Hiller131 0 Posted January 12, 2018 Posted January 12, 2018 Emby has been running great on my WHS 2011 machine until today when I tried to update the Emby server. I first attempted to update through the dashboard and then realized that was incorrect. I then used the installer from the website but it didn't seem to complete. I have now tried to uninstall and reinstall. The install log claims it has installed but it still will not start. I have also tried the stand alone version with the same result. I never get the server to start. Attached is the install log.
Luke 42204 Posted January 12, 2018 Posted January 12, 2018 Hi there did you forget to attach the log? Thanks.
Hiller131 0 Posted January 12, 2018 Author Posted January 12, 2018 Never clicked attach after I browsed for it. Sorry about that! server-install.log
Solution Happy2Play 9802 Posted January 12, 2018 Solution Posted January 12, 2018 Is your WHS2011 server up to date with Windows updates? I don't have any issues on my 2 WHS systems. 1
Hiller131 0 Posted January 12, 2018 Author Posted January 12, 2018 I can't believe it but the updates were the key. Thank you Happy2Play!
Happy2Play 9802 Posted January 12, 2018 Posted January 12, 2018 Would appear to follow the same rules as Windows 7.. * Supports Windows 7 SP1 or newer version of Windows. If running Windows 7 please make sure Windows Updates are fully up to date.
