Croll12 3 Posted January 1, 2018 Posted January 1, 2018 Continue Watching on the FireTV fills up the screen. Any time I watch a live tv channel or movie it list continue watching on left side. If I watch the channel again it duplicates, and again, again, etc. now I have 12 Continue watching on the side of the same channel or movie. Anyway to stop this?
ebr 16337 Posted January 1, 2018 Posted January 1, 2018 Hi. This is not normal. Can you please describe exactly how you are starting and stopping these items?
Croll12 3 Posted January 1, 2018 Author Posted January 1, 2018 Going to TV guide and then watching a channel. Going back to main screen displays continue watching. Watching another channel does the same. Watching a movie does the same.
CBers 7554 Posted January 1, 2018 Posted January 1, 2018 I reported an instance of multiple Continue Watching rows months ago, which was fixed, and I've only had it occur once since then. I was never able to reproduce it.
Croll12 3 Posted January 1, 2018 Author Posted January 1, 2018 Did you do anything different to fix yours? This is a new install and it happens every time I watch something.
CBers 7554 Posted January 1, 2018 Posted January 1, 2018 No, it was a fix that Eric (ebr) put in. As I said, I've only seen it once since then.
ebr 16337 Posted January 2, 2018 Posted January 2, 2018 Hi. Can you please give me the exact steps you are taking? Exactly what you click on and how you navigate, for example, "back to the main screen". Thanks.
Croll12 3 Posted January 2, 2018 Author Posted January 2, 2018 I use the fire tv remote. Navigating with the arrow pad and clicking the middle button to select. Then select tune channel. When done watching the move or channel, I hit the back button on remote (half circle arrow pointing to the left).
ebr 16337 Posted January 3, 2018 Posted January 3, 2018 Okay, can you please do this a couple of times and then send the log from the app? Be sure to come back here and provide the requested info. Thanks.
Croll12 3 Posted January 3, 2018 Author Posted January 3, 2018 Will do, but I won’t be home for a few days. Had to go out of town for work.
