No Subs or Audio Selection
Spaceboy
Hi, is it know than currently it is not possible to select alternate audio tracks or any subs using mediaportal as an external provider? the options do not show up in the OSD on either web client or on android tv.
i don't believe i have anything set in the plugin config that would result in this.
We're looking into it, thanks.
Spaceboy
no problem, hopefully you will have libmpv working for Android TV soon so we can see what impact that has too
