killride 47 Posted December 28, 2017 Posted December 28, 2017 Hello, Is It possible to make the sync faster ? I have around 500 users using my emby server with Kodi and the manual sync is very slow. (I have around 30'000 movies). Thank you.
Luke 42204 Posted December 28, 2017 Posted December 28, 2017 hi there @@killride ! Have you tried the new EmbyCon addon? https://emby.media/community/index.php?/topic/46651-embycon-kodi-addon/page-1 it allows you to browse your emby library without any syncing required!
killride 47 Posted December 28, 2017 Author Posted December 28, 2017 (edited) No but is It possible to use path substitution with Embycon? Because I only use strm files and I give access to the file through FTP server and not SMB Edited December 28, 2017 by killride
Luke 42204 Posted December 28, 2017 Posted December 28, 2017 Yes it is. For your setup i would not recommend the sync plugin. 500 users all syncing individually is too many, because the sync process does require a few extra resources, and it happens individually for each Emby for Kodi installation. Most likely your issue is not the speed of the sync process, but rather too many devices syncing at once.
killride 47 Posted December 28, 2017 Author Posted December 28, 2017 I didn't find the native path like Emby for Kodi. and File Direct Path use SMB so I can't do what I want. Do you have any idea how to setup it like Native path? Thanks
killride 47 Posted December 28, 2017 Author Posted December 28, 2017 I don't know I'm trying on my test server and It always start with direct play. How can I force native path?
killride 47 Posted December 28, 2017 Author Posted December 28, 2017 I tried to play strm file in direct play mode and I remember than last year when I did that with emby for kodi It was the server downloading the movie and streaming to the kodi but now It's not like that with embycon?
killride 47 Posted December 30, 2017 Author Posted December 30, 2017 @ I have this error when I try to read a strm file on my embycon. ERROR: EXCEPTION: Unknown addon id 'script.viewmaster'. this is what the strm looks like : #Aladdin et le Roi des voleurs https://1fichier.com/?xoc8uegldi
killride 47 Posted December 31, 2017 Author Posted December 31, 2017 Hi @@Luke I think I find a way to my problem, I was using HTTPS without certificate so today I added a let's encrypt certificate and now my clients load fluenty the library. Do you think using a ssl certificate helps the server? I have less memory usage now and the server UI is faster than before. 1
