Angelblue05 4132 Posted January 11, 2018 Posted January 11, 2018 Yes, I'll get you that information. Thanks Luke! If we can get the server working less, it's always a good thing in my book Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted January 11, 2018 Posted January 11, 2018 (edited) @@Luke I've look deeper into my logs, never mind what I said about virtual items, I think I corrected this a while back. In my case, it seems the same items that keep being updated are ones emby are throwing errors about. I'll get back to you on this. @@shred00 Do provide your server log so Luke can take a look. Do you see those same lines every day? Edited January 11, 2018 by Angelblue05
sualfred 677 Posted January 11, 2018 Posted January 11, 2018 @@Luke I'm also facing it daily or after a library scan for 104 items. I'll send you a PM with all your requested details.
llonca13 0 Posted January 12, 2018 Posted January 12, 2018 (edited) I also have to report the same problem happening and its very frustrating. The problem started to appear 1-3weeks ago I cant tell for sure,maybe after a new update (i run it in Docker, on auto update so I cant be more precise when). Incremental sync doesnt happen, instead full scan is started (like when you go to emby addon and hit manual sync option). I thought its problem on my end so I performed database reset (and even reinstalled emby addon and deleted emby.db and myvideos.db) to start things fresh, and even reinstalled my emby server (deleted config, start from scratch). The problem continues, no incremental updates. Im using emby (with fast start plugin) on android spmc (kodi 16.1,mibox), LE (rpi3 17.5,generic s905x and odroid c2 on 17.6) and all devices experience the same bug (even after reinstall). I have correct season structure and this problems started to arise since a few weeks ago. Im on newest stable emby server, stable emby kodi addon, and version 2.0 of fast sync kodi plugin. Running in native paths mode. Please tell me what logs you need to identify this bug. Edited January 12, 2018 by llonca13
sualfred 677 Posted January 12, 2018 Posted January 12, 2018 @Illonca13 Turn on Debug logging in the server dashboard and restart the server. After it's back up again trigger a manual library scan. As soon it's done upload the server log.
sualfred 677 Posted January 12, 2018 Posted January 12, 2018 (edited) @@Luke I guess I've found the issue. The .nfo updating on each library scans happens as soon as .sub (idx + sub file) subtitles are stored next to the video. It does not happen if .srt subs are present. @@llonca13 @@shred00 Could you please check it on your side, too? -> Move the subtitle files from one of the unnecessary updated library items to a temporary place -> Scan library (to remove the existing subtitles informations from the nfo file) -> Wait a minute -> Scan library again and check if the modification date of the video .nfo has been changed again Edited January 12, 2018 by sualfred
shred00 13 Posted January 12, 2018 Author Posted January 12, 2018 I don't have anything to do with subtitles.
sualfred 677 Posted January 12, 2018 Posted January 12, 2018 @@shred00 Can you please provide a full debug log so I can compare if we both facing the similar issues? Because for me it's def. caused by sub/idx subtitles (for whatever reason)
Angelblue05 4132 Posted January 12, 2018 Posted January 12, 2018 @@sualfred I'm confused, why are the same items re-scanned then? Is it because it's not finding subs for them or?
sualfred 677 Posted January 12, 2018 Posted January 12, 2018 I don't know. It changes anything. <subtitle> <codec>subrip</codec> <micodec>subrip</micodec> <language>ger</language> <scantype>progressive</scantype> <default>True</default> <forced>True</forced> </subtitle> <subtitle> <codec>sub</codec> <micodec>sub</micodec> <language>deu</language> <scantype>progressive</scantype> <default>False</default> <forced>True</forced> </subtitle> <subtitle> <codec>sub</codec> <micodec>sub</micodec> <language>eng</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> <subtitle> <codec>sub</codec> <micodec>sub</micodec> <language>deu</language> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> </subtitle> The subs are recongnized and written correctly, but I assume Emby thinks that the information for the SUB subtitles is missing in the .nfo and rewrites it again with the same content. That leads into a changed .nfo modification date and a log entry with ... 2018-01-11 10:41:35.453 Debug App: Running FFProbeProvider for /mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv 2018-01-11 10:41:35.453 Debug MediaEncoder: /opt/emby-server/bin/ffprobe -i file:"/mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format 2018-01-11 10:41:35.472 Debug App: Running MovieNfoProvider for /mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv 2018-01-11 10:41:35.473 Debug App: Running OmdbItemProvider for /mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv 2018-01-11 10:41:35.474 Debug App: Running MovieDbProvider for /mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv 2018-01-11 10:41:35.474 Debug JsonSerializer: Deserializing file /var/lib/emby/cache/tmdb-movies2/68726/all-de.json 2018-01-11 10:41:35.477 Debug App: Running BaseGenreCleaner for /mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv 2018-01-11 10:41:35.486 Debug ProviderManager: Saving /mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv to Nfo. 2018-01-11 10:41:35.495 Debug App: Saving /mnt/omv1/omv1/filme/Pacific Rim (2013)/Pacific Rim (2013) h264-1080p DTS-6ch.mkv to database. 2018-01-11 10:41:35.496 Debug App: Emby.Kodi.SyncQueue: ItemUpdated added for DB Saving 5d9e44c3-5c6d-3755-a9fe-47e17bfb5afa ... and voila, the SyncQueue addon is triggered on a library scan. Still trying to find out why this is happening, because I have hundreds of .sub subtitles in my database, but it only applies for ~104 items. 1
Angelblue05 4132 Posted January 12, 2018 Posted January 12, 2018 (edited) In the Kodi log, you should be able to identify the title of one of the 104 items. Best thing to do is track the nfo changes and subs. Copy paste into notepad++ and compare to after a scan happens to see if anything changes? Anyway, hope @@Luke will know why it's happening. Sent from my iPhone using Tapatalk Edited January 12, 2018 by Angelblue05
sualfred 677 Posted January 12, 2018 Posted January 12, 2018 I already did. It happens to the ones with the .sub issue from above. And the .nfos are the same and just gets rewritten to the file. As soon as I delete the .sub subtitles the issue is gone. 1
sualfred 677 Posted January 13, 2018 Posted January 13, 2018 I'm currently cleaning all my directories which are affected and I've noticed that this also happens for some videos with .srt subtitles.@@LukePlease let me know if I should upload a sample video (complete directory), if you cannot reproduce it. 1
llonca13 0 Posted January 13, 2018 Posted January 13, 2018 (edited) Im sorry im not home now I will upload tomorrow. But I can assure you I dont have any .sub subtitle in any of my directorys. Every single media file in my media library have .srt subtitle with the same name as my file (downloaded through kodi). Edited January 13, 2018 by llonca13
shred00 13 Posted January 15, 2018 Author Posted January 15, 2018 (edited) @@shred00 Can you please provide a full debug log so I can compare if we both facing the similar issues? Because for me it's def. caused by sub/idx subtitles (for whatever reason) I mentioned previously that I don't do anything at all with subtitles so my logs will not help in that respect. I did PM @@Luke with the logs he was requesting but I guess he has not had time to look at them yet. I am sure he will when he has time. In the meanwhile I have converted all of my episodes into Season folders to see if my issue is with virtual seasons as suspected. I will report when I have a result of that. Edited January 15, 2018 by shred00 1
shred00 13 Posted January 15, 2018 Author Posted January 15, 2018 Too soon to determine yet. I need some time to pass between doing that (and the manual resync that I did after doing that, to get a clean slate to work from) to see how the incremental sync acts. I should know in the next day or 3. 1
shred00 13 Posted January 18, 2018 Author Posted January 18, 2018 So, the problem is not virtual season folders. I have all of my episodes in real Season NN folders and I still had "fast sync"s last night wanting to update over 500 items and taking minutes to do it. I'm also noticing that even though I have actual Season NN folder dirs in my library now, I am still getting over a thousand: 2018-01-18 10:41:27.445 Info App: Creating Season Season 2015 entry for Saturday Night Live 2018-01-18 10:41:27.720 Info App: Creating Season Season 2016 entry for Saturday Night Live 2018-01-18 10:41:28.014 Info App: Creating Season Season 2017 entry for Saturday Night Live 2018-01-18 10:41:28.479 Info App: Creating Season Season 2014 entry for The Mentalist 2018-01-18 10:41:28.553 Info App: Creating Season Season 2015 entry for The Mentalist 2018-01-18 10:41:28.751 Info App: Creating Season Season 2017 entry for Marketplace 2018-01-18 10:41:29.014 Info App: Creating Season Season 2016 entry for X Company type messages in a 24 hour period. I understood those were virtual seasons being created. Why are virtual seasons still being created here when I have all of my episodes in actual season folders (where some of those seasons are the year, not a season number)? So what next? Were the log files I PM'd to @@Luke previously any use?
Angelblue05 4132 Posted January 18, 2018 Posted January 18, 2018 Wow thanks for the info. @@Luke That's definitely not normal, what are those log lines then? Sent from my iPhone using Tapatalk
Luke 42208 Posted January 19, 2018 Posted January 19, 2018 Can you try the new release and see if that makes any difference? thanks.
shred00 13 Posted January 19, 2018 Author Posted January 19, 2018 Can you try the new release and see if that makes any difference? thanks. Have upgraded to 3.2.70.0+66.1. Will let you know over the next few days if fast syncs are still large with many updates for things that really shouldn't have any change to them.
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 @@shred00 Any changes? Ha! I was just coming here to provide an update when I saw the above message. So, unfortunately not. The last few times I have logged into an account that logs in pretty much daily there have been over 500 updates included in the fast sync.
Angelblue05 4132 Posted January 25, 2018 Posted January 25, 2018 So you are still seeing the create season in your server log?
shred00 13 Posted January 25, 2018 Author Posted January 25, 2018 Definitely not as many as I was, but yes, still seeing them: $ grep Creating\ Season /var/lib/emby-server/logs/server-63652348800.txt | wc -l 128 $ grep Creating\ Season /var/lib/emby-server/logs/server-63652348800.txt | head -23 2018-01-24 04:03:16.741 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 04:03:17.794 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 04:03:39.615 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 04:03:40.205 Info App: Creating Season Season 2016 entry for Scandal (2012) 2018-01-24 04:04:52.828 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 04:04:53.332 Info App: Creating Season Season 2016 entry for Vikings 2018-01-24 10:44:46.138 Info App: Creating Season Season 2014 entry for The Simpsons 2018-01-24 10:44:46.317 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 10:45:00.443 Info App: Creating Season Season 2016 entry for The Simpsons 2018-01-24 10:45:01.232 Info App: Creating Season Season 2013 entry for Cougar Town 2018-01-24 10:45:02.750 Info App: Creating Season Season 2017 entry for The American Woodshop 2018-01-24 10:45:03.859 Info App: Creating Season Season 2016 entry for X Company 2018-01-24 10:45:04.410 Info App: Creating Season Season 2014 entry for Holmes on Homes 2018-01-24 10:45:32.045 Info App: Creating Season Season 2013 entry for Woodsmith Shop 2018-01-24 10:45:32.751 Info App: Creating Season Season 2016 entry for Woodsmith Shop 2018-01-24 10:45:32.905 Info App: Creating Season Season 2017 entry for Woodsmith Shop 2018-01-24 10:45:33.567 Info App: Creating Season Season 2016 entry for Rough Cut - Woodworking with Tommy Mac 2018-01-24 10:45:34.116 Info App: Creating Season Season 2017 entry for Rough Cut - Woodworking with Tommy Mac 2018-01-24 10:45:34.568 Info App: Creating Season Season 2017 entry for The West BLock 2018-01-24 10:45:35.029 Info App: Creating Season Season 2018 entry for The West BLock 2018-01-24 10:45:38.921 Info App: Creating Season Season 2015 entry for Marketplace 2018-01-24 10:45:38.994 Info App: Creating Season Season 2016 entry for Marketplace 2018-01-24 10:45:39.831 Info App: Creating Season Season 2017 entry for Marketplace 1
