Wishmaster20 1 Posted January 11, 2018 Posted January 11, 2018 I have the following problem. I'm with a friend and install Emby Theater with him. I've created an account for him and authorized him on my server, I can see the cloud. When I log in to the theater with Emby Connect, I see the server and select it. Unfortunately, the theater does not combines. I only see a spinning circle. If I log in with my data via Emby Connect then Its the same. If my friend logs in via the mobile app, his account will be processed without any problems. I have tried this now with several PCs and several accounts. The result was always the same. Unfortunately, another friend now reports that he has the same problem accessing my server, he had no problems two days before. The mobile app works for him without problems. If I connect the Theater with the server manually with the IP then that works without problems, until I get a new IP. I also used Emby Theater recently on vacation because I had no problems. Is this a known problem? THX Wish
Luke 42243 Posted January 11, 2018 Posted January 11, 2018 Hi there, please try again and see if the issue persists, thanks !
