myriaxis 3 Posted January 8, 2018 Posted January 8, 2018 Hi, I just sent a log from the Emby for Roku app. Time: 2018-01-07 19:34 EST User: Francois Emby server : 3.2.60.0 Emby for Roku : 3.0.54 I created a mkv file (Blade Runner 2049) encoded with Handbrake (x265 10 bits, CRF 23, HE-AAC 5.1 bitrate 256). When played on my Roku 3 with the Emby for Roku app, the audio low frequencies sound like cracking noises. When played on my Roku 3 with the Blue Neon app, it's not as bad, but I hear cracking noises also. When played on the Web App, it plays fine. When played on VLC, it plays fine. Where should I start to fix this playback problem? Thanks
Luke 42243 Posted January 8, 2018 Posted January 8, 2018 Can you also attach the emby server and ffmpeg log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
myriaxis 3 Posted January 8, 2018 Author Posted January 8, 2018 Hello Luke, Here are the files. In the server log, I see a lot of DLNA error reports. Should I be concerned? server-63650880000.txt ffmpeg-transcode-3c7aab20-05c9-42d9-8973-e325ad852014.txt ffmpeg-transcode-3cd6f5b7-395a-4d30-af75-fbe5df9a06ec.txt
Luke 42243 Posted January 8, 2018 Posted January 8, 2018 As a test, can you go into server transcoding settings and change the audio downmix boost from 2 to 1? See if that makes a difference. thanks.
myriaxis 3 Posted January 12, 2018 Author Posted January 12, 2018 Hello Luke, Sorry for the long delay. Changing the audio downmix boost from 2 to 1 in the transcoding options of the Emby Server seems to solve the problem. I'll test it with other mkv files to confirm. Thanks.
