ajalfon 0 Posted January 11, 2018 Posted January 11, 2018 My Remote (WAN) access address changes between 2 ip addresses for seemingly no reason? Is there a way to make this static? Or any insight into why it changes?
Luke 42239 Posted January 11, 2018 Posted January 11, 2018 Hi, are you running behind a VPN? That could be why. Yes you can customize your remote address under the Advanced section. Please let us know if this helps. Thanks.
ajalfon 0 Posted January 11, 2018 Author Posted January 11, 2018 I am, and I thought that might be it, but when I get off the VPN the address doesn't change back. The field you are referring to in the advanced section is Bind to local network address, correct?
Luke 42239 Posted January 11, 2018 Posted January 11, 2018 I am, and I thought that might be it, but when I get off the VPN the address doesn't change back. Sometimes it may just take a little while before emby realizes that, so that would explain that.
Luke 42239 Posted January 11, 2018 Posted January 11, 2018 The field you are referring to in the advanced section is Bind to local network address, correct? No, it is the external domain.
Jason'sEmby 29 Posted June 4, 2019 Posted June 4, 2019 Hi @@Luke so to stop my wan from changing intermittently do I put that under remote IP address filtering and just paste the wan ip in there? Or should my wan not change intermittently? I was testing out a new router but I put my old one back but my wan changed. I also removed my DNS and I'm using my IP providers DNS. This is all to optimize my upload speeds and latency. Thank you.
Luke 42239 Posted June 4, 2019 Posted June 4, 2019 If your wan address is changing then you may want to consider a ddns.
Jason'sEmby 29 Posted June 4, 2019 Posted June 4, 2019 That's probably what caused it. I change the DNS from Google's DNS to my service provider to try to clear up any network issues. So far things are running smooth. Hopefully They Dont Change by wan multiple times:) Thank you!
trevorkuznak 0 Posted August 8, 2021 Posted August 8, 2021 Hi - my WAN keeps changing and I’m using a macOS. My LAN is static but every time I restart my Mac the WAN changes. How do I keep that from changing? I am unable to find Advanced and the Hosting settings.
Luke 42239 Posted August 8, 2021 Posted August 8, 2021 11 minutes ago, trevorkuznak said: Hi - my WAN keeps changing and I’m using a macOS. My LAN is static but every time I restart my Mac the WAN changes. How do I keep that from changing? I am unable to find Advanced and the Hosting settings. Hi, probably because your remote address is actually changing and emby server is just displaying the new value. Have you looked into this?
