kikinjo 294 Posted January 3, 2018 Posted January 3, 2018 Hi all, Let me say first emby is great ! Few questions : 1. IPTV with m3u, who initiates the stream towards iptv provider, client (emby theather for example) or the emby server? 2. Any way to point Emby server to use a proxy server ? 3. Is there a way to completly disable transcoding? thank you
Luke 42204 Posted January 3, 2018 Posted January 3, 2018 IPTV with m3u, who initiates the stream towards iptv provider, client (emby theather for example) or the emby server? Depends on which app, but usually the server.
Luke 42204 Posted January 3, 2018 Posted January 3, 2018 Any way to point Emby server to use a proxy server ? can't you setup your own proxy server and create your own m3u based on that?
Luke 42204 Posted January 3, 2018 Posted January 3, 2018 Is there a way to completly disable transcoding? Sure, you can disable user permissions for transcoding but that might cause playback failures due unsupported media.
kikinjo 294 Posted January 3, 2018 Author Posted January 3, 2018 Depends on which app, but usually the server. Windows Emby app for example ?
kikinjo 294 Posted January 3, 2018 Author Posted January 3, 2018 can't you setup your own proxy server and create your own m3u based on that? I m already running squid on the server, thats why i m asking not only for m3u but for other caching needs.
Luke 42204 Posted January 3, 2018 Posted January 3, 2018 Ok. There are no proxy server settings inside emby if that's what you mean.
kikinjo 294 Posted January 3, 2018 Author Posted January 3, 2018 Ok. There are no proxy server settings inside emby if that's what you mean. Thank you for your quick answers. Could you be so kind and confirm that windows Emby Theather app is using server connection for iptv m3u streams and not the client app.
