Luke 42241 Posted January 4, 2018 Posted January 4, 2018 Try the new option in display settings to switch to the vertical home screen design ! Enjoy.
Navras 3 Posted April 5, 2018 Posted April 5, 2018 Try the new option in display settings to switch to the vertical home screen design ! Enjoy. Where to get this application? of Samsung app store?
FrostByte 5453 Posted April 5, 2018 Posted April 5, 2018 Where to get this application? of Samsung app store? Yes, but the app is currently only available in the Samsung app store within the US, UK, and Ireland while Luke is working to get the app released world-wide. If you don't want to wait you could try changing your tv region to one of those countries, but you would lose any/all local apps you may be using if you do so. After the app is released world-wide then you could change your region setting back.
Navras 3 Posted April 8, 2018 Posted April 8, 2018 Yes, but the app is currently only available in the Samsung app store within the US, UK, and Ireland while Luke is working to get the app released world-wide. If you don't want to wait you could try changing your tv region to one of those countries, but you would lose any/all local apps you may be using if you do so. After the app is released world-wide then you could change your region setting back. Thanks for the advice, I know about the change of region, but it does not suit me 1
