kanipek 230 Posted December 29, 2017 Posted December 29, 2017 (edited) It has been awhile since I have played with ET on my W10 HTPC. Previous versions I did not have any issues with audio playing where I wanted it output yes but audio was always there. So I updated via the web and no audio - LiveTV, recorded playback doesn't seem to matter. I have of course checked the windows config, no issues. These files play fine in other players. When I drop them into the MPV player in ET system folder I get no audio. Is there a config file I need to create, modify, update? I know we were playing around with mpv.conf files earlier in the process. I no longer have that file anywhere. I can drag a file into the mpv player on have in and older portable version of ET on my storage drive at it works fine. I am confused to say the least. theater-63650157908.txt Edited December 29, 2017 by kanipek
Luke 42243 Posted December 29, 2017 Posted December 29, 2017 Try going back to application default audio settings. You must have some configuration that is causing this. Thanks.
kanipek 230 Posted December 29, 2017 Author Posted December 29, 2017 (edited) Try going back to application default audio settings. You must have some configuration that is causing this. Thanks. Yeah haven't altered any settings. If I replace the mpv folder in my installed version with the mpv folder from the portable version I get audio - I would not call that a fix though. Edit - Further testing shows if I only move the "portable_config" folder into the installed ET mpv folder the audio works also. Edited December 29, 2017 by kanipek
Guest asrequested Posted December 29, 2017 Posted December 29, 2017 I've had a few instances of no audio, but I've been training mine for the circus. When you play and have no sound, what do the stats say?
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 I've had a few instances of no audio, but I've been training mine for the circus. When you play and have no sound, what do the stats say? Thanks for replying! With.jpg is with the "portable_config" folder inside the C:\Users\xxx\AppData\Roaming\Emby-Theater\system\x64\mpv folder without.jpg in without the "portable_config" folder inside the C:\Users\xxx\AppData\Roaming\Emby-Theater\system\x64\mpv folder
Guest asrequested Posted December 30, 2017 Posted December 30, 2017 Do a clean install, don't put the portable config back in, test again,and let me know what the stats say, then
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 Do a clean install, don't put the portable config back in, test again,and let me know what the stats say, then So uninstall -> reboot -> re-install then report back?
Guest asrequested Posted December 30, 2017 Posted December 30, 2017 So uninstall -> reboot -> re-install then report back? No need to reboot, I just want to clear any old stuff out. To that point, delete the mpv folder that's in the Roaming folder. The new install will make a new one. Then play something, and let me know what happens.
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 Do a clean install, don't put the portable config back in, test again,and let me know what the stats say, then Here you go. Thanks for helping!
Luke 42243 Posted December 30, 2017 Posted December 30, 2017 Try updating your emby library setup so that the Theater app can reach the media paths directly. In theory this isn't required, but every once in a while it can make a difference.
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 Try updating your emby library setup so that the Theater app can reach the media paths directly. In theory this isn't required, but every once in a while it can make a difference. I have no idea what that means. I am guessing change the path circled in red?
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 Try updating your emby library setup so that the Theater app can reach the media paths directly. In theory this isn't required, but every once in a while it can make a difference. No change after updating the folder path.
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 Just for giggles I downloaded ET from github same result using that version
Guest asrequested Posted December 30, 2017 Posted December 30, 2017 (edited) You said that when you used your portable config, it worked. Can you post the mpv.conf from that folder? Edited December 30, 2017 by Doofus
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 You said that when you used your portable config, it worked. Can you post the mpv.conf from that folder? Here is the weird thing it is just a folder - empty folder?? I add it it works, delete it it doesn't... The Widows Store version 1.1.186 does work for what that is worth.
Guest asrequested Posted December 30, 2017 Posted December 30, 2017 Here is the weird thing it is just a folder - empty folder?? I add it it works, delete it it doesn't... The Widows Store version 1.1.186 does work for what that is worth. Curious! What's in the Roaming/mpv folder?
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 This is from the web download version
kanipek 230 Posted December 30, 2017 Author Posted December 30, 2017 And this is with the empty portable_config that makes it work
Guest asrequested Posted December 30, 2017 Posted December 30, 2017 But what's in the Roaming/mpv folder?
Solution kanipek 230 Posted December 30, 2017 Author Solution Posted December 30, 2017 But what's in the Roaming/mpv folder? Sorry my bad. There is nothing in the Roaming\mpv folder NOW !! That was the answer. Old mpv.conf from October. Thanks for the assist! mpv.txt
Guest asrequested Posted December 31, 2017 Posted December 31, 2017 (edited) That conf is specifying your audio device by ID, not name. That ID can and will, change. If you delete that file, and remove the portable_config folder, do you then get audio? Edited December 31, 2017 by Doofus
kanipek 230 Posted December 31, 2017 Author Posted December 31, 2017 That conf is specifying your audio device by ID, not name. That ID can and will, change. If you delete that file, and remove the portable_config folder, do you then get audio? Yes
Guest asrequested Posted December 31, 2017 Posted December 31, 2017 Yes Voila! If you want to specify your audio device, use the name. Like this. audio-device=wasapi/SC-95 (Intel(R) Display Audio) 1
kanipek 230 Posted December 31, 2017 Author Posted December 31, 2017 (edited) Voila! If you want to specify your audio device, use the name. Like this. audio-device=wasapi/SC-95 (Intel(R) Display Audio) I will probably do that in the future, After I move the shield I am currently using. What is the command to get it to spit out a list of audio devices ? mpv --audio-device=help ??? Edited December 31, 2017 by kanipek
