ebr 16337 Posted January 10, 2018 Posted January 10, 2018 backed out of the stream, and then sent the log from the app's setting section. So, the app was responsive? You were able to just back out of playback?
TolkienBard 58 Posted January 12, 2018 Posted January 12, 2018 We needed to use the "Home" button to back out of the app and take us to the main menu. The back button did not respond.
ebr 16337 Posted January 12, 2018 Posted January 12, 2018 We needed to use the "Home" button to back out of the app and take us to the main menu. The back button did not respond. And, after hitting home, exactly what did you do?
TolkienBard 58 Posted January 18, 2018 Posted January 18, 2018 Sorry about the delayed response. It's the beginning of a new term and things are a bit hectic around here. After hitting home, we navigated to sending the Emby app logs and executed that. Then we poured shots, climbed in an Uber and went to dinner.
leekingsnatch 5 Posted January 30, 2018 Author Posted January 30, 2018 (edited) When the problem happens, is it always on a specific time like right at the top or bottom of the hour? Sorry for the delay, it's been some time but the problem continues. However, I did see a pattern emerge. I switched from m3u TV streams and went with a HD Homerun tuner. The pattern that I've seen emerge watching TV this way, is at exactly 1 minute past the hour, the video starts to stutter, then the screen goes gray and I have to hit Home, force stop the emby app and then get back into Emby. What happens at 1 minute past the hour? I am using Schedules direct, could that somehow interfere? Thanks Edited January 30, 2018 by leekingsnatch
ebr 16337 Posted January 30, 2018 Posted January 30, 2018 Sorry for the delay, it's been some time but the problem continues. However, I did see a pattern emerge. I switched from m3u TV streams and went with a HD Homerun tuner. The pattern that I've seen emerge watching TV this way, is at exactly 1 minute past the hour, the video starts to stutter, then the screen goes gray and I have to hit Home, force stop the emby app and then get back into Emby. What happens at 1 minute past the hour? I am using Schedules direct, could that somehow interfere? Thanks Okay, thanks that gives me someplace to look. At that time, it was also starting a new program, correct?
leekingsnatch 5 Posted January 30, 2018 Author Posted January 30, 2018 Okay, thanks that gives me someplace to look. At that time, it was also starting a new program, correct? correct
ebr 16337 Posted January 30, 2018 Posted January 30, 2018 Okay, exactly how are you initially starting playback of the channel and do you have proper guide data for it?
leekingsnatch 5 Posted January 30, 2018 Author Posted January 30, 2018 Okay, exactly how are you initially starting playback of the channel and do you have proper guide data for it? It depends. Sometimes I start straight from the guide, other times I go to Channel and select the channel. I would say most of the time I start from the Channels. The channel guide data seems to be correct.
ebr 16337 Posted January 30, 2018 Posted January 30, 2018 Okay, I've made a change in the next beta that may address it. If you can test it when available that would be great.
leekingsnatch 5 Posted January 30, 2018 Author Posted January 30, 2018 Okay, I've made a change in the next beta that may address it. If you can test it when available that would be great. So if I downwload the "Test" version of emby for fireTV it will have the change you mentioned?
ebr 16337 Posted January 30, 2018 Posted January 30, 2018 So if I downwload the "Test" version of emby for fireTV it will have the change you mentioned? Yes, if you are already in the beta program and once I release a new version later today.
leekingsnatch 5 Posted January 30, 2018 Author Posted January 30, 2018 Yes, if you are already in the beta program and once I release a new version later today. I am. Would you post something to let me know when the new version is released? Thanks
leekingsnatch 5 Posted January 31, 2018 Author Posted January 31, 2018 Yes, if you are already in the beta program and once I release a new version later today. If this fix was included in the January 30 release of "Test" Emby, the problem persists. At 7:01 this morning, live tv crashed to a gray screen.
ebr 16337 Posted January 31, 2018 Posted January 31, 2018 If this fix was included in the January 30 release of "Test" Emby, the problem persists. At 7:01 this morning, live tv crashed to a gray screen. Can you please confirm the version from the settings screen?
leekingsnatch 5 Posted January 31, 2018 Author Posted January 31, 2018 Can you please confirm the version from the settings screen? The version is 1.5.37a
ebr 16337 Posted February 1, 2018 Posted February 1, 2018 The next time this happens, can you please post the server log and note the time? Thanks.
leekingsnatch 5 Posted February 2, 2018 Author Posted February 2, 2018 The next time this happens, can you please post the server log and note the time? Thanks. Attached server log. The TV stream stopped again at 7:01 a.m. EST. embyserverlog_2_2_2018.txt
Luke 42245 Posted February 2, 2018 Posted February 2, 2018 Attached server log. The TV stream stopped again at 7:01 a.m. EST. Try shutting down the omni software and keeping it off. it is hammering your emby server with large amounts of requests over a short period of time.
leekingsnatch 5 Posted February 2, 2018 Author Posted February 2, 2018 Try shutting down the omni software and keeping it off. it is hammering your emby server with large amounts of requests over a short period of time. Are you referring to Ombi? I can, but every hour a minute past the hour the streaming stops like clockwork and you are telling me it's Ombi doing this when every other streaming works fine except Live TV? Besides, I just enabled Ombi 2 days ago, and this has has been going on for weeks. I can't fathom that being the problem.
leekingsnatch 5 Posted February 2, 2018 Author Posted February 2, 2018 Are you referring to Ombi? I can, but every hour a minute past the hour the streaming stops like clockwork and you are telling me it's Ombi doing this when every other streaming works fine except Live TV? Besides, I just enabled Ombi 2 days ago, and this has has been going on for weeks. I can't fathom that being the problem. What you are probably seeing is the User Import function. I set the import to happen only once a day so it should stop hammering it.
ebr 16337 Posted February 2, 2018 Posted February 2, 2018 Okay, this may be happening somewhere other than I was thinking it was. The next time you are playing something from Live TV, if you don't mind, try backing out of it at about the top of the hour + 30 seconds to try and catch it just before the crash. Then send the log. Thanks.
leekingsnatch 5 Posted February 2, 2018 Author Posted February 2, 2018 Okay, this may be happening somewhere other than I was thinking it was. The next time you are playing something from Live TV, if you don't mind, try backing out of it at about the top of the hour + 30 seconds to try and catch it just before the crash. Then send the log. Thanks. The app log, the server log or both?
ebr 16337 Posted February 2, 2018 Posted February 2, 2018 The app log, the server log or both? The log from the app. Thanks.
leekingsnatch 5 Posted February 3, 2018 Author Posted February 3, 2018 The log from the app. Thanks. I cannot get the app to stop right before it crashes. I narrowed it down to about 1 minute and 15 seconds after being the time it crashes. However, waiting until 1 after, the app becomes unresponsive, can't click Back. The best I can do is to wait for it to crash, stop the app and send you the log which you should had gotten at about 9:03 a.m. EST. Let me know if you got it. Thanks
