alekdavis 2 Posted January 6, 2018 Posted January 6, 2018 (edited) Trying to process a bunch of MP3 files with Unicode (Russian) names and metatags and get a bunch of exceptions in the log that look like these (do not mind Старые ПеÑни о Главном in the name of the file, it's a web display log bug, it must look normal in the actual log file): 2018-01-05 18:32:36.508 Info CoverArt: image enhance of Старые ПеÑни о Главном - 1 took 0.011 seconds. 2018-01-05 18:32:36.509 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.2.60.0 Command line: C:\Users\XYZ\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\XYZ\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\XYZ\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\XYZ\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\XYZ\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\XYZ\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\XYZ\AppData\Roaming\Emby-Server\system System.NullReferenceException: Object reference not set to an instance of an object. at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImage(SKBitmap originalImage, ProfileDefinition profile, String itemType, String frameType, IHasMetadata item, List`1 childImages) at CoverArt.Skia.CoverArtAlbumEnhancer.EnhanceImageAsyncInternal(IHasMetadata item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(IHasMetadata item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.<ExecuteImageEnhancers>d__46.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<GetEnhancedImageInternal>d__45.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<GetEnhancedImage>d__44.MoveNext() System.NullReferenceException at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImage(SKBitmap originalImage, ProfileDefinition profile, String itemType, String frameType, IHasMetadata item, List`1 childImages) at CoverArt.Skia.CoverArtAlbumEnhancer.EnhanceImageAsyncInternal(IHasMetadata item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(IHasMetadata item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.<ExecuteImageEnhancers>d__46.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<GetEnhancedImageInternal>d__45.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Drawing.ImageProcessor.<GetEnhancedImage>d__44.MoveNext() Edited January 6, 2018 by alekdavis
Luke 42253 Posted January 9, 2018 Posted January 9, 2018 @@alekdavis can you give an example of a filename this is happening with? thanks.
alekdavis 2 Posted January 9, 2018 Author Posted January 9, 2018 2018-01-05 18:32:36.508 Info CoverArt: image enhance of Старые Песни о Главном - 1 took 0.011 seconds. 2018-01-05 18:32:36.509 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.2.60.0
Luke 42253 Posted January 9, 2018 Posted January 9, 2018 what version of the cover art plugin do you have installed?
alekdavis 2 Posted January 9, 2018 Author Posted January 9, 2018 (edited) Btw, I do not have any files (or folders) with the name Старые Песни о Главном - 1. The series folder is called Старые Песни о Главном (1996), under which there is Season 01 folder, under which there are episodes with standard naming convention, such as Старые песни о главном - s01e01 - 1 серия (1996).mkv. I also checked the .nfo files and I do not see this exact name. Edited January 9, 2018 by alekdavis
ebr 16342 Posted January 10, 2018 Posted January 10, 2018 Btw, I do not have any files (or folders) with the name Старые Песни о Главном - 1. The series folder is called Старые Песни о Главном (1996), under which there is Season 01 folder, under which there are episodes with standard naming convention, such as Старые песни о главном - s01e01 - 1 серия (1996).mkv. I also checked the .nfo files and I do not see this exact name. The log message is showing the name of the item from metadata - not the file or folder name.
alekdavis 2 Posted January 11, 2018 Author Posted January 11, 2018 Oh, okay. I'd suspect that file name would be more useful in the log file for troubleshooting (metadata can be totally wrong, but file name would always point to the correct file), but regardless, do you need any additional info? Anything else I can help with to troubleshoot this issue?
ebr 16342 Posted January 11, 2018 Posted January 11, 2018 Have you customized the overlays at all? Entered anything into the custom overlay path?
alekdavis 2 Posted January 11, 2018 Author Posted January 11, 2018 Not sure what you mean, but I did not customize anything. Just installed the CoverArt plugin and left it as-is.
