Stlk filmes 1 Posted November 11, 2019 Posted November 11, 2019 Just click this https://download.teamviewer.com/download/linux/teamviewer_amd64.deb Should download, double click the deb file, will open it in Gnome Software, click install. Good morning my friend, I have the same problem, I set up a virtual disk with Rclone synchronizing with my team drive account, the problem is that the server emby does not see the folder in the library, if you can help me I have AnyDesk so you would enter remotely on my vps server thanks
Stlk filmes 1 Posted November 11, 2019 Posted November 11, 2019 If you can help me, I mounted the virtual disks in the directory / usr / share / doc / emby-server and are as google-team and google-drive, I just need to give the permission that the emby server asks to see the folders. Thanks
Q-Droid 1011 Posted November 11, 2019 Posted November 11, 2019 You should really stop spamming every permissions related thread and create a new one for your specific problem. You are using cloud storage meaning it could very well be more than a simple permissions problem.
Stlk filmes 1 Posted November 11, 2019 Posted November 11, 2019 You should really stop spamming every permissions related thread and create a new one for your specific problem. You are using cloud storage meaning it could very well be more than a simple permissions problem. yes exactly, my storage is cloud, google drive plus the problem is being in linux. because windows has Raidriver that works perfect, because linux gives this problem with emby
