ebr 16337 Posted January 7, 2018 Posted January 7, 2018 For some reason the beta didnt overwrite the release version and was opening that one instead. Correct, on Amazon they are two separate apps. You can have them both installed at the same time so need to pay attention to which one you are running.
TylerV76 84 Posted January 7, 2018 Author Posted January 7, 2018 Correct, on Amazon they are two separate apps. You can have them both installed at the same time so need to pay attention to which one you are running. I ran the beta last night and for the most part it was good. It dumped me out of a show once with the error message again but it started back up no problem
