mbnwa 49 Posted March 2, 2018 Author Posted March 2, 2018 (edited) @@Zodler As far as converting MKV to MP4 if you have a Mac you can use Subler as it sets the correct flags for the Apple TV - Keep in mind converting to MP4 with Subler you will lose all HD / DTS tracks as they will be converted to AC3 or AAC A few threads are going on about HDR -> SDR conversion but they are just discussions at this point and take quite the CPU power due to being single threaded to perform the tone mapping. Keep in mind with Apple being a walled garden what they support is limited and I think based on what @@ebr stated that’s why the Apple TV transcodes vs trying to play something the Apple TV would fail to play Sent from my iPhone using Tapatalk Edited March 2, 2018 by mbnwa
Zodler 18 Posted March 2, 2018 Posted March 2, 2018 I do not want to convert HDR to SDR. I'm on windows. I need a windows MKV to MP4 solution. Infuse or MrMC can play them, so Emby app should too.
mbnwa 49 Posted March 2, 2018 Author Posted March 2, 2018 @@Zodler Your still limited to what the Apple TV can play natively that’s where the issue comes in not all H265 / HEVC MKVs are created equal. I don’t know a way to properly object the required flag into the MKV container so the Apple TV would see it. However maybe @@ebr has some additional details I am missing. Sent from my iPhone using Tapatalk
mbnwa 49 Posted March 2, 2018 Author Posted March 2, 2018 As a side note I ended up replacing my Apple TV with Nvidia Shield now I have HDR and Atmos as well as Dolby HD Sent from my iPhone using Tapatalk 2
chriskeens 5 Posted March 3, 2018 Posted March 3, 2018 (edited) maybe the file that is not working correctly has the codec tag - hev1 instead of hvc1 try using a hex editor (use the find/replace function) to search for hev1 and replace with hvc1 - then save it ... this has worked with most issues of similar type that I have had Edited March 3, 2018 by chriskeens
Zodler 18 Posted March 6, 2018 Posted March 6, 2018 As a side note I ended up replacing my Apple TV with Nvidia Shield now I have HDR and Atmos as well as Dolby HD Sent from my iPhone using Tapatalk 1- Do you have that with Emby client? 2- Another question, Can you convert HDR to SDR on the fly on nVidia Shield?
mbnwa 49 Posted March 6, 2018 Author Posted March 6, 2018 Correct this is with the native Emby app for Android TV, no it’s not doing HDR to SDR conversion but it passes the HDR data along with the stream and my OLED is decoding it as long as Emby is not transcoding. Sent from my iPhone using Tapatalk
Luke 42239 Posted March 6, 2018 Posted March 6, 2018 With the beta server this should no longer be lost on the direct stream, assuming you follow the instructions here: https://emby.media/community/index.php?/topic/56614-3305-video-range-info/ Thanks. 1
Zodler 18 Posted March 6, 2018 Posted March 6, 2018 Correct this is with the native Emby app for Android TV, no it’s not doing HDR to SDR conversion but it passes the HDR data along with the stream and my OLED is decoding it as long as Emby is not transcoding. Sent from my iPhone using Tapatalk Thanks. I installed and am using mrmc on apple tv as Emby Client. It has 3 major things that the official Emby app can't do. 1- It switches the TV to HDR on HDR playback 2- It has much better and more beautiful subtitle renderings 3- It can do HDR to SDR conversion. If I set the Apple TV to not match color range, it can play back HDR content in SDR.
ebr 16332 Posted March 6, 2018 Posted March 6, 2018 1- It switches the TV to HDR on HDR playback As noted above your post, with the new server, the Emby app can do this as well (for direct streaming). 1
andyblac644 69 Posted March 7, 2018 Posted March 7, 2018 As noted above your post, with the new server, the Emby app can do this as well (for direct streaming). but AppleTV wont DirectStream 4k HDR MKV will it?, anyway if it supposed too, none of my UHD remuxes play with HDR.
corey 317 Posted March 7, 2018 Posted March 7, 2018 but AppleTV wont DirectStream 4k HDR MKV will it?, anyway if it supposed too, none of my UHD remuxes play with HDR. Are you using the latest server beta?
andyblac644 69 Posted March 7, 2018 Posted March 7, 2018 Are you using the latest server beta? using Version 3.3.1.1 beta, i'll 3.2.1.2 now.
andyblac644 69 Posted March 7, 2018 Posted March 7, 2018 @@corey same result, server is transcoding i'll pm your logs
corey 317 Posted March 7, 2018 Posted March 7, 2018 (edited) We’ll most likely have to get @@ebr and @@Luke involved in this conversation as well. Edited March 7, 2018 by corey
andyblac644 69 Posted March 7, 2018 Posted March 7, 2018 (edited) should it be able to DS the video and only transcode audio ? as most HDR are not DD5.1, but DTS, DDP, TrueHD, etc Edited March 7, 2018 by andyblac644
andyblac644 69 Posted March 7, 2018 Posted March 7, 2018 (edited) @@corey logs sent, but here what I get TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc Video Title 4K HEVC Codec HEVC Profile Main 10 Level 153 Resolution 3840x2160 Aspect ratio 16:9 Anamorphic No Interlaced No Framerate 23.9760246 Bitrate 45826 kbps Video range HDR Color primaries bt2020 Color space bt2020nc Color transfer smpte2084 Pixel format yuv420p10le Ref frames 1 Audio Title Eng DTS 5.1 Default Language eng Codec DTS Profile DTS-HD MA Layout 5.1 Channels 6 ch Sample rate 48000 Hz Bit depth 16 bit DefaultYes Subtitle Title Eng Language eng Codec PGSSUB Default No Forced No External No Container mkv Edited March 7, 2018 by andyblac644
corey 317 Posted March 7, 2018 Posted March 7, 2018 Apple is very particular about the supported codec and I think the tag needs to be hvc1 and not hevc. @@ebr can keep me honest though.
ebr 16332 Posted March 7, 2018 Posted March 7, 2018 The codec is okay but there needs to be a codec tag of "hvc1" and that appears to be missing. Also, be sure the subs aren't selected as those will obviously cause a transcode as well.
andyblac644 69 Posted March 7, 2018 Posted March 7, 2018 (edited) The codec is okay but there needs to be a codec tag of "hvc1" and that appears to be missing. Also, be sure the subs aren't selected as those will obviously cause a transcode as well. how do i add the tag to a MKV file ?, yeah no subs where selected. surely it should be added as part of the remux by server for DS ? Edited March 7, 2018 by andyblac644
Guest asrequested Posted March 11, 2018 Posted March 11, 2018 I stumbled on this, maybe it'll help? https://github.com/donmelton/video_transcoding/issues/160
Luke 42239 Posted October 22, 2025 Posted October 22, 2025 Hi, HDR playback has been improved in Emby for Apple TV 2.0.1. Thanks !
