deadonthefloor 4 Posted December 28, 2017 Posted December 28, 2017 (edited) I'm having an issue where Ember crashes when I go to browse any season of my stored TV. I can reproduce this onXbox One, slow ring insider previewLumia 950XL fast ring insider previewAnd on Windows 10 Fast Ring Insider Preview Windows EVENT log shows: - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> - <System> <Provider Name="Application Error" /> <EventID Qualifiers="0">1000</EventID> <Level>2</Level> <Task>100</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2017-12-27T23:32:04.256188500Z" /> <EventRecordID>1252</EventRecordID> <Channel>Application</Channel> <Computer>DESKTOP-M5O7L78</Computer> <Security /> </System> - <EventData> <Data>Ember.exe</Data> <Data>1.0.0.0</Data> <Data>5a3d09ed</Data> <Data>Windows.UI.Xaml.dll</Data> <Data>10.0.17063.1000</Data> <Data>c1f00731</Data> <Data>c000027b</Data> <Data>0000000000719a46</Data> <Data>1c8</Data> <Data>01d37f6a0a5ea9fb</Data> <Data>C:\Program Files\WindowsApps\436337Illusions.com.MediaBrowser_4.5.292.0_x64__77hd5e1v1hqs4\Ember.exe</Data> <Data>C:\Windows\System32\Windows.UI.Xaml.dll</Data> <Data>1ba77645-2b15-4b2d-b4e0-1d4ead98a3f4</Data> <Data>436337Illusions.com.MediaBrowser_4.5.292.0_x64__77hd5e1v1hqs4</Data> <Data>App</Data> </EventData> </Event> Edited December 28, 2017 by deadonthefloor
7illusions 1249 Posted December 28, 2017 Posted December 28, 2017 Is this happening on every season of any show? Which theme are you using when this happens? (User icon - Preferences) Can you try changing the theme to something else just to see if that's the problem. (Make sure you click "save" to apply the changes)
Vicpa 612 Posted December 28, 2017 Posted December 28, 2017 Hi 7 I can reproduce this. Checked both the xbox and ember themes. Seems like any recorded tv, when you click on a season crashes to desktop. Next up etc is ok.. -vicpa must have missed this in my testing coverage, bummer 1
deadonthefloor 4 Posted December 28, 2017 Author Posted December 28, 2017 (edited) Is this happening on every season of any show? Which theme are you using when this happens? (User icon - Preferences) Can you try changing the theme to something else just to see if that's the problem. (Make sure you click "save" to apply the changes) Xbox Theme on Xbox and PC Ember theme on Lumia950XL Just tested 'Dark Clean' on Mobile, works fine. This is a suitable workaround while you folks figure it out. Thanks. Edited December 28, 2017 by deadonthefloor
