Incremental Sync Running Frequently. Always seems to be parsing same items.
Go to solution Solved by ChipWhisperer,
ChipWhisperer
When sitting in Kodi, the incremental sync seems to re run every 2-3 minutes, always refreshing data for the same 72 items.
This issue has persisted through a library repair, and was happening in the previous version, as well as the newest version of the add which I  updated to last night.
Logs attached.
Edited by Angelblue05
Angelblue05
@@ChipWhisperer
Thank for the log. Incremental syncs are triggered by the server. Therefore you should look there to see why it's sending out so many updates constantly. It's definitely not normal. Sorry that I can't help you more, I'd start checking your server logs to see when the updates happens in Kodi, what the server was doing at the time and why.
  • Like 1
  • Solution
ChipWhisperer
Thanks for the reply.
After restarting the server a few times, the issue seems to have resolved.
I'll have to look more closely if it happens again.
  • Like 1
Guest
