aahmyu 9 Posted January 12, 2018 Posted January 12, 2018 (edited) Hello. whenever i add a movie they don't show in the latest movies section. tv shows work fine. what can i do to fix this? edit: they movies get added to the library but they don't show in the latest movies. thanks Edited January 12, 2018 by aahmyu
PenkethBoy 2068 Posted January 12, 2018 Posted January 12, 2018 have you run a scan? do you have the real time monitor enabled for the movie library? if that does not help you are going to need to provide a log file and details of what you did etc
aahmyu 9 Posted January 12, 2018 Author Posted January 12, 2018 (edited) have you run a scan? do you have the real time monitor enabled for the movie library? if that does not help you are going to need to provide a log file and details of what you did etc No i don't have that option enabled to any library. Last thing i did yesterday was adding the Ex-machina. it shows in the library if search for it. but it doesn't show in the latest movies. Edited January 20, 2018 by aahmyu
Luke 42204 Posted January 12, 2018 Posted January 12, 2018 Under library -> advanced, check your date added behavior. by default this is set to the date created timestamp of the video file. What is the date created timestamp of this video file?
aahmyu 9 Posted January 12, 2018 Author Posted January 12, 2018 (edited) Under library -> advanced, check your date added behavior. by default this is set to the date created timestamp of the video file. What is the date created timestamp of this video file? Hmmm. its really weird. i checked the movie in the metadata manger and the date added was somehow set to October 2017. i changed it to the right date and it showed in the latest movies. in the library settings it set to use file creation date. probably i should use time scanned to the library instead of file creation date. Edited January 12, 2018 by aahmyu
Luke 42204 Posted January 12, 2018 Posted January 12, 2018 You could do that. But to answer the "somehow" question. Check the date created timestamp of the file. Or if you added the file with a pre-existing nfo, maybe the nfo had an added value inside. If the nfo has an added value, that gets priority over everything, including the setting.
