shred00 13 Posted January 8, 2018 Posted January 8, 2018 If I have multiple Emby user accounts all using the same Trakt account do I need to populate the PIN in the Trakt plugin for each Emby user with a different PIN from Trakt or can/should they all use the same PIN?
Luke 42253 Posted January 8, 2018 Posted January 8, 2018 Yes you need to do them all separately. Thanks.
Jdiesel 1439 Posted January 8, 2018 Posted January 8, 2018 Would it be possible to allow non-admin users to enter their Trakt credentials themselves by having it in the user preference menu? Right now the only way of doing it is for the user to provide their login details to the server admin and have them manage the login. In the event of a password change they would have to provide an updated password to the server admin.
shred00 13 Posted January 8, 2018 Author Posted January 8, 2018 Yes you need to do them all separately. Thanks. And so just to be clear, it's not a problem having multiple PINs outstanding against that one Trackt account all waiting for each Emby user (who are all using the same Trakt account) to connect to play something so that they log to trakt for the first time with that PIN, correct?
Luke 42253 Posted January 8, 2018 Posted January 8, 2018 The trakt plugin is a community addition and I'm not quite an expert with how it works, but i think that's what other people are doing.
