mcbarata 0 Posted March 10, 2014 Posted March 10, 2014 (edited) Hi I seem to have an issue that I'm unable to transcode / stream on different devices at once. Both devices are iPads Scenario: MB Server Version 3.0.5171.19958 Open MB dashboard via the Safari on the iPads. iPad 1 will start the stream and begin playing the movie. iPad 2 will start to stream and begin playing the movie. Once the movies start playing iPad 1 or iPad 2 will stop and "Could not load movie" "There was an error playing the video." whilst the other resumes playing the movie. Sometimes only both of the iPads will stop playing the movie with the same above errors. I have adjusted the quality settings to see if perhaps it was a Wi-Fi bandwidth issue but the resolve was the same. Thanks in advance server-63530037778.log ffmpeg-07f06e84-db4a-4879-84e7-a6087030ca05.txt ffmpeg-aecb19d4-cedf-4973-af3b-d3a04fa0bb6b.txt ffmpeg-a394b986-42d4-4879-ad19-8e6b9771cba2.txt Edited March 10, 2014 by mcbarata
ebr 16357 Posted March 10, 2014 Posted March 10, 2014 Please help us help you. How to Report a Problem
ebr 16357 Posted March 11, 2014 Posted March 11, 2014 When you edit a post, it doesn't show as new again so we didn't know you added the logs. @@Tikuf is the man that can probably help.
w84no1 27 Posted March 11, 2014 Posted March 11, 2014 Your server specs might help also. The CPU is used to do the transcoding. 2 streams kill my slow server. All of my devices use clients and direct play, only the iPad 1 uses the web client and transcoding.
mcbarata 0 Posted March 11, 2014 Author Posted March 11, 2014 My server spec are... HP ML110 G3 Server Xeon 3065 2.3 Ghz Dual core CPU 8 Gig ram 5 3tb SATA drives Do you think my limitation is on the CPU? Most recommendations seem to point at a quad core i5 or i7
w84no1 27 Posted March 11, 2014 Posted March 11, 2014 I only have a core2quad CPU and my transcoded streams start to crap out at 2 if they are HD. One way to test is to use the servers browser to start a stream and look at task manager and see how much CPU is being used, then start the stream on one of the iPads and see how much CPU is being used, keep adding devices to see if the CPU hits 100% when you get the error.
Tikuf 663 Posted March 11, 2014 Posted March 11, 2014 I see nothing in the ffmpeg logs. It is transcoding plenty fast enough. There are a lot of socket errors in the logs I'm not sure if they are the cause or not. It could also be the ios app? @@darwindeeds @@Luke Anything you guys can see that would be causing this behavior?
