0 size= 126976kB time=00:06:09.25 bitrate=2817.0kbits/s speed= 4.9xframe= 8895 fps=117 q=38.0 size= 128000kB time=00:06:11.51 bitrate=2822.4kbits/s speed= 4.9xframe= 8955 fps=117 q=17.0 size= 128768kB time=00:06:13.90 bitrate=2821.2kbits/s speed= 4.9xframe= 9017 fps=117 q=18.0 size= 129536kB time=00:06:16.50 bitrate=2818.4kbits/s speed= 4.9xframe= 9076 fps=117 q=25.0 size= 130560kB time=00:06:19.06 bitrate=2821.5kbits/s speed= 4.9xframe= 9129 fps=117 q=28.0 size= 131328kB time=00:06:21.41 bitrate=2820.7kbits/s speed= 4.9xframe= 9196 fps=117 q=20.0 size= 132352kB time=00:06:24.01 bitrate=2823.4kbits/s speed= 4.9xframe= 9257 fps=117 q=26.0 size= 133120kB time=00:06:26.74 bitrate=2819.7kbits/s speed= 4.9xframe= 9321 fps=117 q=17.0 size= 134144kB time=00:06:29.35 bitrate=2822.4kbits/s speed=4.91xframe= 9384 fps=118 q=24.0 size= 135168kB time=00:06:31.74 bitrate=2826.6kbits/s speed=4.91xframe= 9446 fps=118 q=19.0 size= 135936kB time=00:06:34.72 bitrate=2821.2kbits/s speed=4.91xframe= 9513 fps=118 q=19.0 size= 136960kB time=00:06:37.41 bitrate=2823.2kbits/s speed=4.91xframe= 9574 fps=118 q=21.0 size= 137728kB time=00:06:39.80 bitrate=2822.0kbits/s speed=4.91xframe= 9639 fps=118 q=19.0 size= 138752kB time=00:06:42.36 bitrate=2824.9kbits/s speed=4.91xframe= 9700 fps=118 q=23.0 size= 139520kB time=00:06:45.01 bitrate=2822.0kbits/s speed=4.92xframe= 9762 fps=118 q=26.0 size= 140544kB time=00:06:47.65 bitrate=2824.3kbits/s speed=4.92xframe= 9821 fps=118 q=26.0 size= 141312kB time=00:06:50.25 bitrate=2821.7kbits/s speed=4.92xframe= 9876 fps=118 q=32.0 size= 142336kB time=00:06:52.34 bitrate=2827.7kbits/s speed=4.92xframe= 9930 fps=118 q=28.0 size= 142848kB time=00:06:54.73 bitrate=2821.6kbits/s speed=4.91xframe= 9982 fps=118 q=27.0 size= 143872kB time=00:06:56.78 bitrate=2827.8kbits/s speed=4.91xframe=10033 fps=117 q=36.0 size= 144384kB time=00:06:58.83 bitrate=2824.0kbits/s speed= 4.9xframe=10083 fps=117 q=35.0 size= 145152kB time=00:07:01.01 bitrate=2824.4kbits/s speed= 4.9xframe=10142 fps=117 q=27.0 size= 146176kB time=00:07:03.61 bitrate=2826.8kbits/s speed= 4.9xframe=10203 fps=117 q=26.0 size= 146944kB time=00:07:06.00 bitrate=2825.7kbits/s speed= 4.9xframe=10260 fps=117 q=28.0 size= 147712kB time=00:07:08.43 bitrate=2824.4kbits/s speed= 4.9xframe=10326 fps=117 q=22.0 size= 148736kB time=00:07:11.16 bitrate=2825.9kbits/s speed= 4.9xframe=10386 fps=117 q=24.0 size= 149504kB time=00:07:13.81 bitrate=2823.2kbits/s speed=4.91xframe=10447 fps=117 q=24.0 size= 150528kB time=00:07:16.32 bitrate=2826.1kbits/s speed=4.91xframe=10511 fps=118 q=19.0 size= 151552kB time=00:07:18.88 bitrate=2828.8kbits/s speed=4.91xframe=10564 fps=117 q=34.0 size= 152320kB time=00:07:20.97 bitrate=2829.6kbits/s speed= 4.9xframe=10613 fps=117 q=30.0 size= 152832kB time=00:07:23.02 bitrate=2826.0kbits/s speed= 4.9xframe=10666 fps=117 q=37.0 size= 153600kB time=00:07:25.41 bitrate=2825.0kbits/s speed= 4.9xframe=10716 fps=117 q=34.0 size= 154368kB time=00:07:27.46 bitrate=2826.1kbits/s speed=4.89xframe=10778 fps=117 q=24.0 size= 155392kB time=00:07:30.10 bitrate=2828.1kbits/s speed= 4.9xframe=10845 fps=117 q=22.0 size= 156160kB time=00:07:32.79 bitrate=2825.2kbits/s speed= 4.9xframe=10909 fps=117 q=20.0 size= 157184kB time=00:07:35.52 bitrate=2826.7kbits/s speed= 4.9xframe=10975 fps=117 q=20.0 size= 158208kB time=00:07:38.25 bitrate=2828.2kbits/s speed= 4.9xframe=11038 fps=117 q=26.0 size= 159232kB time=00:07:40.86 bitrate=2830.4kbits/s speed= 4.9xframe=11104 fps=118 q=28.0 size= 160000kB time=00:07:43.46 bitrate=2828.1kbits/s speed=4.91xframe=11165 fps=118 q=25.0 size= 161024kB time=00:07:46.19 bitrate=2829.5kbits/s speed=4.91xframe=11228 fps=118 q=24.0 size= 161792kB time=00:07:48.83 bitrate=2827.0kbits/s speed=4.91xframe=11279 fps=118 q=29.0 size= 162560kB time=00:07:50.84 bitrate=2828.3kbits/s speed=4.91xframe=11335 fps=117 q=21.0 size= 163328kB time=00:07:53.19 bitrate=2827.6kbits/s speed= 4.9xframe=11389 fps=117 q=23.0 size= 164352kB time=00:07:55.58 bitrate=2831.0kbits/s speed= 4.9xframe=11456 fps=117 q=21.0 size= 165120kB time=00:07:58.22 bitrate=2828.5kbits/s speed= 4.9xframe=11520 fps=118 q=28.0 size= 166144kB time=00:08:01.04 bitrate=2829.4kbits/s speed=4.91xframe=11575 fps=118 q=23.0 size= 166912kB time=00:08:03.51 bitrate=2827.9kbits/s speed=4.91xframe=11632 fps=117 q=24.0 size= 167680kB time=00:08:05.56 bitrate=2828.9kbits/s speed= 4.9xframe=11689 fps=117 q=22.0 size= 168448kB time=00:08:08.21 bitrate=2826.5kbits/s speed=4.91xframe=11748 fps=117 q=24.0 size= 169472kB time=00:08:10.51 bitrate=2830.3kbits/s speed= 4.9xframe=11802 fps=117 q=33.0 size= 170240kB time=00:08:12.60 bitrate=2831.1kbits/s speed= 4.9xframe=11860 fps=117 q=26.0 size= 171008kB time=00:08:15.37 bitrate=2827.9kbits/s speed= 4.9xframe=11926 fps=117 q=23.0 size= 172032kB time=00:08:18.10 bitrate=2829.3kbits/s speed=4.91xframe=11993 fps=118 q=21.0 size= 173056kB time=00:08:20.83 bitrate=2830.6kbits/s speed=4.91xframe=12057 fps=118 q=19.0 size= 173824kB time=00:08:23.22 bitrate=2829.7kbits/s speed=4.91xframe=12123 fps=118 q=26.0 size= 174848kB time=00:08:26.17 bitrate=2829.8kbits/s speed=4.91xframe=12184 fps=118 q=16.0 size= 175616kB time=00:08:28.56 bitrate=2828.9kbits/s speed=4.91xframe=12240 fps=118 q=36.0 size= 176640kB time=00:08:31.03 bitrate=2831.6kbits/s speed=4.91xframe=12294 fps=118 q=34.0 size= 177408kB time=00:08:33.34 bitrate=2831.1kbits/s speed=4.91xframe=12355 fps=118 q=26.0 size= 178176kB time=00:08:35.77 bitrate=2830.0kbits/s speed=4.91xframe=12422 fps=118 q=22.0 size= 179200kB time=00:08:38.67 bitrate=2830.3kbits/s speed=4.91xframe=12444 fps=118 q=-1.0 Lsize= 180119kB time=00:08:39.69 bitrate=2839.2kbits/s speed=4.91xvideo:161296kB audio:4062kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 8.926828%[libx264 @ 000001b3797c5c80] frame I:273 Avg QP:20.60 size: 58201[libx264 @ 000001b3797c5c80] frame P:4360 Avg QP:22.53 size: 22747[libx264 @ 000001b3797c5c80] frame B:7811 Avg QP:21.89 size: 6414[libx264 @ 000001b3797c5c80] consecutive B-frames: 11.9% 10.4% 8.7% 69.0%[libx264 @ 000001b3797c5c80] mb I I16..4: 58.0% 0.0% 42.0%[libx264 @ 000001b3797c5c80] mb P I16..4: 31.6% 0.0% 0.0% P16..4: 35.4% 0.0% 0.0% 0.0% 0.0% skip:33.0%[libx264 @ 000001b3797c5c80] mb B I16..4: 2.3% 0.0% 0.0% B16..8: 18.5% 0.0% 0.0% direct:11.2% skip:68.0% L0:39.5% L1:51.9% BI: 8.6%[libx264 @ 000001b3797c5c80] coded y,uvDC,uvAC intra: 18.7% 45.8% 17.8% inter: 6.5% 15.3% 0.6%[libx264 @ 000001b3797c5c80] i16 v,h,dc,p: 50% 29% 13% 8%[libx264 @ 000001b3797c5c80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 23% 18% 9% 5% 4% 5% 4% 5%[libx264 @ 000001b3797c5c80] i8c dc,h,v,p: 43% 27% 22% 8%[libx264 @ 000001b3797c5c80] Weighted P-Frames: Y:3.9% UV:1.4%[libx264 @ 000001b3797c5c80] kb/s:2545.83 Edited February 2, 2018 by strugglez 1
SamES 1084 Posted February 2, 2018 Posted February 2, 2018 @@Luke, before I submit this change, does the second log and parameters look fine to you? I'm not sure if this change to maxbitrate will cause anyone else issues, but probably the risk is low. The only reason this is transcoding is because it is x265 content, otherwise pretty much everything else direct plays with this app, even on the E-series.
Luke 42239 Posted July 6, 2018 Posted July 6, 2018 New app releases available: https://emby.media/community/index.php?/topic/60524-emby-for-samsung-smart-tv-updates/ Thanks guys.
Luke 42239 Posted May 28, 2019 Posted May 28, 2019 Emby for Samsung Tizen 1.0.61 has been released for 2015-2019 models. Please try it out and stay tuned to the blog for release notes. Thanks !
Luke 42239 Posted June 30, 2019 Posted June 30, 2019 For those interested, Install from USB: https://emby.media/community/index.php?/topic/74969-samsung-tizen-install-from-usb/
