glandpuck 0 Posted January 3, 2018 Posted January 3, 2018 My channel guide does not work using zap2xml or schedules direct. I get a SQL error message. This is from my log file: 2018-01-02 09:51:11.865 Error HttpServer: Error processing request*** Error Report ***Version: 3.2.60.0Command line: C:\Users\xxxxx\AppData\Roaming\Emby-Server\system\EmbyServer.dllOperating system: Microsoft Windows NT 6.2.9200.064-Bit OS: True64-Bit Process: TrueUser Interactive: TrueProcessor count: 8Program data path: C:\Users\xxxxx\AppData\Roaming\Emby-ServerApplication directory: C:\Users\xxxxx\AppData\Roaming\Emby-Server\systemCorrupt: database disk image is malformedSQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at Emby.Server.Implementations.Data.SqliteExtensions.<ExecuteQuery>d__36.MoveNext() at Emby.Server.Implementations.Data.SqliteItemRepository.<>c__DisplayClass64_0.<GetItems>b__0(IDatabaseConnection db) at SQLitePCL.pretty.DatabaseConnection.RunInTransaction[T](IDatabaseConnection This, Func`2 f, TransactionMode mode) at Emby.Server.Implementations.Data.SqliteItemRepository.GetItems(InternalItemsQuery query) at Emby.Server.Implementations.Library.LibraryManager.GetItemsResult(InternalItemsQuery query) at Emby.Server.Implementations.LiveTv.LiveTvManager.GetInternalChannels(LiveTvChannelQuery query, DtoOptions dtoOptions, CancellationToken cancellationToken) at MediaBrowser.Api.LiveTv.LiveTvService.Get(GetChannels request) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__72.MoveNext()SQLitePCL.pretty.SQLiteException at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at Emby.Server.Implementations.Data.SqliteExtensions.<ExecuteQuery>d__36.MoveNext() at Emby.Server.Implementations.Data.SqliteItemRepository.<>c__DisplayClass64_0.<GetItems>b__0(IDatabaseConnection db) at SQLitePCL.pretty.DatabaseConnection.RunInTransaction[T](IDatabaseConnection This, Func`2 f, TransactionMode mode) at Emby.Server.Implementations.Data.SqliteItemRepository.GetItems(InternalItemsQuery query) at Emby.Server.Implementations.Library.LibraryManager.GetItemsResult(InternalItemsQuery query) at Emby.Server.Implementations.LiveTv.LiveTvManager.GetInternalChannels(LiveTvChannelQuery query, DtoOptions dtoOptions, CancellationToken cancellationToken) at MediaBrowser.Api.LiveTv.LiveTvService.Get(GetChannels request) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__72.MoveNext() I haven't figured out how to fix it. Help would be appreciated.
Solution Luke 42243 Posted January 3, 2018 Solution Posted January 3, 2018 Hi, please shutdown emby server, then rename this file: C:\Users\xxxxx\AppData\Roaming\Emby-Server\data\library.db Then start emby server and you'll need to run a library scan and refresh your guide. Typical causes of this are sudden terminations of the emby server process - for example, a power loss, abruptly killing the server process, abruptly shutting down your machine, etc. Please let us know if this helps. 1
glandpuck 0 Posted January 3, 2018 Author Posted January 3, 2018 That solved the problem and all is now working. I did have a power outage a while back. The computer is now on a UPS. Thanks.
Jim-Bob Billy-io 0 Posted January 15, 2018 Posted January 15, 2018 Forgive me for being ignorant; but, rename the file to what?
Luke 42243 Posted January 15, 2018 Posted January 15, 2018 Forgive me for being ignorant; but, rename the file to what? To anything different, and the server will generate a new one the next time you start it. I said rename rather than to delete just in case you may want to try and extract something from it at some point.
