Happy2Play 9802 Posted January 8, 2018 Posted January 8, 2018 (edited) Ok, latest logs attached. This morning, I went into Metadata Manager, and added the Original & Sort titles to American Horror Story. Saved and then loaded Emby Theater. I navigated to the show via TV & then selected several actors to see if the metadata would appear. Nothing showing. Well that is a bad show to test with as all the seasonnumbers added to the actor there will be no metadata. Issue with this series each actor has different role in every season. Edited January 8, 2018 by Happy2Play
Aussiedroid 56 Posted January 8, 2018 Author Posted January 8, 2018 Ah just my luck starting at 'A' Ok tried another show Seinfeld. Updated all the Titles to ensure they are populated, refreshed and saved. Same behaviour being seen. Updated log attached. I tried to go into the 4 main actors to see if the metadata would show. Same result as AHS. Log.txt
Luke 42212 Posted January 8, 2018 Posted January 8, 2018 Ok for starters, since you're on 3.2.50 I would suggest updating to the latest version of emby server, then try again. Thanks.
Aussiedroid 56 Posted January 8, 2018 Author Posted January 8, 2018 (edited) Thanks for the reminder Luke. Have just updated & reattempted on Seinfeld but still the same. Cleaner log attached. From what I can see it is attempting to fetch the data: 2018-01-09 09:57:45.504 Debug App: Running PersonXmlProvider for /volume1/Backups/Emby Server Data/metadata/People/J/Jerry Seinfeld2018-01-09 09:57:45.507 Debug App: PersonXmlProvider returned no metadata for /volume1/Backups/Emby Server Data/metadata/People/J/Jerry Seinfeld2018-01-09 09:57:45.515 Debug App: Running MovieDbPersonProvider for /volume1/Backups/Emby Server Data/metadata/People/J/Jerry Seinfeld ... 2018-01-09 09:57:46.534 Debug App: MovieDbPersonProvider returned no metadata for /volume1/Backups/Emby Server Data/metadata/People/J/Jerry Seinfeld Although there seems to be data present via website: https://www.themoviedb.org/person/16377-jerry-seinfeld Log.txt Edited January 8, 2018 by Aussiedroid
Luke 42212 Posted January 9, 2018 Posted January 9, 2018 I already mentioned earlier, if we don't have the MovieDb Id for the person, then we don't search by name. The moviedb id is obtained when we download the metadata from a movie or series that the actor appears in.
Aussiedroid 56 Posted January 9, 2018 Author Posted January 9, 2018 Thanks for explaining this. Will doing a refresh metadata for 'search for missing metadata' resolve the missing MovieDB person IDs? or are these only created when a new show metadata being downloaded from scratch?
Aussiedroid 56 Posted January 9, 2018 Author Posted January 9, 2018 Righto, made it home and given the above suggestion a try. No change It does not appear to be updating the nfo file at all (date/time remains from this morning). I have tried searching for missing metadata in both the metadata manager and via Emby Theater. Next I renamed the tvshow.nfo to remove the existing metadata and rescan anew. Completed a library scan, but the data remains in the metadata manager when I check (even with the file removed). I try replace all metadata & no nfo file is being created. I tried to view actors again at this point but nothing has changed, still no data showing. Not sure where it is sourcing or storing the data. I don't know if this may even relate to the main issue at this point or there is something else prevent the refresh.
Luke 42212 Posted January 9, 2018 Posted January 9, 2018 unfortunately the settings we offer create a lot of scenarios that are difficult to test. i would try putting all metadata settings back to default. thanks.
Aussiedroid 56 Posted January 9, 2018 Author Posted January 9, 2018 I understand I'll troubleshoot it further my end and try some different settings and see if I can get it to work. Really appreciate your help trying to solve this. Been working through a few minor issues over past few weeks that have been left unchecked for far too long, and the great knowledge around these forums has pretty much got them all solved! This bugbear seems to be the troublesome one. there's no support for any kind of people.nfo file. fatal (the metabrowser developer) asked me to do this a while back but i never got to it. at this point i would just rely on emby for metadata and you'll be fine. Regarding the above, I just tried a quick test, & simply renaming the people.nfo to people.xml and the data for the actors displays fine. A possible workaround could be to do a bulk rename of all the people.nfo files (if I can find a reliable way to do it for the entire folder/sub-folders) after they are created to xml for the Emby XML plugin to read it. Got me thinking if a simple solution here could be to add the .nfo file extension to be supported by the XML plugin for the actors? Search for xml file first but if not found read the nfo file if present? Cheers, AD
maximilianh75 19 Posted August 10, 2018 Posted August 10, 2018 (edited) Only for be clear, in the past emby added person.xml for any actor added in people folder in metadata. These feature never added again, because i can modify actor metadata but only saved in library.db file and i don't have any backup of it Edited August 10, 2018 by maximilianh75
Luke 42212 Posted August 10, 2018 Posted August 10, 2018 You can install the legacy XML metadata plugin if you really need that.
Happy2Play 9802 Posted August 10, 2018 Posted August 10, 2018 You can install the legacy XML metadata plugin if you really need that. Sorry the plugin doesn't do metadata..
Luke 42212 Posted August 10, 2018 Posted August 10, 2018 Maybe I'm forgetting again but i thought it had person.xml support.
Happy2Play 9802 Posted August 10, 2018 Posted August 10, 2018 Maybe I'm forgetting again but i thought it had person.xml support. Wasn't able to find the topic with a quick search, but I believe everything is commented out.
pünktchen 1410 Posted August 10, 2018 Posted August 10, 2018 Wasn't able to find the topic with a quick search, but I believe everything is commented out.True.
maximilianh75 19 Posted August 10, 2018 Posted August 10, 2018 Maybe I'm forgetting again but i thought it had person.xml support. I saw it in some post but i don't remember exactly where?
Luke 42212 Posted August 10, 2018 Posted August 10, 2018 I think happy 2 play is right that it is disabled, but I don't have the bandwidth to dive back into it. New contributors to the plugin are welcome.
