CatSama 1 Posted January 8, 2018 Posted January 8, 2018 (edited) It seems like Emby always use the old cache data instead of download the newest. I can see this problem everyway. For example, I have a movie that I can't find any info from TheMovieDb, so emby used "screen grabber" to generate a screenshot as the movie‘s poster. Now I added this movie’s info to TheMovieDb,and "Identify" this movie again, I can see the info I added, but when I try to download this info, I found emby still use the screenshot as the poster. I "Edite images" and deleted this screenshot and try again, still the same result. Not just the movie's poster,the cache problem also happend in picture's metadata. I have a picture named "A.jpg",and it has a metadata of title "B". So when I put this picture in a picture library, emby will scan it's metadata and named this picture by "B". now I deleted the picture's metadata,and choose “Refresh metadata”,but the picture still named by "B". even I choose "edit info" and change the title from "B" to "A", but once I refresh this picture, the name back to "B". It also happend in some audios, I changed a audio's embedded image and "Refresh metadata",but it still display the old image. I really need this problem to be fixed,thanks. Edited January 8, 2018 by CatSama
Luke 42245 Posted January 8, 2018 Posted January 8, 2018 Emby will cache MovieDb data for up to a couple days, so if you just updated MovieDb, then give it a try in another day or so. Thanks.
CatSama 1 Posted January 8, 2018 Author Posted January 8, 2018 Emby will cache MovieDb data for up to a couple days, so if you just updated MovieDb, then give it a try in another day or so. Thanks. OK,but how to explain the picture's medata problem and the audio's embedded image problem I mentioned, I found these problem in 1/8/2018 and posted it in that time, now it's already a week,but the problem still there.
CatSama 1 Posted January 8, 2018 Author Posted January 8, 2018 Emby will cache MovieDb data for up to a couple days, so if you just updated MovieDb, then give it a try in another day or so. Thanks. Sorry,my bad. about the picture's medata problem ,I deleted the picture's metadata by "right-click" → "roperties",but it doesn't really delete them, I can still see the metadata by photoshop. So I deleted the metadata by photoshop,now it shows the right name.
