Question Regarding Cache and Snapshots
I'm restructuring my ZFS root pool at the moment to optimise things a bit more for offsite send/receive. In regards to Emby I have /var/lib/emby/transcoding-temp as it's own dataset, which is excluded from snapshots for obvious reasons.
I was just wondering if there will be any consequences of also doing the same for the cache directory i.e if I restore a snapshot that includes and empty cache directory - will Emby continue to function?
Thanks
yes it should be fine.
  • Like 1
