chjohans 34 Posted February 19, 2018 Author Posted February 19, 2018 As I had the same problem after switching to nfo files, the solution was found in this topic. You have to put the information into the right place, for example: ... <fileinfo> <streamdetails> <video> <format3d>HTAB</format3d> ... Then, it will be recognized on filescan (you can simply rescan single metadata to test this). Ciao, Alfred Thanks! I did try to add exactly this manually but I still could not get Emby to recognize it as 3D. Was multitasking though so maybe I missed something, will try again.
chjohans 34 Posted February 19, 2018 Author Posted February 19, 2018 Thanks! I did try to add exactly this manually but I still could not get Emby to recognize it as 3D. Was multitasking though so maybe I missed something, will try again. Bingo, this worked perfectly, not sure why it didn't work the first time I tried, might have been a typo. Anyhow will get this added to MCM so Emby will correctly identify 3D files with metadata generated by MCM in the future.
nodiaque 62 Posted April 1, 2018 Posted April 1, 2018 Hello, I'm unsure if that was resolved. I have put my first 3D movie in MVC format, file are named xxx 3D.mvc.mkv. But they are detected as normal 2D movie. I did switch them in the metadata manager and lock them to prevent any automated job to revert it. But now, I see 2x the same movie (on in 3D and the 2D one). I would be great if instead of having all 3D movie in double, in the interface, there could be a dropdown list like for the subs and audio where we can choose between different type of movie (3D, extended, etc.). Thank you!
Luke 42201 Posted April 1, 2018 Posted April 1, 2018 Hello, I'm unsure if that was resolved. I have put my first 3D movie in MVC format, file are named xxx 3D.mvc.mkv. But they are detected as normal 2D movie. I did switch them in the metadata manager and lock them to prevent any automated job to revert it. But now, I see 2x the same movie (on in 3D and the 2D one). I would be great if instead of having all 3D movie in double, in the interface, there could be a dropdown list like for the subs and audio where we can choose between different type of movie (3D, extended, etc.). Thank you! If you imported them with pre-existing metadata then you need to make sure the value is also in the metadata.
serpi 82 Posted April 1, 2018 Posted April 1, 2018 If you imported them with pre-existing metadata then you need to make sure the value is also in the metadata. Also, it seems the tag has now to be written in lower case with the latest release of emby. At least for me, it wasn't recognized anymore when written as Format3D, but is was after changing to format3d. Ciao, Alfred
chjohans 34 Posted April 1, 2018 Author Posted April 1, 2018 Also, it seems the tag has now to be written in lower case with the latest release of emby. At least for me, it wasn't recognized anymore when written as Format3D, but is was after changing to format3d. Ciao, Alfred Yes, I've noticed that as well. The Xml Reader though accepts it as "Format3D", go figure! My guess is that someone forgot an "ignorecase" when doing a string comparison.
Luke 42201 Posted April 1, 2018 Posted April 1, 2018 Serpi that hasn't changed. It has always been lowercase for nfo.
Charma 0 Posted July 22, 2021 Posted July 22, 2021 Hi All, I currently have Radarr writing my .nfo files, and it doesn't seem to be adding the Format3d line into the nfo files. I run both Plex and Emby, is there something I can turn on in one of those that WILL right the 3d format into the nfo? Apologies, bit of a n00b, so could be quite an easy fix.
Carlo 4561 Posted July 22, 2021 Posted July 22, 2021 Hi, Any reason you're having the NFO written by Radarr vs letting Emby do it?
