denisb88 1 Posted January 4, 2018 Posted January 4, 2018 (edited) I have installed the last Emby Server on my new DS218+ and Cover Art plugin Unfortunately, Art covers are too small, bad or correct without any reason How to fix it Edited January 4, 2018 by denisb88
Luke 42253 Posted January 4, 2018 Posted January 4, 2018 Hi, does this happen without the cover art plugin installed?
denisb88 1 Posted January 4, 2018 Author Posted January 4, 2018 No without plugin, everything works correctly
Abobader 3485 Posted January 5, 2018 Posted January 5, 2018 Good day, Maybe you enable this in the profile: If it checked, uncheck that option and see if that fix the issue, otherwise, Ebr will find out what the problem. My best
denisb88 1 Posted January 5, 2018 Author Posted January 5, 2018 (edited) checked ou unchecked, it's the same thing And this is what I get when I try to setup display. Edited January 5, 2018 by denisb88
denisb88 1 Posted January 5, 2018 Author Posted January 5, 2018 (edited) I have tried to install the previous version of the plugin but it freezes the server Edited January 5, 2018 by denisb88
denisb88 1 Posted January 8, 2018 Author Posted January 8, 2018 I have updated with the last version of Emby Now the plugin makes Emby crashing everytime I launch Emby It seems that this plugin doesn't work with DS218+
Luke 42253 Posted January 8, 2018 Posted January 8, 2018 Please attach the information requested in how to report a problem. t hanks !
denisb88 1 Posted January 8, 2018 Author Posted January 8, 2018 Here is the log when server stops after installing pluging. Version 3.2.60.0 log.txt
Luke 42253 Posted January 9, 2018 Posted January 9, 2018 Ok, it looks like there might be an issue with the plugin and the combination of settings that you're using. We'll look at this soon. In the meantime you may want to uninstall it for now, and/or go back to CoverArt default settings. Thanks.
denisb88 1 Posted January 9, 2018 Author Posted January 9, 2018 Thanks but that's what I have done many times. But always the same error
