Emby for kodi Best Pratice
Hello guys,
I'm looking for the best configuration for my kodi clients.
Specialy for Sync Options, what is the best configuration to have less connections hamming the server and a good sync speed.
What it seems Max of items per one and Number of Threads?
Angelblue05
Are you referring to the initial sync? Otherwise, are you getting a lot of updates?
Sent from my iPhone using Tapatalk
I have around 400 updates per day. and Yes the initial sync is hamming my server and do slow respond from the server and then lost a lot of videos during sync
I don't know what is actualy a update cause I do nothing and I have movies updates every day. I'm using strm file only with direct path to a ftp server
Guest
