Angelblue05 4132 Posted January 25, 2018 Posted January 25, 2018 Well, I suggest you switch to Embycon if possible. For sure if your server keeps doing this, you'll always see it in Emby for Kodi.
sualfred 677 Posted January 25, 2018 Posted January 25, 2018 (edited) I'm just curious: How does your folder structure, file namings and .nfo look like? I don't get why Emby uses a year value for a season number Oo Edited January 25, 2018 by sualfred
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 Well, I suggest you switch to Embycon if possible. For sure if your server keeps doing this, you'll always see it in Emby for Kodi. But switching to Embycon doesn't change the fact that there is a bug in the fast sync in Emby. I guess I'd hope we'd rather find and fix the bug than to paper over it by just using another tool. 1
Angelblue05 4132 Posted January 25, 2018 Posted January 25, 2018 (edited) There's no bug in the fast sync. The server generates all the updates, the fast sync just records this so the add-on in Kodi can quickly find what's been modified on your server. Edit: But I understand your sentiment. I want to fix this too for you. But we need to find what's causing the server to constantly create those entries. It is not normal. Edited January 25, 2018 by Angelblue05
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 I'm just curious: How does your folder structure, file namings and .nfo look like? I don't get why Emby uses a year value for a season number Oo That happens because my recordings are being recorded from TV (not using Emby, but something different) and the metadata for a program is not known before it starts recording so it has to name the season with something so it uses the year as a placeholder. Then the recording starts writing into a file in that folder and once the recording starts metadata lookup is done. Once the metadata lookup has completed the file/folder is renamed into the proper season/episode. Sometimes the metadata lookup fails though and so the file gets left in the year-named folder. But why should have year-based Season folders be a problem? If it is a problem, it shouldn't be and that needs to be fixed. Some shows actually use a year-based season naming structure so this needs to be supported. 1
Angelblue05 4132 Posted January 25, 2018 Posted January 25, 2018 (edited) Season with the year is fine to use. I use that format for my daily shows. @@Luke With the info provided by shred00 just above, does that explain why Emby is doing what it is doing? Edited January 25, 2018 by Angelblue05
sualfred 677 Posted January 25, 2018 Posted January 25, 2018 Ah ok. I never faced such season namings. My recordings are all stored in one folder and get deleted as soon as they are watched (all controlled by TVHeadend and not by Emby). And my shows have S01/S02/S03/etc, but now I understand why the year is used. 1
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 What is worth adding I think is that these recordings that have season as year instead of actual season number, there is no .nfo file for them. Could recordings without .nfo files be a cause of this problem? 1
Luke 42208 Posted January 25, 2018 Posted January 25, 2018 Those log messages are going to happen sometime so just the presence of them in one single log does not indicate a problem. The only thing that would be a problem is if the same ones are being created and removed repeatedly.
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 For a 24h period here is all of the Creating/Deleting log records: 2018-01-24 04:03:16.741 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 04:03:17.092 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 0fec914e-4904-7925-5594-f6a1884d82d3 2018-01-24 04:03:17.794 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 04:03:19.083 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 0fec914e-4904-7925-5594-f6a1884d82d3 2018-01-24 04:03:39.615 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 04:03:39.771 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 7bbfa3a7-ce1a-8c8c-d2f8-615e2f0815c3 2018-01-24 04:03:40.205 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 04:03:40.350 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 7bbfa3a7-ce1a-8c8c-d2f8-615e2f0815c3 2018-01-24 04:04:52.828 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 04:04:52.981 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 3d3ba72d-95e7-a5c3-cdf7-1d7e1f1f179f 2018-01-24 04:04:53.332 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 04:04:53.399 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 3d3ba72d-95e7-a5c3-cdf7-1d7e1f1f179f 2018-01-24 10:44:17.285 Info App: Deleting item, Type: Season, Name: Season 42, Path: /storage1/Mom & Dad/the fifth estate/Season 42, Id: c06fddd2-3102-bba8-d049-67c19ac4c7db 2018-01-24 10:44:18.495 Info App: Deleting item, Type: Season, Name: Season 43, Path: /storage1/Mom & Dad/the fifth estate/Season 43, Id: 65f9a649-be28-5f6f-55b2-02094487fd64 2018-01-24 10:44:46.138 Info App: Creating Season Season 2014 entry for The Simpsons 2018-01-24 10:44:46.317 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 10:44:46.515 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 0c4c6d01-a2d4-6df9-ce28-6e687e29f912 2018-01-24 10:44:46.557 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 8b52e96b-b624-344d-a697-a5ecaa510c13 2018-01-24 10:45:00.443 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 10:45:00.586 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 0fec914e-4904-7925-5594-f6a1884d82d3 2018-01-24 10:45:01.232 Info App: Creating Season Season 2013 entry for Cougar Town 2018-01-24 10:45:01.959 Info App: Deleting item, Type: Season, Name: Season 2013, Path: , Id: e1bcba65-b709-6bb5-4ba7-d295e2e54396 2018-01-24 10:45:02.750 Info App: Creating Season Season 2017 entry for The American Woodshop 2018-01-24 10:45:03.256 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 386fd359-3aa8-eb8b-864c-6999eab42d31 2018-01-24 10:45:03.859 Info App: Creating Season Season 2016 entry for X Company 2018-01-24 10:45:04.162 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: ad04a07d-87e4-2d9c-6332-1752f1ff4e65 2018-01-24 10:45:04.410 Info App: Creating Season Season 2014 entry for Holmes on Homes 2018-01-24 10:45:05.127 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 4d9a88f4-e4dc-c894-de49-1d86d72fd3df 2018-01-24 10:45:32.045 Info App: Creating Season Season 2013 entry for Woodsmith Shop 2018-01-24 10:45:32.751 Info App: Creating Season Season 2016 entry for Woodsmith Shop 2018-01-24 10:45:32.905 Info App: Creating Season Season 2017 entry for Woodsmith Shop 2018-01-24 10:45:32.997 Info App: Deleting item, Type: Season, Name: Season 2013, Path: , Id: 96199eb6-dd6b-824a-1f0f-9f26cf5c891e 2018-01-24 10:45:33.000 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 8e15cac2-7577-cd87-2179-17ec6af71c39 2018-01-24 10:45:33.002 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 683f34c2-8c85-dc2d-386a-5036fece3d92 2018-01-24 10:45:33.567 Info App: Creating Season Season 2016 entry for Rough Cut - Woodworking with Tommy Mac 2018-01-24 10:45:34.116 Info App: Creating Season Season 2017 entry for Rough Cut - Woodworking with Tommy Mac 2018-01-24 10:45:34.318 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 1714368e-7bc2-91b6-d366-55a6e3eee354 2018-01-24 10:45:34.321 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: d7b45148-8532-3a40-b144-1af1e9a1bc67 2018-01-24 10:45:34.568 Info App: Creating Season Season 2017 entry for The West BLock 2018-01-24 10:45:35.029 Info App: Creating Season Season 2018 entry for The West BLock 2018-01-24 10:45:35.155 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 278977b4-3a80-771e-5784-e2c96351be83 2018-01-24 10:45:35.187 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 9607554d-b573-d00e-5fb1-8c5d2571e468 2018-01-24 10:45:38.921 Info App: Creating Season Season 2015 entry for Marketplace 2018-01-24 10:45:38.994 Info App: Creating Season Season 2016 entry for Marketplace 2018-01-24 10:45:39.041 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 7333fd5a-e14a-d029-e18b-55122f3574e9 2018-01-24 10:45:39.044 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 0eaf6c83-2bed-2357-54dc-343dda76f6a5 2018-01-24 10:45:39.831 Info App: Creating Season Season 2017 entry for Marketplace 2018-01-24 10:45:39.989 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: edb91b2b-d118-c1ac-9248-4362482a5ecb 2018-01-24 10:45:41.568 Info App: Creating Season Season 2016 entry for X Company 2018-01-24 10:45:41.655 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 07b85f54-5870-69de-1da9-07ff8ad4ac6a 2018-01-24 10:45:44.256 Info App: Creating Season Season 2015 entry for You Gotta Eat Here! 2018-01-24 10:45:44.601 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 6d302ce9-b815-0837-cd5e-116ff7dc5085 2018-01-24 10:45:44.949 Info App: Creating Season Season 2016 entry for Duck Dynasty 2018-01-24 10:45:45.147 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: ea0aa056-ecb9-151c-af27-8059facd3611 2018-01-24 10:45:45.613 Info App: Creating Season Season 2014 entry for Vikings 2018-01-24 10:45:45.700 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 10:45:45.796 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 8b67a343-b49e-3b44-4990-46aaa6d80f31 2018-01-24 10:45:45.798 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 56536c3e-058f-ed29-a112-4ee10fc54896 2018-01-24 10:45:46.127 Info App: Creating Season Season 2017 entry for The Mayor 2018-01-24 10:45:46.231 Info App: Creating Season Season 2018 entry for The Mayor 2018-01-24 10:45:46.361 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: de833798-f712-d670-eddc-61129c729c5a 2018-01-24 10:45:46.380 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 4a22d00b-efd8-a547-1cd6-10f28d3d41f1 2018-01-24 10:45:46.682 Info App: Creating Season Season 2017 entry for Young Sheldon 2018-01-24 10:45:46.813 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: dc37fbb8-1a73-f23d-2005-241d3e6d3072 2018-01-24 10:45:47.489 Info App: Creating Season Season 2016 entry for Duck Dynasty 2018-01-24 10:45:48.110 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: acb57813-8aef-92fc-5d33-cebe4390054f 2018-01-24 10:45:49.266 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 10:45:49.381 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 3d3ba72d-95e7-a5c3-cdf7-1d7e1f1f179f 2018-01-24 10:45:57.455 Info App: Creating Season Season 2017 entry for The Ellen DeGeneres Show 2018-01-24 10:45:57.936 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 50386549-2f6c-ccf1-0be2-43f2a91dd4ab 2018-01-24 10:46:02.910 Info App: Creating Season Season 2015 entry for Black-ish 2018-01-24 10:46:03.123 Info App: Creating Season Season 2017 entry for Black-ish 2018-01-24 10:46:04.042 Info App: Creating Season Season 2018 entry for Black-ish 2018-01-24 10:46:04.429 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: a212151e-0bae-e78a-9cf1-5a3fd74af134 2018-01-24 10:46:04.431 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: ebead07f-b256-9b30-fab2-df7f95d24d54 2018-01-24 10:46:04.486 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 1339a16a-feff-d785-8f61-b81b4c5391c7 2018-01-24 10:46:06.718 Info App: Creating Season Season 2016 entry for Paw Patrol 2018-01-24 10:46:06.927 Info App: Creating Season Season 2017 entry for Paw Patrol 2018-01-24 10:46:07.005 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: d99a602d-01a0-a6bf-3bd3-7892a1f11296 2018-01-24 10:46:07.008 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 1e94018e-a883-71b2-a52b-2eabf69540f2 2018-01-24 10:46:07.331 Info App: Creating Season Season 2015 entry for Barney and Friends 2018-01-24 10:46:07.501 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 1ffa667b-ba1a-b98b-9517-0c0a135e4c6d 2018-01-24 10:46:08.310 Info App: Creating Season Season 2016 entry for 16x9 2018-01-24 10:46:08.373 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: e4bd846f-7719-c977-601e-1bf467b3c27a 2018-01-24 10:46:09.624 Info App: Creating Season Season 2014 entry for The Mentalist 2018-01-24 10:46:09.771 Info App: Creating Season Season 2015 entry for The Mentalist 2018-01-24 10:46:09.833 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 9e4e3634-2798-3818-2701-64a9f319a9e4 2018-01-24 10:46:09.851 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 8ce7f50b-1a61-1be5-745d-581d02c0831f 2018-01-24 10:46:12.433 Info App: Creating Season Season 2017 entry for The Disappearance 2018-01-24 10:46:12.547 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 02aad5af-1933-9397-c2aa-8123454e6ded 2018-01-24 10:46:13.867 Info App: Creating Season Season 2015 entry for CSI: Crime Scene Investigation 2018-01-24 10:46:14.144 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: ba2487a9-23a9-8ed2-33f6-5f3dddbbe1d0 2018-01-24 10:46:16.352 Info App: Creating Season Season 2017 entry for Ten Days in the Valley 2018-01-24 10:46:16.460 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: a6a75280-3066-1195-7a35-856c10b9b182 2018-01-24 10:46:17.931 Info App: Creating Season Season 2016 entry for Chicago Fire 2018-01-24 10:46:18.049 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: c4b1937b-91e7-7436-f2c5-009223d3674e 2018-01-24 10:46:21.751 Info App: Creating Season Season 2017 entry for W5 2018-01-24 10:46:21.859 Info App: Creating Season Season 2018 entry for W5 2018-01-24 10:46:21.983 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: e78c34c0-d9ac-7b15-f60d-f9aef63eb176 2018-01-24 10:46:22.904 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: c181468c-a3f9-4275-e1a0-08ead26a5283 2018-01-24 10:46:30.962 Info App: Creating Season Season 2015 entry for Saturday Night Live 2018-01-24 10:46:33.090 Info App: Creating Season Season 2016 entry for Saturday Night Live 2018-01-24 10:46:33.764 Info App: Creating Season Season 2017 entry for Saturday Night Live 2018-01-24 10:46:34.155 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 2d6406f6-f242-fa90-4343-485163d36167 2018-01-24 10:46:34.157 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 67044327-f5f8-f2af-201d-425e05024be4 2018-01-24 10:46:34.197 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 4b571ff1-5fa0-bf04-2d19-ad7adaf9f0d9 2018-01-24 10:46:35.750 Info App: Creating Season Season 2017 entry for Wisdom of the Crowd 2018-01-24 10:46:36.214 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: d4ef997b-87c1-0dff-97ca-f6a41c8f2d00 2018-01-24 10:46:38.315 Info App: Creating Season Season 2017 entry for The Good Doctor 2018-01-24 10:46:38.427 Info App: Creating Season Season 2018 entry for The Good Doctor 2018-01-24 10:46:38.488 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 0390a200-e4e6-013b-41fb-75f72ba7af7b 2018-01-24 10:46:39.525 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 7460c1cb-2d3e-a2e9-d630-e341628e84ac 2018-01-24 10:46:39.961 Info App: Creating Season Season 2017 entry for Kevin (Probably) Saves the World 2018-01-24 10:46:40.379 Info App: Creating Season Season 2018 entry for Kevin (Probably) Saves the World 2018-01-24 10:46:41.436 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 5a882ea0-6b54-03f4-0770-f71d764a14eb 2018-01-24 10:46:41.499 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 678d95da-0081-83e6-33c8-ae52a238c5d3 2018-01-24 10:46:41.821 Info App: Creating Season Season 2017 entry for SEAL Team 2018-01-24 10:46:41.913 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 5740f08f-7628-1655-f805-b85a492ad714 2018-01-24 10:46:45.841 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 10:46:45.988 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: ecf73f55-e2ba-74fc-24e4-8fa18c33fc52 2018-01-24 10:46:47.305 Info App: Creating Season Season 2018 entry for The National 2018-01-24 10:46:47.660 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 76251ef2-61e9-7c95-78a7-9cc5672a609b 2018-01-24 10:46:47.872 Info App: Creating Season Season 2017 entry for W5 2018-01-24 10:46:48.241 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 6375f482-cc50-e82b-1d88-160b32854f4b 2018-01-24 10:46:49.486 Info App: Creating Season Season 2017 entry for The Fifth Estate 2018-01-24 10:46:49.628 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 5dedac44-a7e3-321b-1ca3-568c5a84924e 2018-01-24 10:46:54.816 Info App: Creating Season Season 2016 entry for New Girl 2018-01-24 10:46:55.576 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: b2625f22-6da6-1880-d0f1-159a4742555b 2018-01-24 10:47:01.005 Info App: Creating Season Season 2018 entry for The National 2018-01-24 10:47:01.040 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: c0225206-9b25-04d6-2fe5-80dc93b73eab 2018-01-24 10:47:05.182 Info App: Creating Season Season 2016 entry for Chicago Fire 2018-01-24 10:47:05.944 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: eed0e91a-1781-33a8-6561-b361f797e096 2018-01-24 10:47:09.649 Info App: Creating Season Season 2016 entry for Criminal Minds 2018-01-24 10:47:10.603 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: e8b7ac64-0c1b-cefe-a421-8aec65250406 2018-01-24 10:47:12.475 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 10:47:13.103 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 7bbfa3a7-ce1a-8c8c-d2f8-615e2f0815c3 2018-01-24 22:44:43.481 Info App: Creating Season Season 2014 entry for The Simpsons 2018-01-24 22:44:45.955 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 22:44:46.846 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 0c4c6d01-a2d4-6df9-ce28-6e687e29f912 2018-01-24 22:44:46.947 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 8b52e96b-b624-344d-a697-a5ecaa510c13 2018-01-24 22:44:51.056 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 22:44:51.490 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 0fec914e-4904-7925-5594-f6a1884d82d3 2018-01-24 22:44:52.134 Info App: Creating Season Season 2013 entry for Cougar Town 2018-01-24 22:44:52.455 Info App: Deleting item, Type: Season, Name: Season 2013, Path: , Id: e1bcba65-b709-6bb5-4ba7-d295e2e54396 2018-01-24 22:44:53.597 Info App: Creating Season Season 2017 entry for The American Woodshop 2018-01-24 22:44:53.830 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 386fd359-3aa8-eb8b-864c-6999eab42d31 2018-01-24 22:44:54.577 Info App: Creating Season Season 2016 entry for X Company 2018-01-24 22:44:54.910 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: ad04a07d-87e4-2d9c-6332-1752f1ff4e65 2018-01-24 22:44:55.192 Info App: Creating Season Season 2014 entry for Holmes on Homes 2018-01-24 22:44:55.438 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 4d9a88f4-e4dc-c894-de49-1d86d72fd3df 2018-01-24 22:45:12.780 Info App: Creating Season Season 2013 entry for Woodsmith Shop 2018-01-24 22:45:13.017 Info App: Creating Season Season 2016 entry for Woodsmith Shop 2018-01-24 22:45:13.121 Info App: Creating Season Season 2017 entry for Woodsmith Shop 2018-01-24 22:45:13.226 Info App: Deleting item, Type: Season, Name: Season 2013, Path: , Id: 96199eb6-dd6b-824a-1f0f-9f26cf5c891e 2018-01-24 22:45:13.262 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 8e15cac2-7577-cd87-2179-17ec6af71c39 2018-01-24 22:45:13.316 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 683f34c2-8c85-dc2d-386a-5036fece3d92 2018-01-24 22:45:14.100 Info App: Creating Season Season 2016 entry for Rough Cut - Woodworking with Tommy Mac 2018-01-24 22:45:14.260 Info App: Creating Season Season 2017 entry for Rough Cut - Woodworking with Tommy Mac 2018-01-24 22:45:14.400 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 1714368e-7bc2-91b6-d366-55a6e3eee354 2018-01-24 22:45:14.431 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: d7b45148-8532-3a40-b144-1af1e9a1bc67 2018-01-24 22:45:14.822 Info App: Creating Season Season 2017 entry for The West BLock 2018-01-24 22:45:14.978 Info App: Creating Season Season 2018 entry for The West BLock 2018-01-24 22:45:15.103 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 278977b4-3a80-771e-5784-e2c96351be83 2018-01-24 22:45:15.155 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 9607554d-b573-d00e-5fb1-8c5d2571e468 2018-01-24 22:45:19.096 Info App: Creating Season Season 2015 entry for Marketplace 2018-01-24 22:45:19.175 Info App: Creating Season Season 2016 entry for Marketplace 2018-01-24 22:45:19.320 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 7333fd5a-e14a-d029-e18b-55122f3574e9 2018-01-24 22:45:19.354 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 0eaf6c83-2bed-2357-54dc-343dda76f6a5 2018-01-24 22:45:21.197 Info App: Creating Season Season 2017 entry for Marketplace 2018-01-24 22:45:21.436 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: edb91b2b-d118-c1ac-9248-4362482a5ecb 2018-01-24 22:45:22.796 Info App: Creating Season Season 2016 entry for X Company 2018-01-24 22:45:23.383 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 07b85f54-5870-69de-1da9-07ff8ad4ac6a 2018-01-24 22:45:26.425 Info App: Creating Season Season 2015 entry for You Gotta Eat Here! 2018-01-24 22:45:27.107 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 6d302ce9-b815-0837-cd5e-116ff7dc5085 2018-01-24 22:45:27.671 Info App: Creating Season Season 2016 entry for Duck Dynasty 2018-01-24 22:45:27.923 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: ea0aa056-ecb9-151c-af27-8059facd3611 2018-01-24 22:45:28.544 Info App: Creating Season Season 2014 entry for Vikings 2018-01-24 22:45:28.887 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 22:45:29.050 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 8b67a343-b49e-3b44-4990-46aaa6d80f31 2018-01-24 22:45:29.104 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 56536c3e-058f-ed29-a112-4ee10fc54896 2018-01-24 22:45:29.410 Info App: Creating Season Season 2017 entry for The Mayor 2018-01-24 22:45:29.685 Info App: Creating Season Season 2018 entry for The Mayor 2018-01-24 22:45:29.885 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: de833798-f712-d670-eddc-61129c729c5a 2018-01-24 22:45:29.938 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 4a22d00b-efd8-a547-1cd6-10f28d3d41f1 2018-01-24 22:45:30.233 Info App: Creating Season Season 2017 entry for Young Sheldon 2018-01-24 22:45:30.481 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: dc37fbb8-1a73-f23d-2005-241d3e6d3072 2018-01-24 22:45:31.496 Info App: Creating Season Season 2016 entry for Duck Dynasty 2018-01-24 22:45:31.854 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: acb57813-8aef-92fc-5d33-cebe4390054f 2018-01-24 22:45:33.090 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 22:45:33.269 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 3d3ba72d-95e7-a5c3-cdf7-1d7e1f1f179f 2018-01-24 22:45:42.181 Info App: Creating Season Season 2017 entry for The Ellen DeGeneres Show 2018-01-24 22:45:47.795 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 50386549-2f6c-ccf1-0be2-43f2a91dd4ab 2018-01-24 22:45:50.209 Info App: Creating Season Season 2015 entry for Black-ish 2018-01-24 22:45:51.155 Info App: Creating Season Season 2017 entry for Black-ish 2018-01-24 22:45:53.024 Info App: Creating Season Season 2018 entry for Black-ish 2018-01-24 22:45:53.138 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: a212151e-0bae-e78a-9cf1-5a3fd74af134 2018-01-24 22:45:53.140 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: ebead07f-b256-9b30-fab2-df7f95d24d54 2018-01-24 22:45:53.187 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 1339a16a-feff-d785-8f61-b81b4c5391c7 2018-01-24 22:45:55.604 Info App: Creating Season Season 2016 entry for Paw Patrol 2018-01-24 22:45:56.162 Info App: Creating Season Season 2017 entry for Paw Patrol 2018-01-24 22:45:56.397 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: d99a602d-01a0-a6bf-3bd3-7892a1f11296 2018-01-24 22:45:56.401 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 1e94018e-a883-71b2-a52b-2eabf69540f2 2018-01-24 22:45:56.579 Info App: Creating Season Season 2015 entry for Barney and Friends 2018-01-24 22:45:57.569 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 1ffa667b-ba1a-b98b-9517-0c0a135e4c6d 2018-01-24 22:45:58.158 Info App: Creating Season Season 2016 entry for 16x9 2018-01-24 22:45:58.382 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: e4bd846f-7719-c977-601e-1bf467b3c27a 2018-01-24 22:45:58.612 Info App: Creating Season Season 2014 entry for The Mentalist 2018-01-24 22:45:59.585 Info App: Creating Season Season 2015 entry for The Mentalist 2018-01-24 22:45:59.870 Info App: Deleting item, Type: Season, Name: Season 2014, Path: , Id: 9e4e3634-2798-3818-2701-64a9f319a9e4 2018-01-24 22:45:59.916 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 8ce7f50b-1a61-1be5-745d-581d02c0831f 2018-01-24 22:46:00.658 Info App: Creating Season Season 2017 entry for The Disappearance 2018-01-24 22:46:01.191 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 02aad5af-1933-9397-c2aa-8123454e6ded 2018-01-24 22:46:01.349 Info App: Creating Season Season 2015 entry for CSI: Crime Scene Investigation 2018-01-24 22:46:02.437 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: ba2487a9-23a9-8ed2-33f6-5f3dddbbe1d0 2018-01-24 22:46:03.358 Info App: Creating Season Season 2017 entry for Ten Days in the Valley 2018-01-24 22:46:03.603 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: a6a75280-3066-1195-7a35-856c10b9b182 2018-01-24 22:46:03.944 Info App: Creating Season Season 2016 entry for Chicago Fire 2018-01-24 22:46:04.660 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: c4b1937b-91e7-7436-f2c5-009223d3674e 2018-01-24 22:46:05.899 Info App: Creating Season Season 2017 entry for W5 2018-01-24 22:46:06.075 Info App: Creating Season Season 2018 entry for W5 2018-01-24 22:46:06.262 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: e78c34c0-d9ac-7b15-f60d-f9aef63eb176 2018-01-24 22:46:06.313 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: c181468c-a3f9-4275-e1a0-08ead26a5283 2018-01-24 22:46:08.436 Info App: Creating Season Season 2015 entry for Saturday Night Live 2018-01-24 22:46:08.945 Info App: Creating Season Season 2016 entry for Saturday Night Live 2018-01-24 22:46:09.320 Info App: Creating Season Season 2017 entry for Saturday Night Live 2018-01-24 22:46:09.770 Info App: Deleting item, Type: Season, Name: Season 2015, Path: , Id: 2d6406f6-f242-fa90-4343-485163d36167 2018-01-24 22:46:09.791 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 67044327-f5f8-f2af-201d-425e05024be4 2018-01-24 22:46:09.828 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 4b571ff1-5fa0-bf04-2d19-ad7adaf9f0d9 2018-01-24 22:46:11.482 Info App: Creating Season Season 2017 entry for Wisdom of the Crowd 2018-01-24 22:46:11.648 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: d4ef997b-87c1-0dff-97ca-f6a41c8f2d00 2018-01-24 22:46:12.783 Info App: Creating Season Season 2017 entry for The Good Doctor 2018-01-24 22:46:13.151 Info App: Creating Season Season 2018 entry for The Good Doctor 2018-01-24 22:46:13.303 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 0390a200-e4e6-013b-41fb-75f72ba7af7b 2018-01-24 22:46:13.314 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 7460c1cb-2d3e-a2e9-d630-e341628e84ac 2018-01-24 22:46:13.524 Info App: Creating Season Season 2017 entry for Kevin (Probably) Saves the World 2018-01-24 22:46:13.692 Info App: Creating Season Season 2018 entry for Kevin (Probably) Saves the World 2018-01-24 22:46:13.818 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 5a882ea0-6b54-03f4-0770-f71d764a14eb 2018-01-24 22:46:14.408 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 678d95da-0081-83e6-33c8-ae52a238c5d3 2018-01-24 22:46:14.835 Info App: Creating Season Season 2017 entry for SEAL Team 2018-01-24 22:46:15.029 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 5740f08f-7628-1655-f805-b85a492ad714 2018-01-24 22:46:15.482 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 22:46:15.721 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: ecf73f55-e2ba-74fc-24e4-8fa18c33fc52 2018-01-24 22:46:16.486 Info App: Creating Season Season 2018 entry for The National 2018-01-24 22:46:16.580 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: 76251ef2-61e9-7c95-78a7-9cc5672a609b 2018-01-24 22:46:16.798 Info App: Creating Season Season 2017 entry for W5 2018-01-24 22:46:16.838 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 6375f482-cc50-e82b-1d88-160b32854f4b 2018-01-24 22:46:17.533 Info App: Creating Season Season 2017 entry for The Fifth Estate 2018-01-24 22:46:17.655 Info App: Deleting item, Type: Season, Name: Season 2017, Path: , Id: 5dedac44-a7e3-321b-1ca3-568c5a84924e 2018-01-24 22:46:18.751 Info App: Creating Season Season 2016 entry for New Girl 2018-01-24 22:46:19.020 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: b2625f22-6da6-1880-d0f1-159a4742555b 2018-01-24 22:46:21.270 Info App: Creating Season Season 2018 entry for The National 2018-01-24 22:46:21.362 Info App: Deleting item, Type: Season, Name: Season 2018, Path: , Id: c0225206-9b25-04d6-2fe5-80dc93b73eab 2018-01-24 22:46:21.948 Info App: Creating Season Season 2016 entry for Chicago Fire 2018-01-24 22:46:22.088 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: eed0e91a-1781-33a8-6561-b361f797e096 2018-01-24 22:46:22.691 Info App: Creating Season Season 2016 entry for Criminal Minds 2018-01-24 22:46:23.124 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: e8b7ac64-0c1b-cefe-a421-8aec65250406 2018-01-24 22:46:23.927 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 22:46:24.813 Info App: Deleting item, Type: Season, Name: Season 2016, Path: , Id: 7bbfa3a7-ce1a-8c8c-d2f8-615e2f0815c3 I'm not sure if this normal or not. Or if it's even causing or related the massive fast sync problems in fact. I'm just following the opinions here.
Angelblue05 4132 Posted January 25, 2018 Posted January 25, 2018 Well. The fast sync only record server events. So whatever the server is doing, it is definitely generating your 500 updates you are seeing. I guess the next step is figuring out if it's the same items being processed over and over. I'd say, the best way to figuring this out is with two Kodi logs. It will print the item names being updated to log. So two separate days that contains the fast sync updates would give us this information. Sent from my iPhone using Tapatalk
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 In cases like last night, it's every item -- not just a case of some number of items that were being updated over and over. The ~500 or so items that it updated equals the total number of items in that user's library. So we don't really even have to look at a Kodi log to see what is being updated. It's everything. I think what we need to focus on is the entire list of what constitutes an item change such that fast sync thinks it needs to be transferred to the client again and rule out each item one by one. IOW, what conditions could cause an item to be flagged as needing to be sent in a fast-sync where that item is not at all a new item. I can quite clearly see the fast sync processing progress in the on-screen dialog and the adds are a few and the removes are a few, but it's the "updates" in between that can be 500 items.
Angelblue05 4132 Posted January 25, 2018 Posted January 25, 2018 (edited) You misunderstand how the fast sync works. The server triggers websocket events when it scans your libraries. Each event contains ids of what the server said has been modified. The fast sync simply records it. When you turn on Kodi, Emby for kodi asks the server plugin for all items to update since last time Emby for Kodi was on. The fast sync doesn't think. It just records events. While Kodi is running, if your server is scanning libraries, Emby for Kodi receives those events live. I hope this makes sense to you. If the server triggers an update event with ids, there is nothing else that will prevent that update down the line, because that's just not how things works. The server update event should be prevented in the first place. And that's where we are falling short, to understand why this is happening. Sent from my iPhone using Tapatalk Edited January 25, 2018 by Angelblue05
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 I don't really misunderstand how fast sync works. I understand that it's just updating the client with what has changed on the server since it was last connected. I am just generally using the term "fast sync" to cover everything involved with a fast sync actually working which is including the server identifying things that have changed (that haven't really).
xnappo 1611 Posted January 25, 2018 Posted January 25, 2018 (edited) Yep - the symptom is fast sync, but clearly the issue is that the server is generating 'updates' when things don't get identified correctly. I have seen that before... Nothing that can be done on the Emby for Kodi side unfortunately. Honestly - I really think EmbyCon is better in a 'DVR' style environment with content changing often. Emby for Kodi is better suited for very large and cultivated collections. You can actually use both - Emby for Kodi for movies and EmbyCon for TV... That isn't to say it shouldn't be fixed, but it isn't going to be quick I don't think. Edited January 25, 2018 by xnappo
shred00 13 Posted January 30, 2018 Author Posted January 30, 2018 Any more ideas here? I'm still seeing incremental syncs with updates in the neighborhood of 500-600 items, which is usually the entire library for a given user. Clearly within every 24-48 hours, every item in my library is being "refreshed" such that an incremental sync thinks it needs updating to clients which have been connected in the last 24-48 hours. What do I need to do to see why every single library item is being considered updated on the server?
shred00 13 Posted February 2, 2018 Author Posted February 2, 2018 Check the server logs and talk to the server team. I would, if I knew what I was checking for. I keep asking for what to check for and never seem to get an answer. You could set up a new emby library with just a few test items in it and create a new user with access to just that library. Reproducing the issue with a much smaller test set of data might help track down the issue. So, if I were looking for a needle in a haystack, I would agree with that. But I don't even know what I am looking for so I don't know if there is a haystack that I am trying to find a needle in. On the other hand, a large library makes the problem really obvious. When my Kodi box is supposed to be doing an incremental sync and it says there are 600 updates, there is no question that every single item in my library is getting refreshed every 24-48 hours. If I had a very small library, as you suggest for debugging, I would not notice such a small number of items being refreshed so frequently because they would get masked by a quick (even though not really incremental) update. So in this case, I would say that a large library is exactly what is needed since it makes the problem so obvious and provides a lot of items to look for some kind of pattern over.
Luke 42208 Posted February 2, 2018 Posted February 2, 2018 I'd like to help resolve it. Do your tv series have season folders, or no?
shred00 13 Posted February 2, 2018 Author Posted February 2, 2018 I'd like to help resolve it. Do your tv series have season folders, or no? They didn't originally but I reorganised them all into season folders a few weeks ago when it was thought that virtual season folders might be a cause. So to be clear, yes, they all have season folders now.
llonca13 0 Posted February 5, 2018 Posted February 5, 2018 (edited) I had the same problems until I upgraded my Kodi addon to newest beta version, now incremental sync works like before. I would like to apologize to developers I said I will post my server log to pinpoint the issue but I had some personal problems, I forgot to do it. And thank you for all your hard work and this awesome software. Edited February 5, 2018 by llonca13
shred00 13 Posted March 6, 2018 Author Posted March 6, 2018 So a number of Emby server updates and even Emby Kodi addon updates later and this problem is still happening. I'm not entirely positive of this data item but maybe it only happens when I have not done an update in closer to two days rather than one day. Perhaps helps trigger an idea. Like how long does Emby server keep track of changed items before it starts dropping the oldest changes and then requires any clients that need an update since before the drop time to do a full refresh? Perhaps it's not even that sophisticated and it's just telling clients to update anything that has a "modified" timestamp newer than it's last update. In which case we are back to why is Emby server marking everything on my server as needing an update every day or two?
Luke 42208 Posted March 6, 2018 Posted March 6, 2018 The other users affected confirmed it as resolved so we'll have to start from the beginning. Can you please discuss an example and attach the emby server log? What you can do is enable debug logging on the server, then run a full scan. The scan can help tell us if items are getting refreshed for some reason. Thanks.
Luke 42208 Posted March 11, 2018 Posted March 11, 2018 @@shred00 based on the log that you sent I would suggest updating to 3.3.1. Also, there's something going on with your file system, perhaps a drive down? 2018-03-10 11:44:32.460 Error App: Error validating images for /var/lib/emby-server/root/default/TV - Mom & Dad *** Error Report *** Version: 3.3.0.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.13.0.135 64-Bit OS: False 64-Bit Process: False User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Tue May 2 22:30:49 UTC 2017) Processor count: 2 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.IO.DirectoryNotFoundException: Directory '/storage2/Mom & Dad' not found.
shred00 13 Posted March 12, 2018 Author Posted March 12, 2018 based on the log that you sent I would suggest updating to 3.3.1. Doing that right now then. Do you want another library scan with debug after that or shall I wait to see if the problem persists before doing that? Also, there's something going on with your file system, perhaps a drive down? Indeed, it's been down a while. I have just not yet gone through all of my Libraries to remove it as I'm not yet sure if I am going to replace it or not and don't want to have to first undo all those Library settings only to have to re-do them later. Thanks much for taking a look!
shred00 13 Posted March 14, 2018 Author Posted March 14, 2018 So upgrading to 3.3.1 has not resolved this issue.
