acroninj 0 Posted August 18, 2022 Posted August 18, 2022 (edited) I just cleared 400,000 directories and files from the transcode directory last night after most of my docker services crashed when the hard drive was full. The server has been restarted may times, so something is not right. Is there a setting built in that will wipe these out after 24 hours? Edited August 18, 2022 by acroninj
Happy2Play 9814 Posted August 18, 2022 Posted August 18, 2022 1 minute ago, acroninj said: I just cleared 400,000 directories last night after most of my docker services crashed when the hard drive was full. The server has been restarted may times, so something is not right. Is there a setting built in that will wipe these out after 24 hours? No there is no setting for this, only a server restart has some behind the scenes process. But have never seen or heard of it not work on restart. I have seen empty directories. Unless this is a platform specific issue.
Luke 42290 Posted September 1, 2022 Posted September 1, 2022 On 8/18/2022 at 9:51 AM, acroninj said: I just cleared 400,000 directories and files from the transcode directory last night after most of my docker services crashed when the hard drive was full. The server has been restarted may times, so something is not right. Is there a setting built in that will wipe these out after 24 hours? @acroninj are you still having an issue with this? Can you please provide an example? Thanks !
acroninj 0 Posted September 1, 2022 Posted September 1, 2022 My server restarts every night at 4am. Ever since I discovered this issue of the transcode directory not emptying, I try to remember to manually empty it. Attached is what I have stuck in there today after not touching it for a week. Devices used to stream are NVidia Shields, FireSticks, Roku's, PCs, etc.
Happy2Play 9814 Posted September 1, 2022 Posted September 1, 2022 I know I cannot reproduce Emby not clearing this folder upon restart on Windows. But at the same time I would expect many more Docker users to have this issue if it were a platform specific issue. But logs are needed showing those session id. Not sure this temp folder cleanup is logged at all during a restart.
acroninj 0 Posted October 6, 2022 Posted October 6, 2022 Server crashed due a different issue, but after reboot I looked at disk space and transcoding-temp had 12.9GB today. embyserver.txt
