krisjanis2000 0 Posted January 6, 2018 Posted January 6, 2018 Hello! I recently installed Emby on my Qnap server. Everything works perfectly with no problems except HTTPS. I am trying with te port, but it says page not found. Any ideas?
krisjanis2000 0 Posted January 6, 2018 Author Posted January 6, 2018 I have configured it for Qnap web server. Do I need to do it for Emby separately? If yes, how do you do that?
Luke 42239 Posted January 9, 2018 Posted January 9, 2018 hi there, in the advanced section of emby server setup, you'd have to specify an SSL cert such as Lets Encrypt. Please let us know if this helps. Thanks.
Zmajur 1 Posted January 9, 2018 Posted January 9, 2018 (edited) Today I manage to run Emby with SSL following this tutorial. Except, you cant run on port 443, looks is reserved for qnap. Im still learning.... Edited January 9, 2018 by Zmajur
Luke 42239 Posted January 10, 2018 Posted January 10, 2018 Yes trying to use 443 will always be a little more complicated.
Zmajur 1 Posted January 10, 2018 Posted January 10, 2018 Qnap have option to change server default 443 port. This doesent help. I dont know should stop service from ssh or maybe must make some reverse proxy. Problem is I dont know where and what files to edit. Is anybody manage to run emby on port 443?
krisjanis2000 0 Posted January 10, 2018 Author Posted January 10, 2018 You should change Qnap web server port from 443 to something else so no other services are using it.
Zmajur 1 Posted January 10, 2018 Posted January 10, 2018 Yes i did that. Didnt have luck. Only thing I didnt do is restarded NAS. Maybe ttat is problem. Did you manage to use Emby SSL on port 443?
krisjanis2000 0 Posted January 10, 2018 Author Posted January 10, 2018 No, unfortunately I can't seem to get the encryption working. I have Let's Encrypt for Qnap web server. Is it possible to use the same encryption for Emby?
Zmajur 1 Posted January 10, 2018 Posted January 10, 2018 Yes Im using it. Just follow the tutorial. Only I didnt test on main domain "mydomain.com" I make subdomain "media.mydomain.com". Here I get certificate https://www.sslforfree.com Just dont forhet to make px.fike without password and for start use emby default port ssl port.
Zmajur 1 Posted January 22, 2018 Posted January 22, 2018 NOOB is just curious, what this error in log files mean? *** Error Report *** Version: 3.2.70.0 Command line: /share/CACHEDEV1_DATA/.qpkg/Emby/Emby/MediaBrowser.Server.Mono.exe Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 jeudi 27 avril 2017, 14:32:02 (UTC+0200)) Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/Emby/Emby/ProgramData-Server Application directory: /share/CACHEDEV1_DATA/.qpkg/Emby/Emby Mono.Btls.MonoBtlsException: Ssl error:10000416:SSL routines:OPENSSL_internal:SSLV3_ALERT_CERTIFICATE_UNKNOWN at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00054] in <f8255d9ef0594d18ae2c0d97286b9a80>:0 at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncProtocolRequest asyncRequest, Mono.Net.Security.AsyncOperationStatus status) [0x00033] in <f8255d9ef0594d18ae2c0d97286b9a80>:0 ..... This error come when I connect over SSL from android smartphone via Emby app. I created Lets Encrypt certificate with password protected .pfx file. By the way connection is fine, video files played without problem. Like I say at beggining, Im just curious is this connection is encripted or not? Thanks...
Luke 42239 Posted January 22, 2018 Posted January 22, 2018 NOOB is just curious, what this error in log files mean? This error come when I connect over SSL from android smartphone via Emby app. I created Lets Encrypt certificate with password protected .pfx file. By the way connection is fine, video files played without problem. Like I say at beggining, Im just curious is this connection is encripted or not? Thanks... Not sure, but i can see you are using the older mono based package which has a different ssl implementation.
Zmajur 1 Posted January 22, 2018 Posted January 22, 2018 Thanks for response. I Will try latest mono. By the way I yust switch to "mono" after I tested beta Emby product. Hope you will resolve ssl crashing connection in near feature. For me you are the best because you have apps for many platforms and you dont require to be connected on your server like Plex... I like privacy...
