davesurfer 18 Posted December 31, 2017 Posted December 31, 2017 So when I go into Display Settings, I find that the Screensaver and Sound Effects are set to "None", they don't turn off. The screensaver still appears and there are the sounds when navigating through menus, movies or skipping ahead during playback etc. I've turned them on and off again, but still it seems locked on. How can I resolve this glitch? Thanks!
davesurfer 18 Posted January 1, 2018 Author Posted January 1, 2018 We're looking into it, thanks. No huge emergency, thanks!
blaise 1 Posted April 5, 2024 Posted April 5, 2024 I'm experiencing this with Emby Theater on Windows 11. Display > "Sound effects" is set to None but navigation sounds are still on after I save.
blaise 1 Posted April 6, 2024 Posted April 6, 2024 I should have mentioned this is for navigating with a controller or keyboard.
Luke 42235 Posted April 9, 2024 Posted April 9, 2024 On 4/5/2024 at 8:09 PM, blaise said: I should have mentioned this is for navigating with a controller or keyboard. Hi, we'll take a look at it. Thanks for reporting.
