Jdiesel 1435 Posted January 7, 2018 Posted January 7, 2018 If a channel has no program info it can not be played from the grid guide on the Roku app. You must go to the "All channels" view to play the channel. On the Android TV app you are able to select and play channels with no program info from the grid guide.
mix123 1 Posted January 6, 2019 Posted January 6, 2019 It appears this is still like this. It's super annoying to be honest.
Luke 42242 Posted January 7, 2019 Posted January 7, 2019 We'll add this to our internal tracker for the roku app @@speechles. Thanks !
all4dom 101 Posted January 7, 2019 Posted January 7, 2019 same thing & this time i tried it in the emby server itself. its a server issue im believing now. In emby server after I hit play, it just spins & spins but does not play. I have to just shut the browser. Log1.txt Log2.txt
all4dom 101 Posted January 7, 2019 Posted January 7, 2019 if you cant fix it, does emby have an uninstall button. im going to delete & reinstall tomorrow while my daughter is in school. Shes special needs and these episodes that are not playing are aome of the onbly ones she watches.
all4dom 101 Posted January 7, 2019 Posted January 7, 2019 i have to have everythiung working by the time she comes home from school tomorrow. Im even havinbg an issue with playon so im thinking something with this new install is not working right. As i said, before i had to wipe my pc clean, emby was working 100% fine.
speechles 2062 Posted January 7, 2019 Posted January 7, 2019 (edited) The channel with no program info from guide will not play has been added to the issue tracker. ( Reference: Issue #177: Can't play channel with no program info from guide ) @@Luke any ideas for the fellow in the post above mine. Appears to affect web client as well as Roku. Edited January 7, 2019 by speechles
all4dom 101 Posted January 7, 2019 Posted January 7, 2019 And firestick also. I'll just do a clean install tomorrow morning & keep my fingers crossed.
Luke 42242 Posted January 7, 2019 Posted January 7, 2019 Is there a problem perhaps with your D: drive?
all4dom 101 Posted January 7, 2019 Posted January 7, 2019 I dont think that's it because my tv shows play fine & they are on that drive. I'll do the reinstall & update.
