kanipek 230 Posted January 6, 2018 Posted January 6, 2018 (edited) I have been having this error for awhile now, several versions of Emby. I have been "living" with it - a restart of the server clears it up but it really does become annoying, restarting the server is not always a practical solution. Is there something wrong with my install? The puzzling thing is when it happens there is usually nothing happening that would cause "...Too many changes at once in directory..." no added episodes/films. 2018-01-06 13:01:05.698 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.112\TV Shows\U-Z *** Error Report *** Version: 3.2.50.0 Command line: C:\Users\kanip\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 12 Program data path: C:\Users\kanip\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\kanip\AppData\Roaming\Emby-Server\system System.IO.InternalBufferOverflowException: Too many changes at once in directory:\\192.168.1.112\TV Shows\U-Z. System.IO.InternalBufferOverflowException No Stack Trace Available LM.txt Edited January 6, 2018 by kanipek
Solution Luke 42216 Posted January 6, 2018 Solution Posted January 6, 2018 The Windows file system monitor has a limit on the number of changes it will handle in a short period of time. there's nothing we can do about it. You can just ignore it because the server will recover from it just fine and continue on. 2
kanipek 230 Posted January 6, 2018 Author Posted January 6, 2018 The Windows file system monitor has a limit on the number of changes it will handle in a short period of time. there's nothing we can do about it. You can just ignore it because the server will recover from it just fine and continue on. Would using NFS change anything?
kanipek 230 Posted January 6, 2018 Author Posted January 6, 2018 I'm not sure, sorry. Hmmm...I will let you know!
kanipek 230 Posted January 6, 2018 Author Posted January 6, 2018 (edited) We just shouldn't have log files anymore. I know these queries from users eat up a lot of your time. Your help is appreciated Luke and everyone. I don't really get what you mean when you say "the server will recover from it" - Do you mean when it restarts? that is the only way I have been able to get the Library Monitor to function again. If I can get rid of the problem with NFS that would be great. Can't really justify moving to a true server OS at this point, which I think would solve the problem, or at least make it less frequent. Anyways I will play with it and see what happens. Logs are your friend! Edited January 6, 2018 by kanipek
chudak 24 Posted July 29, 2018 Posted July 29, 2018 I have been having this error for awhile now, several versions of Emby. I have been "living" with it - a restart of the server clears it up but it really does become annoying, restarting the server is not always a practical solution. Is there something wrong with my install? The puzzling thing is when it happens there is usually nothing happening that would cause "...Too many changes at once in directory..." no added episodes/films. 2018-01-06 13:01:05.698 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.112\TV Shows\U-Z *** Error Report *** Version: 3.2.50.0 Command line: C:\Users\kanip\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 12 Program data path: C:\Users\kanip\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\kanip\AppData\Roaming\Emby-Server\system System.IO.InternalBufferOverflowException: Too many changes at once in directory:\\192.168.1.112\TV Shows\U-Z. System.IO.InternalBufferOverflowException No Stack Trace Available I am seeing similar issue on ubuntu server. Have you found any resolution ? Thx
Luke 42216 Posted July 29, 2018 Posted July 29, 2018 I am seeing similar issue on ubuntu server. Have you found any resolution ? Thx You're not seeing a similar issue. the message is different and completely unrelated.
djhifi 56 Posted September 24, 2018 Posted September 24, 2018 (edited) Digging this one up after googling it. Altough I'm on Synology and not the same message but is this related? (not doing anything, just letting an initial sync finish) 2018-09-24 09:48:53.802 Info LibraryMonitor: Watching directory /volume3/Array-7/Filmes (HD3)/Movies2018-09-24 09:48:53.964 Info LibraryMonitor: Watching directory /volumeUSB3/usbshare/Filmes (HD1)/TV Shows2018-09-24 09:48:54.057 Info LibraryMonitor: Watching directory /volumeUSB3/usbshare/Filmes (HD1)/Movies2018-09-24 09:48:54.333 Info LibraryMonitor: Watching directory /volume4/Array-4/Filmes (HD11)/TV Shows2018-09-24 09:48:54.464 Info LibraryMonitor: Watching directory /volume2/Array-2/Filmes (HD14)/TV Shows2018-09-24 09:48:54.861 Info LibraryMonitor: Watching directory /volumeUSB2/usbshare/Filmes (HD2)/Movies2018-09-24 09:48:54.962 Info LibraryMonitor: Watching directory /volume2/Array-2/Filmes (HD14)/Movies2018-09-24 09:48:55.062 Info LibraryMonitor: Watching directory /volume4/Array-4/Filmes (HD11)/Movies2018-09-24 09:48:56.890 Info App: Emby.Kodi.SyncQueue: Starting Library Sync… 2018-09-24 09:48:57.163 Error LibraryMonitor: Error in Directory watcher for: /volume6/Array-6/Filmes (HD13)/Movies *** Error Report ***Version: 3.6.0.46Command line: /volume6/@appstore/EmbyServerNET/releases/3.6.0.46-beta/EmbyServer.dll -package synology -nocustomffmpeg -programdata /var/packages/EmbyServerNET/target/var -ffmpeg /var/packages/EmbyServerNET/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServerNET/target/ffmpeg/bin/ffprobe -restartexitcode 121Operating system: Unix 3.10.105.064-Bit OS: True64-Bit Process: TrueUser Interactive: TrueProcessor count: 4Program data path: /var/packages/EmbyServerNET/target/varApplication directory: /volume6/@appstore/EmbyServerNET/releases/3.6.0.46-betaSystem.IO.IOException: The configured user limit (8192) on the number of inotify watches has been reached. PS:As you can see all other directories throw no errors in the log. Edited September 24, 2018 by djhifi
chrissi55 2 Posted November 21, 2018 Posted November 21, 2018 *** Error Report *** Version: 3.6.0.46 Command line: /volume6/@appstore/EmbyServerNET/releases/3.6.0.46-beta/EmbyServer.dll -package synology -nocustomffmpeg -programdata /var/packages/EmbyServerNET/target/var -ffmpeg /var/packages/EmbyServerNET/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServerNET/target/ffmpeg/bin/ffprobe -restartexitcode 121 Operating system: Unix 3.10.105.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/packages/EmbyServerNET/target/var Application directory: /volume6/@appstore/EmbyServerNET/releases/3.6.0.46-beta System.IO.IOException: The configured user limit (8192) on the number of inotify watches has been reached. This one -> limit (8192) i had too under emby 3.5.3.0 Many Files and Folders where not found or empty, allthough i had no .ignore file in these folders! Till today many of my files where not found under ubuntu server 18.04.1 -> with emby 3.5.3.0 because my log file says System.IO.InternalBufferOverflowException: Too many changes at once in directory:/xy/xy/audio/... But i could get more of my files to show up in Emby Media Server by using following changes 1) sudo nano /etc/sysctl.conf 2) at the end of the file enter -> fs.inotify.max_user_watches=1048576 3) save /etc/sysctl.conf 4) check settings by -> sudo sysctl -p 5) reboot server That brings up many more files to be scanned in emby media (like under miniDLNA) But never the less i could not see all my files (audio, ebook, video) in all types the same. My full error message says: *** Error Report *** Version: 3.5.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.39 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.IO.InternalBufferOverflowException: Too many changes at once in directory:/xy/xy/audio/SUBDIR. System.IO.InternalBufferOverflowException No Stack Trace Available
Luke 42216 Posted November 21, 2018 Posted November 21, 2018 That message won't prevent you from seeing content. The only thing it will do is affect the realtime monitor. Try running a library scan.
chrissi55 2 Posted November 23, 2018 Posted November 23, 2018 (edited) Can i do this under ubuntu by terminal command? I scanned my Libraries more and more without any effect. That by using the button under the WebUI. What worked sometimes, was, creating a new folder / subfolder with a dummy file (a audio.mp3 or cover.jpg) and then scan again. That brings up in some cases more of the folders, that were missing under emby but that exists under file-manager (midnight commander e.g.) I set my folder and files to emby:users by sudo chown -R emby:users /music /video /ebook and i set the files to 777 -> chmod -R 777 .... As i said in some folders and subfolders that worked for me and brought some aof my missing files under emby media. But in other cases it didn't work allthough there are no ".igniore" files in these folders. Could too many missing meta data broke the watchdog or hinder it to index my files? Edited November 23, 2018 by chrissi55
Luke 42216 Posted November 23, 2018 Posted November 23, 2018 If you are running a full library scan and some content isn't showing up, then i think it is best if we look at specific examples of that. thanks.
chrissi55 2 Posted November 24, 2018 Posted November 24, 2018 Thanks for your offer to help :-) Before i prepare some examples... What does this mean? -> Error HttpServer: Could not find handler for /service/recordings/get I have many of those errors in my log file.
Luke 42216 Posted November 24, 2018 Posted November 24, 2018 Please attach the complete emby server log. thanks.
chrissi55 2 Posted November 24, 2018 Posted November 24, 2018 (edited) here you are ... What i found today was a folder with an mp4 file (audio+video) in a library declared as audio / mp3 So i deleted the folder containing the mp4 file and did a rescan of all libraries. After that all files and folders in that subdir - that was containing the mp4 before become visible under emby. Is it true that if i add a directory to the emby Libraries i have to define with type of content there will be - so far so good - and that after adding this directory files could be invisible if they are containing a different type of files? But in that case i would expect that mp4 files were hidden and mp3 files were not - if i say that Lib XY contains "Music" instead of "Mixed Content" - or not? Log Edited November 24, 2018 by chrissi55
Luke 42216 Posted November 24, 2018 Posted November 24, 2018 Ok so whoever is sending those requests is requesting urls that don't exist. 2018-11-24 12:45:03.517 Info HttpServer: HTTP GET http://192.168.55.14:8096/service/recordings/get. UserAgent: Zenterio/0x800D-12.2.4.1-433 I've never heard of Zenterio, so you'll need to consult with them.
chrissi55 2 Posted November 24, 2018 Posted November 24, 2018 In fact that all router ports 8096 and 8920 are closed, the only client that could act lika this is a PS4 with Live TV Support App. But not clear why this one is looking for that path? IP and port are well the configured ones of the emby server ...
Luke 42216 Posted November 24, 2018 Posted November 24, 2018 That request is not coming from an Emby app so i can't answer about why it is doing that. But i would think you can figure it out by finding out what device is on your network with the IP address: 192.168.55.101 Try disconnecting that device from the network, keep it off, and then you shouldn't see that activity in the emby server log anymore.
