jjvva 0 Posted December 29, 2017 Posted December 29, 2017 I went through the process of getting a certificate from namecheap and importing the certificate into my Emby server. I only allow remote access over https. This worked without issue in version 3.2.33.0. Immediately after doing the upgrade to 3.2.60 I am unable to connect over https. I noticed that in the new version, “Remote (WAN) access” setting is defaulting to an http header and http port using my external domain. it does not appear to recognize that I am trying run over https even though I have checked the setting “Require https for external connections. If I shutdown v 3.2.60.0 and run 3.2.33, everything goes back to working without issue. I have attached an image of the dashboard settings between the two versions. .
Luke 42238 Posted December 29, 2017 Posted December 29, 2017 Hi, are you sure you configured the SSL cert in Emby Server? It sounds like that process did not complete. Thanks.
Luke 42238 Posted December 29, 2017 Posted December 29, 2017 I would suggest configuring it again, then restarting the server and attaching the emby server log. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
jjvva 0 Posted December 29, 2017 Author Posted December 29, 2017 I will try reconfiguring it on the new version. Thanks.
jjvva 0 Posted December 29, 2017 Author Posted December 29, 2017 I removed my .pfx file and domain reference then restarted the server. I then added .pfx file and domain name back and restarted the server. Still the same result. Is there more to configuring ssl on the newer server versions? I believe my .pfx file is good because it works with the old version. I have attached my latest log file.
Luke 42238 Posted December 29, 2017 Posted December 29, 2017 Did you forget to attach the log? thanks.
jjvva 0 Posted December 29, 2017 Author Posted December 29, 2017 (edited) Ooops, here it is. Edited December 30, 2017 by jjvva
Luke 42238 Posted December 29, 2017 Posted December 29, 2017 Does the cert require a password? Interop+AppleCrypto+AppleCommonCryptoCryptographicException: MAC verification failed during PKCS12 import (wrong password?)
jjvva 0 Posted December 29, 2017 Author Posted December 29, 2017 Interesting. I did not set it up with a password but it looks like I was getting this error in 3.2.33 but everything still worked. I will re-generate the .pfx file and see if that resolves it. Thanks for your help.
jjvva 0 Posted December 30, 2017 Author Posted December 30, 2017 I regenerated the .pfx file and added a password that did the trick. Thanks again for your help.
Luke 42238 Posted March 3, 2018 Posted March 3, 2018 I have the same issue with the same error message. I ran "openssl pkcs12 -export -out mydomain.pfx -inkey privkey.pem -in cert.pem -certfile chain.pem -password pass:" to convert my letsencrypt cert to one compatible with Emby but it isn't working at all. How did you add a password to the certificate? Hi @@TheSilentLink, what does "isn't working" mean? Can you provide a little more information? Thanks !
