Quiptix 2 Posted December 30, 2017 Posted December 30, 2017 Hi, Just for me curiosity: What are the rules for transcoding the audio. I have got the impression that when you don't choose the primary audio stream (all streams DTS) it transcodes it to AC3. When choosing it seems to keep the stream in DTS format. Using QNAP server and the Emby LG app Isn't it possible to keep the DTS stream when remuxing the streams? Was not sure in which group to post, so I posted in General Vincent
Guest asrequested Posted December 30, 2017 Posted December 30, 2017 It all depends on what the app/device, supports. If they can play DTS, then it will. If not, the server will transcode it.
Quiptix 2 Posted December 30, 2017 Author Posted December 30, 2017 It all depends on what the app/device, supports. If they can play DTS, then it will. If not, the server will transcode it. The app (LG app) supports DTS, when using the first audio stream it remains DTS when remuxing, choosing another DTS it gets transcoded to AC3 (I allow audio transcoding for other devices, such as chromebook) I will investigate some more myself...
Luke 42204 Posted December 30, 2017 Posted December 30, 2017 When we remux we use the HLS format, and this does not support carrying DTS.
Quiptix 2 Posted December 30, 2017 Author Posted December 30, 2017 (edited) When we remux we use the HLS format, and this does not support carrying DTS. Oke, that explains somethings... So a MKV with 1 DTS audio stream isn't remuxed and remains DTS, every other MKV with multiple audiostreams gets remuxed? For this media file log states actually 2 things: Unknown Profile and secundary audio stream. Just trying to understand the behavor. Because not all MKV are remuxed when using the LG app Edited December 30, 2017 by Quiptix
Luke 42204 Posted December 30, 2017 Posted December 30, 2017 We'd have to look at a specific example. Thanks.
Quiptix 2 Posted December 30, 2017 Author Posted December 30, 2017 We'd have to look at a specific example. Thanks. I will find some examples as not all MKV's are remuxed when using the LG app
Quiptix 2 Posted December 30, 2017 Author Posted December 30, 2017 The most recent example is a media file with 3 DTS audio streams: Output of ffmpeg -i : <ision Course.2016] # ffmpeg -i Ice\ Age\ 5\ Collision\ Course.2016.1080p.H264.mkv ffmpeg version 2.8.5 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: --enable-cross-compile --arch=i686 --target-os=linux --disable-yasm --disable-static --enable-shared --enable-gpl --enable-libmp3lame --enable-libx264 --enable-libvo-aacenc --enable-libsoxr --enable-version3 --enable-nonfree --disable-decoder=ac3 --disable-decoder=ac3_fixed --disable-decoder=eac3 --disable-decoder=dca --disable-decoder=truehd --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-encoder=dca --extra-ldflags='-L/root/daily_build/64_27/4.3.3/Model/TS-269/build/RootFS/usr/local/medialibrary/lib -Wl,--rpath -Wl,/usr/local/medialibrary/lib' --extra-cflags='-I/root/daily_build/64_27/4.3.3/Model/TS-269/build/RootFS/usr/local/medialibrary/include -D_GNU_SOURCE -DQNAP' --prefix=/root/daily_build/64_27/4.3.3/Model/TS-269/build/RootFS/usr/local/medialibrary libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Guessed Channel Layout for Input Stream #0.1 : 5.1 Guessed Channel Layout for Input Stream #0.2 : 5.1 Guessed Channel Layout for Input Stream #0.3 : 5.1 Input #0, matroska,webm, from 'Ice Age 5 Collision Course.2016.1080p.H264.mkv': Metadata: title : Ice.Age.5.Collision.Course.2016.1080p.BluRay.DTS.x264-MoBee1 encoder : libebml v1.3.1 + libmatroska v1.4.2 creation_time : 2016-10-24 04:19:51 Duration: 01:34:32.77, start: 0.000000, bitrate: 7004 kb/s Chapter #0:0: start 0.000000, end 189.106000 Metadata: title : 00:00:00.000 Chapter #0:1: start 189.106000, end 324.366000 Metadata: title : 00:03:09.106 Chapter #0:2: start 324.366000, end 546.087000 Metadata: title : 00:05:24.366 Chapter #0:3: start 546.087000, end 802.301000 Metadata: title : 00:09:06.087 Chapter #0:4: start 802.301000, end 1085.751000 Metadata: title : 00:13:22.301 Chapter #0:5: start 1085.751000, end 1250.583000 Metadata: title : 00:18:05.751 Chapter #0:6: start 1250.583000, end 1390.306000 Metadata: title : 00:20:50.583 Chapter #0:7: start 1390.306000, end 1649.898000 Metadata: title : 00:23:10.306 Chapter #0:8: start 1649.898000, end 1815.981000 Metadata: title : 00:27:29.898 Chapter #0:9: start 1815.981000, end 1974.347000 Metadata: title : 00:30:15.981 Chapter #0:10: start 1974.347000, end 2173.588000 Metadata: title : 00:32:54.347 Chapter #0:11: start 2173.588000, end 2373.454000 Metadata: title : 00:36:13.588 Chapter #0:12: start 2373.454000, end 2578.701000 Metadata: title : 00:39:33.454 Chapter #0:13: start 2578.701000, end 2855.019000 Metadata: title : 00:42:58.701 Chapter #0:14: start 2855.019000, end 3071.735000 Metadata: title : 00:47:35.019 Chapter #0:15: start 3071.735000, end 3350.764000 Metadata: title : 00:51:11.735 Chapter #0:16: start 3350.764000, end 3669.457000 Metadata: title : 00:55:50.764 Chapter #0:17: start 3669.457000, end 3906.402000 Metadata: title : 01:01:09.457 Chapter #0:18: start 3906.402000, end 4179.300000 Metadata: title : 01:05:06.402 Chapter #0:19: start 4179.300000, end 4476.889000 Metadata: title : 01:09:39.300 Chapter #0:20: start 4476.889000, end 4661.532000 Metadata: title : 01:14:36.889 Chapter #0:21: start 4661.532000, end 4903.065000 Metadata: title : 01:17:41.532 Chapter #0:22: start 4903.065000, end 5086.498000 Metadata: title : 01:21:43.065 Chapter #0:23: start 5086.498000, end 5672.768000 Metadata: title : 01:24:46.498 Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709), 1920x800 [SAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default) (forced) Metadata: title : Ice Age 5: Collision Course (2016) 1080p @ ~ 4000 Kbps BPS : 3956981 BPS-eng : 3956981 DURATION : 01:34:32.676000000 DURATION-eng : 01:34:32.676000000 NUMBER_OF_FRAMES: 136008 NUMBER_OF_FRAMES-eng: 136008 NUMBER_OF_BYTES : 2805834402 NUMBER_OF_BYTES-eng: 2805834402 _STATISTICS_WRITING_APP: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_APP-eng: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_DATE_UTC: 2016-10-24 04:19:51 _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-24 04:19:51 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: dts, 48000 Hz, 6 channels (default) Metadata: title : English DTS-ES 5.1 @ 1536 Kbps BPS : 1508999 BPS-eng : 1508999 DURATION : 01:34:27.670000000 DURATION-eng : 01:34:27.670000000 NUMBER_OF_FRAMES: 531344 NUMBER_OF_FRAMES-eng: 531344 NUMBER_OF_BYTES : 1069064128 NUMBER_OF_BYTES-eng: 1069064128 _STATISTICS_WRITING_APP: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_APP-eng: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_DATE_UTC: 2016-10-24 04:19:51 _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-24 04:19:51 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(dut): Audio: dts, 48000 Hz, 6 channels Metadata: title : Nederlands (Dutch) DTS 5.1 @ 768 Kbps BPS : 767998 BPS-eng : 767998 DURATION : 01:34:32.768000000 DURATION-eng : 01:34:32.768000000 NUMBER_OF_FRAMES: 531821 NUMBER_OF_FRAMES-eng: 531821 NUMBER_OF_BYTES : 544584704 NUMBER_OF_BYTES-eng: 544584704 _STATISTICS_WRITING_APP: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_APP-eng: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_DATE_UTC: 2016-10-24 04:19:51 _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-24 04:19:51 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:3(dut): Audio: dts, 48000 Hz, 6 channels Metadata: title : Vlaams (Flemish) DTS 5.1 @ 768 Kbps BPS : 767998 BPS-eng : 767998 DURATION : 01:34:32.768000000 DURATION-eng : 01:34:32.768000000 NUMBER_OF_FRAMES: 531821 NUMBER_OF_FRAMES-eng: 531821 NUMBER_OF_BYTES : 544584704 NUMBER_OF_BYTES-eng: 544584704 _STATISTICS_WRITING_APP: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_APP-eng: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_DATE_UTC: 2016-10-24 04:19:51 _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-24 04:19:51 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:4(dut): Subtitle: subrip (default) Metadata: title : Nederlandse ondertiteling (Dutch retail subs) BPS : 54 BPS-eng : 54 DURATION : 01:23:44.977000000 DURATION-eng : 01:23:44.977000000 NUMBER_OF_FRAMES: 1068 NUMBER_OF_FRAMES-eng: 1068 NUMBER_OF_BYTES : 34315 NUMBER_OF_BYTES-eng: 34315 _STATISTICS_WRITING_APP: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_APP-eng: mkvmerge v7.7.0 ('Six Voices') 64bit built on Feb 28 2015 23:39:33 _STATISTICS_WRITING_DATE_UTC: 2016-10-24 04:19:51 _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-24 04:19:51 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES When I select in the Emby LG app to play the default (english) DTS stream Emby Direct Streams the MKV without any remuxing and transcoding. When selecting the second DTS (dutch) audio stream it remuxes the media ending up transcoding the DTS, due to HLS. These lines appear in the log: 2017-12-30 23:08:52.217 Info App: User policy for Vincent. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: True 2017-12-30 23:08:52.217 Info App: Profile: Unknown Profile, Path: /share/Multimedia/Movies/Ice Age 5 Collision Course.2016/Ice Age 5 Collision Course.2016.1080p.H264.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2017-12-30 23:08:52.217 Info App: Profile: VideoAudioCodecProfile, DirectPlay=false. Reason=Unknown Profile.IsSecondaryAudio Condition: Equals. ConditionValue: false. IsRequired: False. Path: /share/Multimedia/Movies/Ice Age 5 Collision Course.2016/Ice Age 5 Collision Course.2016.1080p.H264.mkv Am getting it, I think! I assume this is because of the limitations of the Emby app or LG player for selecting which stream to use. If we depend on the LG media player then it is a fact of life unless you write your own player. So practically, if I want the dutch DTS to be used I have to reconstruct the MKV so that the dutch DTS becomes the first/primary stream. (Or the only audio stream) Is this something the Emby could do? A Handbrake built into Emby, just to shuffle streams? (Still full of ideas) ;-) Vincent
Guest asrequested Posted December 30, 2017 Posted December 30, 2017 You wouldn't need to transcode it. It's really quick and easy to remux an MKV. Try mkvtoolnix. It may also be a condition of which track is marked as default. If you open in it in the header editor of mkvtoolnix, you can change the default and save, without having to remux at all. I would try that, first. But remuxing is very quick.
Quiptix 2 Posted December 30, 2017 Author Posted December 30, 2017 (edited) You wouldn't need to transcode it. It's really quick and easy to remux an MKV. Try mkvtoolnix. It may also be a condition of which track is marked as default. If you open in it in the header editor of mkvtoolnix, you can change the default and save, without having to remux at all. I would try that, first. But remuxing is very quick. Good suggestion. I'm familiar with mkvtoolnix, so I give that a shot for now. But... With the same file something interesting happens. When setting the second DTS (dutch) stream as default, the following behavor occurs on the LG: Stream 1 selected: I get a transcoded version of Audio track 1 (english) Stream 2 (which is default now) selected: I get a direct stream of Stream 1 in DTS Stream 3 selected: I get a transcoded version of Audio track 3 (flemish) When selecting stream 2, Dutch DTS which is marked as default, it won't get remuxed by Emby, however the LG app, gets the direct stream (mkv) and plays audio track 1 (despite not being default), so my assuption is that the LG app only plays the first audio stream. I have checked the assumption to re-number the audio tracks as such that dutch DTS is the first audio stream and behold: Dutch DTS directly streamed. Only now the descriptions of the streams are mixed up... Vincent Edited December 30, 2017 by Quiptix
Quiptix 2 Posted December 31, 2017 Author Posted December 31, 2017 With all this I probably found a bug in how to meta-data is build up. Scanning for meta-data it orders the audio streams on ID and not by track-number. I have no hard evidence at the moment, but will take a look into it.
Luke 42204 Posted December 31, 2017 Posted December 31, 2017 We use the order that we are given from ffprobe.
Guest asrequested Posted December 31, 2017 Posted December 31, 2017 It sounds a bit like this issue. https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=469717
Quiptix 2 Posted December 31, 2017 Author Posted December 31, 2017 (edited) We use the order that we are given from ffprobe. It sounds a bit like this issue. https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=4697 Tested it, and the order doesn't change in the output of ffprobe. Probably looking at ID numbers. It sounds a bit like this issue. https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=469717 Seems pretty similar! Edited December 31, 2017 by Quiptix
