Guest Posted January 1, 2018 Posted January 1, 2018 Hello, today I installed emby on my new Ds918+. Everything is working quite nice besides the download of subtitles from opensubtitles.org. The Logs says something about connection reset by peer, but i don't know what to do now. I already tried to change the DNS to google's, but this doesn't help. Also tried to "talk" with the API with wget from my Synology via ssh. With that I am able to get a response, so the connection itself is working. Trying to capture some packets with tcpdump confirmes the "reset by peer", but with https I cannot see any information. Anybode know if there is a fix? Kind regards 2018-01-01 19:37:16.650 Error HttpClient: Error ReceiveFailure getting response from https://api.opensubtitles.org/xml-rpc *** Error Report *** Version: 3.2.50.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -restartpath /var/packages/EmbyServer/scripts/restart Operating system: Unix 4.4.15.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.2.0.224 (tarball Mon Sep 25 18:34:32 CST 2017) Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/v3.2.50.0 System.Net.WebException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00003] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x00027] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00058] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <d31cad56a57f4677b3b2262d472abcad>:0 System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00058] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <d31cad56a57f4677b3b2262d472abcad>:0 InnerException: System.IO.IOException System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00003] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x00027] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00003] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x00027] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 InnerException: System.Net.Sockets.SocketException System.Net.Sockets.SocketException (0x80004005): Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 2018-01-01 19:37:16.658 Error SubtitleManager: Error downloading subtitles from Open Subtitles *** Error Report *** Version: 3.2.50.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -restartpath /var/packages/EmbyServer/scripts/restart Operating system: Unix 4.4.15.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.2.0.224 (tarball Mon Sep 25 18:34:32 CST 2017) Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/v3.2.50.0 MediaBrowser.Model.Net.HttpException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.Net.WebException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00003] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x00027] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00058] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <d31cad56a57f4677b3b2262d472abcad>:0 --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__19.MoveNext () [0x0072e] in <9742a2042076413cbc6bfeeacbc56f94>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsync>d__16.MoveNext () [0x0009f] in <9742a2042076413cbc6bfeeacbc56f94>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at OpenSubtitlesHandler.Utilities+<SendRequestAsync>d__20.MoveNext () [0x000de] in <b90a4ece0cec40099d95d4e5d7864e7d>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at OpenSubtitlesHandler.OpenSubtitles+<SearchSubtitlesAsync>d__8.MoveNext () [0x002ea] in <b90a4ece0cec40099d95d4e5d7864e7d>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at MediaBrowser.MediaEncoding.Subtitles.OpenSubtitleDownloader+<Search>d__24.MoveNext () [0x0047c] in <e2abfa33664e46dbaa5eee4b5d8f6f4e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at MediaBrowser.Providers.Subtitles.SubtitleManager+<>c__DisplayClass15_0+<<SearchSubtitles>b__1>d.MoveNext () [0x00086] in <ac361c26e5084feeaa1d0d745c9b0949>:0 MediaBrowser.Model.Net.HttpException at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__19.MoveNext () [0x0072e] in <9742a2042076413cbc6bfeeacbc56f94>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsync>d__16.MoveNext () [0x0009f] in <9742a2042076413cbc6bfeeacbc56f94>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at OpenSubtitlesHandler.Utilities+<SendRequestAsync>d__20.MoveNext () [0x000de] in <b90a4ece0cec40099d95d4e5d7864e7d>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at OpenSubtitlesHandler.OpenSubtitles+<SearchSubtitlesAsync>d__8.MoveNext () [0x002ea] in <b90a4ece0cec40099d95d4e5d7864e7d>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at MediaBrowser.MediaEncoding.Subtitles.OpenSubtitleDownloader+<Search>d__24.MoveNext () [0x0047c] in <e2abfa33664e46dbaa5eee4b5d8f6f4e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <d31cad56a57f4677b3b2262d472abcad>:0 at MediaBrowser.Providers.Subtitles.SubtitleManager+<>c__DisplayClass15_0+<<SearchSubtitles>b__1>d.MoveNext () [0x00086] in <ac361c26e5084feeaa1d0d745c9b0949>:0 InnerException: System.Net.WebException System.Net.WebException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00003] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x00027] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00058] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <d31cad56a57f4677b3b2262d472abcad>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00058] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <d31cad56a57f4677b3b2262d472abcad>:0 InnerException: System.IO.IOException System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00003] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x00027] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00003] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x00027] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 InnerException: System.Net.Sockets.SocketException System.Net.Sockets.SocketException (0x80004005): Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x0009b] in <7bc83f72cfb44c1eac96d11ef998e9a2>:0
Luke 42241 Posted January 1, 2018 Posted January 1, 2018 Once 3.2.60 is available please try that because we reworked a lot of the subtitle downloading. Although if the issue is coming from the remote server then it won't make any difference. To be honest, I wouldn't really worry about this too much. We're downloading from a remote server and we can't predict or guarantee their availability. The good news is that if it fails it will try again the next time so that's why I would just see what happens the next time. Thanks.
Guest Posted January 1, 2018 Posted January 1, 2018 Thanks for your answere. I tried 3.2.60 and 3.2.50 on Windows and with both version i can download the subtitles. So I'm thinking that the external server or the version on my Synology is not the problem. It seems that my synology is the problem, but i don't know how to prove / solve that.
Luke 42241 Posted January 1, 2018 Posted January 1, 2018 Are you able to download any subtitles? If it is random, then why stress about it? Just let the next run of the scheduled task get them.
Guest Posted January 1, 2018 Posted January 1, 2018 No I'm not able to download any subtitles. Since installing emby none subtitles could be downloaded, neither manual nor with the scheduled task.
Luke 42241 Posted January 1, 2018 Posted January 1, 2018 Ok that's very strange. I haven't seen that reported by anyone else. Let's see if 3.2.60 makes a difference. Thanks.
Guest Posted January 1, 2018 Posted January 1, 2018 (edited) Ok I will wait, but i don't think 3.2.60 will help. I tried installing 3.2.60 with docker on my Synology only to check if I can manually download subtitles. But I also get a "connection reset by peer" error. So now I don't really know what to to now edit: I've tried using Plex to load from opensubtitles and it worked. So maybe my Synology is not the problem. But then I can't explain why it is not working with 3.2.50 and 3.2.60 on docker. Edited January 1, 2018 by marzig
Luke 42241 Posted January 2, 2018 Posted January 2, 2018 Can you supply a new log from 3.2.60? thanks.
Guest Posted January 7, 2018 Posted January 7, 2018 (edited) Hello. Sorry for the late answere. The log from 3.2.60 Version running with docker shows the same error (connection reset). BTW downloading Subtitles from opensubtitles.org using Video Station from Synology or Plex is working edit: Tried manually calling the xml-rpc webservice with curl using the same url as in the log file (https://api.opensubtitles.org/xml-rpc). I've used the embysvr user with putty (version 3.2.50), also the docker root user (version 3.2.60) and also one "normal" user using ssh with putty. I tried using the ServerInfo() call and the Login() call with my credentials. All of this is working nicley. I've got a "200 Ok" response and could search for subtitles using the token from the login() call. So it seems that my network / network-configuration etc. is not the problem, right? edit end; 2018-01-07 14:51:09.330 Info HttpServer: HTTP Response 204 to 172.17.0.1. Time: 65ms. http://192.168.2.123:8096/emby/DisplayPreferences/usersettings?userId=c3583c2eebc54141a5ce1e7679b0a13e&client=emby 2018-01-07 14:51:09.333 Info HttpClient: HttpClientManager POST: https://api.opensubtitles.org/xml-rpc 2018-01-07 14:51:09.500 Info HttpClient: HttpClientManager POST: https://api.opensubtitles.org/xml-rpc 2018-01-07 14:51:24.534 Error HttpClient: Error ReceiveFailure getting response from https://api.opensubtitles.org/xml-rpc *** Error Report *** Version: 3.2.60.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.4.15.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Sun Oct 1 17:55:43 UTC 2017) Processor count: 4 Program data path: /config Application directory: /usr/lib/emby-server/bin System.Net.WebException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00055] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x0002a] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 InnerException: System.IO.IOException System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00055] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x0002a] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00055] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x0002a] in <5641e4edad4f4464ba58c620a7b8ea48>:0 InnerException: System.Net.Sockets.SocketException System.Net.Sockets.SocketException (0x80004005): Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 2018-01-07 14:51:24.542 Error SubtitleManager: Error downloading subtitles from Open Subtitles *** Error Report *** Version: 3.2.60.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.4.15.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Sun Oct 1 17:55:43 UTC 2017) Processor count: 4 Program data path: /config Application directory: /usr/lib/emby-server/bin MediaBrowser.Model.Net.HttpException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.Net.WebException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00055] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x0002a] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__19.MoveNext () [0x0072e] in <a12a7c6217e143eaa39430af322cb07e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsync>d__16.MoveNext () [0x0009f] in <a12a7c6217e143eaa39430af322cb07e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at MediaBrowser.MediaEncoding.Subtitles.OpenSubtitleDownloader+<SearchSubtitlesAsync>d__33.MoveNext () [0x00226] in <9660b9518eb6424a914dff2c53832dbf>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at MediaBrowser.MediaEncoding.Subtitles.OpenSubtitleDownloader+<Search>d__32.MoveNext () [0x00468] in <9660b9518eb6424a914dff2c53832dbf>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at MediaBrowser.Providers.Subtitles.SubtitleManager+<>c__DisplayClass15_0+<<SearchSubtitles>b__1>d.MoveNext () [0x00086] in <4c8e7501588b4a22955bf3cb6abe85f5>:0 MediaBrowser.Model.Net.HttpException at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__19.MoveNext () [0x0072e] in <a12a7c6217e143eaa39430af322cb07e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager+<SendAsync>d__16.MoveNext () [0x0009f] in <a12a7c6217e143eaa39430af322cb07e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at MediaBrowser.MediaEncoding.Subtitles.OpenSubtitleDownloader+<SearchSubtitlesAsync>d__33.MoveNext () [0x00226] in <9660b9518eb6424a914dff2c53832dbf>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at MediaBrowser.MediaEncoding.Subtitles.OpenSubtitleDownloader+<Search>d__32.MoveNext () [0x00468] in <9660b9518eb6424a914dff2c53832dbf>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at MediaBrowser.Providers.Subtitles.SubtitleManager+<>c__DisplayClass15_0+<<SearchSubtitles>b__1>d.MoveNext () [0x00086] in <4c8e7501588b4a22955bf3cb6abe85f5>:0 InnerException: System.Net.WebException System.Net.WebException: Error getting response stream (ReadDone1): ReceiveFailure ---> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00055] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x0002a] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 InnerException: System.IO.IOException System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00055] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x0002a] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndReadOrWrite (System.IAsyncResult asyncResult, Mono.Net.Security.AsyncProtocolRequest& nestedRequest) [0x00055] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.WebConnection.ReadDone (System.IAsyncResult result) [0x0002a] in <5641e4edad4f4464ba58c620a7b8ea48>:0 InnerException: System.Net.Sockets.SocketException System.Net.Sockets.SocketException (0x80004005): Connection reset by peer at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.Socket.Receive (System.Byte[] buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00052] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 size) [0x000b4] in <5641e4edad4f4464ba58c620a7b8ea48>:0 2018-01-07 14:51:24.559 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 15344ms (slow). http://192.168.2.123:8096/emby/Items/a5e605061adcade0807733e9a49f4803/RemoteSearch/Subtitles/ger Edited January 7, 2018 by marzig
Luke 42241 Posted January 7, 2018 Posted January 7, 2018 Yea at the moment I'm not quite sure because I'm not able to reproduce the problem, and nobody else is reporting it. We'll continue to investigate. Thanks.
