cryzis 7 Posted January 1, 2018 Posted January 1, 2018 I was testing this app to see what files could be direct played. It looks like the TV can handle all video formats and most audio formats (still waiting to test TrueHD which I don't think will work) The issue I discovered is that the only way to get the server to direct play some of these files is to disable video/audio/and remuxing for the user. It seems from the logs that the server checks the TVs profiles for compatibility, doesn't find it so it starts to transcode/remux. Whatever method is being used to detect compatibility on these TVs looks to be incorrect. Is this a known issue?
Luke 42237 Posted January 1, 2018 Posted January 1, 2018 hi there, can we take a look at an example? please attach the information requested in how to report a media playback issue. thanks !
cryzis 7 Posted January 1, 2018 Author Posted January 1, 2018 Here are the logs. In this example I first played The Expendables 3 (2014) under a user account that had video/audio/remuxing disabled. It direct played, this file has a TrueHD audio stream. I then enabled video/audio/remuxing and after pressing play the screen was black for about 30 seconds while the server switched from direct play to transcoding. The transcode began and the video started playing. So even though the file can be direct played the server for some reason doesn't see this capability in the TVs profiles so it forces transcoding. server-63650426734.txt
Luke 42237 Posted January 1, 2018 Posted January 1, 2018 Can you please copy and paste the media info of this file from the web app into here? thanks.
cryzis 7 Posted January 2, 2018 Author Posted January 2, 2018 As requested Media Info VideoCodecHEVCProfileMain 10Level153Resolution3840x2160Aspect ratio16:9AnamorphicNoInterlacedNoFramerate23.9760246Bitrate60868 kbpsPixel formatyuv420p10leRef frames1Title4K HEVC AudioLanguageengCodecTRUEHDLayout7.1Channels8 chSample rate48000 HzBit depth24 bitDefaultYesTitleEng TRUEHD 7.1 Default AudioLanguageengCodecAC3Layout5.1Channels6 chBitrate640 kbpsSample rate48000 HzDefaultNoTitleEng Dolby Digital 5.1 Containermkv Path/bfp/Media/Movies/The Expendables 3 (2014)/The Expendables 3 (2014).mkv
Luke 42237 Posted January 2, 2018 Posted January 2, 2018 Do you have an audio receiver that supports truehd? when you force direct play does the truehd get passed all the way to your receiver? thanks.
cryzis 7 Posted January 2, 2018 Author Posted January 2, 2018 Audio is being played through the TV's speakers. Which must be getting converted by the TV? So I think the TV accepts the codec but converts it for playback. My understanding is that only 2017 models support TrueHD passthrough.
Luke 42237 Posted January 3, 2018 Posted January 3, 2018 Yea I think we'll have to adjust the app for the new models, thanks.
robawarner 0 Posted January 3, 2018 Posted January 3, 2018 (edited) Hey, just to weigh in. I have a new 43UJ670V 2017 TV, I've edited the LG DLNA profile to allow direct play for all, however it still transcodes for anything with TrueHD audio too (also, if I try to change audio source on a movie with multiple audio tracks to a non TrueHD emby crashes) Let me know if there's any info I can provide to help Edited January 3, 2018 by robawarner
Luke 42237 Posted January 3, 2018 Posted January 3, 2018 The dlna profile won't affect the app. Thanks.
tonytwist 0 Posted January 15, 2018 Posted January 15, 2018 Hi all, I'm on a 2017 b7 OLED with emby v104 and have no issues direct playing HEVC 4k video by editing the DLNA profile, but trueHD and DTS-HD will not pass thru. I get downgraded to plain DD5.1 or DTS. Apologies if this has already been covered. My understanding is that the 2017 models can pass thru these formats. Is that correct? Limitation of the emby app? Thanks,
andyblac644 69 Posted January 15, 2018 Posted January 15, 2018 Hi all, I'm on a 2017 b7 OLED with emby v104 and have no issues direct playing HEVC 4k video by editing the DLNA profile, but trueHD and DTS-HD will not pass thru. I get downgraded to plain DD5.1 or DTS. Apologies if this has already been covered. My understanding is that the 2017 models can pass thru these formats. Is that correct? Limitation of the emby app? Thanks, I believe no 2017 can do DTS-HD, The manual is accurate. Marketing website is not HDMI Audio Supported Format: DTS (44.1 kHz / 48 kHz), Dolby Digital / Dolby Digital Plus (32 kHz / 44.1 kHz / 48 kHz), PCM (32 kHz / 44.1 kHz / 48 kHz / 96 kHz / 192 kHz) (Depending on model) Dolby TrueHD was recently added in Oct 2017 firmware
tonytwist 0 Posted January 15, 2018 Posted January 15, 2018 Thanks guys. In that case, TrueHD will still not pass thru, it is downgraded to DD5.1 Let me know if I can gather any additional info to help.
andyblac644 69 Posted January 15, 2018 Posted January 15, 2018 Thanks guys. In that case, TrueHD will still not pass thru, it is downgraded to DD5.1 Let me know if I can gather any additional info to help. maybe try the movie on a USB stick and play with the LG media player, to confirm your TV can play TrueHD
Luke 42237 Posted January 15, 2018 Posted January 15, 2018 The next release of the app will have direct play improvements. thanks guys.
tonytwist 0 Posted January 15, 2018 Posted January 15, 2018 So I went back and tried running my ps4 through the b7 OLED with pass thru audio to my marantz reciever. Result is: both TrueHD and DTS-HD will not work. DTS-HD downgrades to DTS and TrueHD just outputs static. Both of these test movies light up the proper audio when directly connected thru the receiver. The tv is running os version 4.70.36 from December. Long story short, the emby app may not be the issue here. I think the b7 (2017) still has a problem with passing thru TrueHD.
andyblac644 69 Posted January 15, 2018 Posted January 15, 2018 (edited) So I went back and tried running my ps4 through the b7 OLED with pass thru audio to my marantz reciever. Result is: both TrueHD and DTS-HD will not work. DTS-HD downgrades to DTS and TrueHD just outputs static. Both of these test movies light up the proper audio when directly connected thru the receiver. The tv is running os version 4.70.36 from December. Long story short, the emby app may not be the issue here. I think the b7 (2017) still has a problem with passing thru TrueHD. are you trying to passthrough TrueHD to your AMP via ARC, that will not be possible until HDMI 2.1 with eARC. HD audio is not supported in ARC via HDMI 2.0, on ANY device, is is not supported the the standard. Edited January 15, 2018 by andyblac644
tonytwist 0 Posted January 15, 2018 Posted January 15, 2018 Thanks Andy, that makes sense. Just to be clear -- does that also mean that emby running on the LG TV with audio output to a receiver with HDMI would be considered ARC and suffer the same limitation? My ultimate goal here is to play 4k HEVC content with uncompressed audio via emby on the LG TV. Possible?
andyblac644 69 Posted January 16, 2018 Posted January 16, 2018 (edited) Thanks Andy, that makes sense. Just to be clear -- does that also mean that emby running on the LG TV with audio output to a receiver with HDMI would be considered ARC and suffer the same limitation? My ultimate goal here is to play 4k HEVC content with uncompressed audio via emby on the LG TV. Possible? yes, this will not be possible until 2019, LG have no plans releasing a TV with HDMI 2.1 in 2018, the standard was ratified too late. And imo DTS-HD and TrueHD / Atmos for a tv without a A/V receiver is just a sales gimmick. Edited January 16, 2018 by andyblac644
Luke 42237 Posted March 22, 2018 Posted March 22, 2018 Emby for LG 1.06 has just been released. Please try it out. Thanks !
